Canon EOS R6 Mark II Sensor Measurements at PhotonsToPhotos
bclaff Forum Pro • Posts: 13,922
23
Here is the Photographic Dynamic Range (PDR) :
Also shown is the Canon EOS R6 and Electronic Shutter (ES).
Bill ( Your trusted source for independent sensor data at PhotonsToPhotos )
Ephemeris
Ephemeris Senior Member • Posts: 1,186
Re: Canon EOS R6 Mark II Sensor Measurements at PhotonsToPhotos
Thanks for posting Bill.
Where the electronic shutter starts to have a similar PDR ot the mechanical, at around the 8 point is this similar to other Canon cameras? (Sorry I have some network issue with your site at the minute so couldn't check).
OP bclaff Forum Pro • Posts: 13,922
The effect of Electronic Shutter (ES) varies depending on the camera model so you'll have to check that out yourself. Hopefully you network issues will resolve. I'm not aware of any issues at the PhotonsToPhotos.net end of things.
johnpul Junior Member • Posts: 37
Bill you are the man. Thank you for all that you do. Photonstophotos is such a great resource.
The dynamic range of the R6ii looks solid and truly competitive with Sony offerings.
Can you explain whether the "triangle down - noise reduction" markers for sub 3200 ISOs is a bad thing?
I see that the Sony A74 for example... has similar values but only circles.
Does this mean the Canon sensor is sacrificing some detail to hit these dynamic range figures?
My untechnical mind is surprised there would be noise reduction going on at iso 100.
Noise Reduction at Low ISO
6
Noise Reduction (NR) at low ISO settings has become more common with certain brands in recent years. NR does result is some loss of detail but I have no truly objective way of measuring that. I'm working on it. Personally I would prefer to have complete control over how I apply NR so I would prefer that I could disable this behavior. Strangely enough it is not applied when Electronic Shutter (ES) is invoked. (As I was writing this I realized that my software wrongly put the triangles on the ES data and I have just fixed that.)
One way to judge the amount is to look at the energy spectra.
R6 Mark II
R6
R6 Mark II (ES)
The stronger the NR the deeper the dip. Flat is no NR.
Revised to remove NR indicators for ES
silentstorm Senior Member • Posts: 1,718
Thank you bclaff
Great info as usual. Interestingly both old and new R6 exhibit similar measurement, ie. DR is reduced using ES at the lower ISO.
Why is this so? Fuji, Olympus, Sony, Nikon, etc don't have such gaps when using ES vs MS.
Any ES measurement for the R10 and R7?
Thanks.
Re: Thank you bclaff
Thanks.
I believe the electronic shutter is lower bit (12?) files and therefore lower dynamic range    â€” could be wrong
SigZero
SigZero Contributing Member • Posts: 686
Thanks.
I believe the electronic shutter is lower bit (12?) files and therefore lower dynamic range — could be wrong
Yep it's probably due to Canon's ES still being limited to 12 bit read-out. It's common in all R bodies.
Br, Pawel
My photo-blog: http://pawel.online
 SigZero's gear list:SigZero's gear list
Canon EOS R5 Canon RF 100-500mm F4.5-7.1L IS USM Canon RF 70-200 F4 L Canon RF 14-35mm F4L IS USM Apple iPhone 13 Pro
SigZero
Thanks Bill.
Seems that R6mk2 share the same sensor technology with R6 with only some minor adjustments (or the improvement is due to additional 4mpix)
Br, Pawel
cocoanud
cocoanud Contributing Member • Posts: 699
Re: Noise Reduction at Low ISO
Hi Bill,
Does the R6 apply Low ISO NR in ES as well ? It has the down triangles in the graph ?
Thanks,
—C
 cocoanud's gear list:cocoanud's gear list
Canon EOS R6 Canon EF 100-400mm F4.5-5.6L IS II Canon EF 70-200 F4 II Canon RF 24-105mm F4L IS USM Samyang AF 85mm F1.4 RF +3 more
evertdoorn Regular Member • Posts: 159
Thanks.
Br, Pawel
I believe the ES of the R3 is 14 bit
SigZero
evertdoorn wrote:
Thanks.
Br, Pawel
Yep, I think this is the only exception.
Br, Paw.
SigZero wrote:
evertdoorn wrote:
Thanks.
Br, Pawel
Br, Paw.
yep, that's one of the appeals of the R3 above the R6 (II), plus the stacked sensor for those that shoot fast movement
Sittatunga Veteran Member • Posts: 5,406
Thanks.
Br, Pawel
I thought the original EOS R gives 14 bits in ES. It certainly gives 30 second exposures in ES rather than the ½ second maximum of the R5/6.
Ephemeris
Sittatunga wrote:
Thanks.
Br, Pawel
That is also 12-bit, I don't recall the maximum shutter time myself but with your info I don't know why those systems are different.
Ephemeris
SigZero wrote:
evertdoorn wrote:
Thanks.
Br, Pawel
Br, Paw.
We didn'took at the R3 to closely due to its resolution but the information from the analysis Bill has provided shows a different pattern to other R cameras operating in ES.
https://www.photonstophotos.net/Charts/PDR.htm#Canon%20EOS%20R6%20Mark%20II
MAC Forum Pro • Posts: 18,487
Thanks.
Br, Pawel
my M6II stays in 14 bit during e-shutter
like other manufacturers, Canon is deploying 12 bit for some cameras for quickness
 MAC's gear list:MAC's gear list
Canon EOS 7D Mark II Canon EOS RP Canon EOS M6 II Canon EOS R8 Canon EF 70-200mm f/2.8L USM +7 more
that e-shutter for DR sucks on R6II
Even my M6II with e-shutter uses 14 bit and has better DR
maybe at base iso, but it's not that great to be honest. Rather have that R6 (II) since that still gives you the option to use max dr with a mechanical shutter
