Canon M6 mark II with internal battery broken
Badlagar Junior Member • Posts: 33
Today after switching the battery, the camera has resetted the time.
I have read about that and a lot of people is having this issue. It is just the internal battery not loading anymore. There is no possibility of replacement. This looks like a bad batch of batteries and or a poor design of the motherboard.
Really sad, my old Canon 400D still has a functional internal battery and this "new" camera is failing after a couple of years...
From now I will just charge the camera from the USB-C port and only switch batteries if I am outside.
Canon EOS 400D (EOS Digital Rebel XTi / EOS Kiss Digital X) Canon EOS M6
RLBur
MOD RLBur Veteran Member • Posts: 5,551
Re: Canon M6 mark II with internal battery broken
Yes, it seems to be a common problem.  I, too, have the same issue.  With my camera I have found if I switch out the battery within about the first minute, it will not reset.
Randy
 RLBur's gear list:RLBur's gear list
Canon PowerShot A640 Canon PowerShot G1 X Canon PowerShot S120 Canon PowerShot G7 X Olympus PEN E-PL1 +10 more
Photato
Photato Veteran Member • Posts: 3,152
Same problem with mine, this looks to be a defective batch. Could also be triggered if the camera stays off without power for a long time.
From the dozens cameras I’ve owned, none had the internal battery failing, some have been in a drawer for ages without issues turning them back on.
Too bad it happened after the warranty expired.
If we poll the serial numbers a pattern could emerge here.
IMO, the best workaround is to rarely remove the battery and when done, set the clock with the mobile app, is fast and accurate.
 Photato's gear list:Photato's gear list
Panasonic LX100 Canon EOS M Canon EOS M6 Canon EOS M6 II Canon EOS R10 +22 more
