Viltrox 85mm f1.8
Resoman Regular Member • Posts: 268
Viltrox 85mm f1.8
I bought this lens two years ago, and returned it, being so frustrated with the clunky and unpredictable AF performance on my X-T3. It remains a very desirable lens for me and, based on the positive reviews of the lens that I've read, I'm thinking that I may have just had a bad copy.
Anyway, I'm now using an X-T4, and am seriously considering giving the lens another try. What do those of you who own this lens have to say?
 Resoman's gear list:Resoman's gear list
Fujifilm X100V Fujifilm X-E3 Fujifilm X-T4 Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm XF 55-200mm F3.5-4.8 R LM OIS +7 more
Fujifilm X-T3 Fujifilm X-T4
Ian J G Contributing Member • Posts: 825
Re: Viltrox 85mm f1.8
Hi
For what it's worth, I have this lens and use it on an X-t20, and the autofocus works fine as far as I can tell, as well as any other lens I have for the system, but no I haven't done any specific testing of it. Just used it and seems fine.
Good luck
Ian
instagram: Iangoldring
 Ian J G's gear list:Ian J G's gear list
Fujifilm X-T20 Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm XF 27mm F2.8 Samyang 12mm F2.0 NCS CS Fujifilm XF 35mm F2 R WR
RustyRus Senior Member • Posts: 1,696
Why not the 90 f/2. It can be had for 200ish more used. Amazing lens and as good at autofocus as it gets.
 RustyRus's gear list:RustyRus's gear list
Ricoh GR III Leica Q2 Fujifilm X100V Fujifilm X-Pro3 Leica M11 +1 more
Rightsaidfred
Rightsaidfred Senior Member • Posts: 2,179
I use it the Mk II on my X-T4. While its AF speed is not excellent, it is certainly not bad either. Well, I just don't know how should I measure it with objective criteria...
Focus accuracy is good IMO, I only have few outliers.
I use the lens mostly wide open, always AF-S + box, rarely AF-C, no video done yet with it.
There is a video review by Dustin Abbott, and he says, face detection of the Viltrox 85 works quite well on Sony, better than on Fujifilm.
Optically, it is good. There is a test by Opticallimits, Viltrox PFU RBMH 85mm f/1.8 STM (Fujifilm X) - Test Report / Review. The Mk II has the same formula.
I got this lens for 350 € from Rollei, and I have to say, this is excellent value for money.
What they really screwed up with the 85/1.8 II is the lens hood. It is terribly cumbersome to mount and unmount.
Btw, up to date, my fastest focusing lens ever is probably the Viltrox 13/1.4.
Martin
 Rightsaidfred's gear list:Rightsaidfred's gear list
Fujifilm X-T20 Fujifilm X-T4 Fujifilm XF 35mm F1.4 R Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm XF 55-200mm F3.5-4.8 R LM OIS +5 more
Human Elements
Human Elements Senior Member • Posts: 1,051
I had no trouble with the Viltrox 85mm II on my X-T4. The Mark I version was also fine on my X-T2.
https://www.human-element.me/
Please do not edit my images without permission.
 Human Elements's gear list:Human Elements's gear list
Sigma DP1 Merrill Sigma DP2 Merrill Sigma DP3 Merrill Fujifilm X-T4 Fujifilm XF 35mm F1.4 R +2 more
Erik Baumgartner Senior Member • Posts: 6,894
I tried one (the original version) out on my X-T2 and found it to be quite good, better than good, actually. No problems with the AF at all. The best Viltrox I've used except for the stellar 13 f/1.4. I bet the new 75 f/1.2 is even better.
Sony RX100 Fujifilm X100V Fujifilm X-T2 Fujifilm X-T20 Fujifilm XF 35mm F1.4 R +5 more
