Dynamic range in video
Started 4 months ago | Questions
Israel Bracha New Member • Posts: 13
from what we all learned when we first met the photography world, a bigger sensor = wider dynamic range.
but as its seem in real world it isn’t the case,
and I don’t talking about pictures now because I don’t know, but in video the dynamic range of the full-frame  a7siii the aps-c xh2s and the 4/3 gh6 are more or less the same.
what do we missing? Does the difference in sensor size doesn’t exist (for DR) because of a weaker link in the chain (like a processor or something ) ?
 Israel Bracha's gear list:Israel Bracha's gear list
Sony a7 III Tamron 28-75mm F2.8 III
Sony a7 Sony a7S
NickZ2016 Veteran Member • Posts: 5,836
Re: Dynamic range in video
Just like stills final range is a function of the output device. IIRC Rec 709 is pretty tight at six stops?
That means if you aren't recording at least log you're in a pretty tight place to begin with.  Log can get you twice that. So can RAW.
The other issue is things are often related to the generation of each sensor. That means the best small sensor today might be better than the best large sensor of ten years ago. In spite of the size advantage.
 NickZ2016's gear list:NickZ2016's gear list
Nikon D800 Nikon AF-S Nikkor 50mm F1.4G Nikon AF Nikkor 35mm f/2D Nikon AF-S Nikkor 50mm F1.8G Nikon 85mm F1.8G +4 more
Samuel Dilworth
Samuel Dilworth Senior Member • Posts: 1,391
I don’t know about the Fujifilm, but the Sony α7S III slathers the image in heavy noise reduction that you cannot turn off (so that more discerning users are forced to buy an FX6 with the same sensor).
So the dynamic-range performance of that full-frame camera is deliberately limited by software. (Therefore it does much better in stills mode with a Raw file.)
The GH6 is Panasonic’s full-tilt effort and suffers no such restrictions.
sludge21017
sludge21017 Veteran Member • Posts: 3,813
It appears you would need to record externally to bypass internal NR.
Fx30 Dual Base ISO | YES it works - YouTube
Samuel Dilworth
Good point and supporting evidence by video. (I presume it works the same way with the α7S III.)
The FX6 (but not, from memory, the FX3) allows you to record internally without this heavy noise reduction.
Of course the noise reduction is usually useful, not least because it massively reduces the random motion of the image that needs to be compressed by the codec. So it greatly improves overall image quality with the highly lossy codecs we typically use with these cameras.
Sean Nelson
Sean Nelson Forum Pro • Posts: 16,109
Israel Bracha wrote:
...in video the dynamic range of the full-frame a7siii the aps-c xh2s and the 4/3 gh6 are more or less the same.
If you shoot 8-bit video in all those cameras then you're going to hit the limits of the 8-bit color depth before you hit the limits of the sensors.
Markr041 Forum Pro • Posts: 10,078
The codec stress of random noise is less with intra-frame codecs, right? These are available for the fx3 and fx30. And noise reduction smears detail in an ugly way so nr effects on image quality does not obviously increase iq.
 Markr041's gear list:Markr041's gear list
Panasonic ZS100 Olympus TG-5 Canon EOS M Panasonic Lumix DMC-GH4 Nikon Z6 +5 more
John Brawley Contributing Member • Posts: 780
What you’re missing is accepting a gross generalisation as being true in all circumstances.
Many factors affect the DR of the sensor, even before it’s gets to post capture processing (which is what most people talk about here)
All things being equal, a larger sensor could afford a smidge more DR, typically because you tend to be oversampling the noise, so the perception is that it has more DR. I qualified this on a million ways that mean you can never compare apples to apples.
Some cameras are also sensor optimised for DR and some for stills.  You can’t take the stills as the same DR number either.
JB
John Brawley
Cinematographer
LA California
www.johnbrawley.com
http://johnbrawley.wordpress.com/
 John Brawley's gear list:John Brawley's gear list
Leica M8 Leica M-E Typ 220 Olympus E-M5 II Olympus E-M1 II Leica M10 +37 more
