Canon EOS R6 Mark II Sensor Measurements at PhotonsToPhotos
Ephemeris
Ephemeris Senior Member • Posts: 1,186
Re: Canon EOS R6 Mark II Sensor Measurements at PhotonsToPhotos
PAntunes wrote:
Ephemeris wrote:
PAntunes wrote:
Ephemeris wrote:
John Sheehy wrote:
Mr F48 wrote:
I've been looking at comparisons between different brands and that R5 sensor looks great in terms of PDR.
I wouldn't put too much stock in a high DR that is achieved by raw-cooking the deep shadows.
Does this not benefit the user, however a camera or brand may process the data?
No, it doesn’t benefit the user.
So what is the purpose? I am assuming that these type of systems don't allow access to RAW ADC data (just an assumption), for example those used in automotive which is more my world may be slanting my thoughts and our cameras may work differently.
The noise reduction applied pre raw saving can’t be removed. So if you need the information, there’s nothing you can do.
That makes sense but I assume quite a lot is done to the data anyway. From above I could be off track here.
At the same time, you can apply the same noise reduction in post to other cameras and have better measured DR.
So if we apply some NR as you mention to say the RAW from an R5 and from a Sony A1, we would see improvement from Sony but not from Canon?
You'd have more freedom to fine-tune the sony file.
So you’re not gaining anything that you couldn’t achieve in post, but you’re losing the possibility to adjust it to your needs.
Understood
But this allows canon to claim to have the same DR than the competition.
Maybe you answered one of my questions here, so the purpose is marketing?
I'd say yes. Canon could skip the noise reduction baked in, and the raw converters could do that step in post easily. But then we'd still have graphics saying that the canon is still behind in DR.
And where this kind of approach to marketing really annoys me is when the information isn't disclosed and actually affects the final image.
If you see the Electronic Shutter mode, the DR is quite low. We're losing 2 stops in DR, from 11.5 to 9.5 stops. That's old 6D levels. But canon won't inform the user that this happens. So, many users will be happily shooting in silent mode, thinking they're getting the best image possible, but will end up with lower DR.
Most appreciated fella.
Thank you.
I do try to use Bill's data to help me choose which shutter mode if possible. So normally I would try to use MS at lower ISO and at higher I may opt for ES if I need that 20fps and won't be loosing much in the image.
As for explaining the downsides if ES to the user, other than the reduced bit output within the manual I agree it's not so clear from Canon. We are fortunate to have this information source and also people like Bill.
OP bclaff Forum Pro • Posts: 13,922
Gaps
John Sheehy wrote:
bclaff wrote:
Higgins2002 wrote:
I believe the R3 is 13 bits in ES otherwise it should be similar to the mechanical graf but it isn't
A 13-bit histogram would not be this smooth.
Are gaps in histograms really much of a thing anymore, with independent ADCs having different potential blackpoints? The firmware could be shifting the offsets before writing the raw file.
R3 ES histogram
These looks like gaps to me:
R6 Mark II ES histogram
Bill ( Your trusted source for independent sensor data at PhotonsToPhotos )
