How Do You Like the RF-S 18-150mm?
davev8
davev8 Veteran Member • Posts: 4,833
Re: How Do You Like the RF-S 18-150mm?
Messier Object wrote:
I would like it more if it was
* 14mm at the wide end,
* constant f/4
* weather sealed
I wouldn't mind if it was shorter at the long end, say 100mm or even 80mm if that would make it easier for Conon to make it more compact
But what I'm asking for is a better quality lens almost to 'L' level and giving me 24-105mm coverage without having to carry a FF camera - something Canon has always seemed reluctant (if not stubbornly resistant) to do for crop lenses
They did do the EF-s 17-55F2.8 and the 15-85 F3,5-5.6 which were good lenses, especially the 2.8  couple that to the only 2 EF-s primes the 24mmF2.8 pancake and a 60mm macro
so canon only made 4 decent lenses with good build and optics for the EF-s mount in 20 years so i don't hold much hope for RF-s
a mention has to go the 10-18 and the 55-250STM although cheaply made are optically good
the last EF-s 18-55 kit lens the F4-5,6 one is also pretty sharp
Peter
Attention Dislexsic i mean dyslexic person... This post will have many although spell checked, spelling and grammatical errs ..its The best its going get so no need to tell me it is bad I know it is .....................................................................................................
the EOS M is not dead and wont be for a long time ....as long as you don't want a flagship camera with a VF...if that's the case it died sometime ago
My 5D IS a MK1 classic
There is no argument for FF vs APS-c (or m43) with shallow DOF..as it's a law of physics and a very subjective personal thing if you want to make use of the shallow DOF only FF can offer
If you wait for a camera that will  tick all your boxes ....by then you will have more boxes to tick..... so the wait continues .....David Appleton
 davev8's gear list:davev8's gear list
Canon EOS 5D Canon EOS R6 Canon EF 50mm F1.4 USM +5 more
davev8
Tweakers Net wrote:
In my experience, the 18mm is not wide enough. Canon lenses should start at 15mm because of the 1.6 crop.
i am surprised they did not port over the EF-m 15-45 F3.5-6.3 as canon did with the 18-150 rather than making a new slower lens the RF-S 18-45mm f4.5-6.3 starting at 18mm and not optically as good as the M lens
OP CamerEyes Regular Member • Posts: 266
Purchase Complete, Initial Impressions
Sweet deal for $300! Initial impressions (some a mere reiteration of feedback and comments above):
  • Quiet and fast focusing
  • Light yet does not feel fragile
  • Can do a bit of macro up to around 100mm
  • Sharpness is above what's usual for this price range
  • Just half an inch longer (when fully retracted) than the RF24mm (and slimmer)
  • Obvious downside: Indoor with average lighting, you'll have to be north of ISO800 for the lens to be usable. I've taken shots at 1/10 shutter speeds with 75-80% keeper rate so far
 CamerEyes's gear list:CamerEyes's gear list
Sony a7C Canon EOS R7 Canon EOS R6 Mark II Canon EF 50mm f/1.2L USM Canon EF 50mm F1.4 USM +12 more
MAC Forum Pro • Posts: 18,487
* constant f/4
* weather sealed
15-85 F3,5-5.6
I had two of these and shot 15 mm all the time
now I enjoy my RP + RF 24-105 F4L for travel and walkabout - best 24-105 ever made
I use my 24mm extensively
Peter
 MAC's gear list:MAC's gear list
Canon EOS 7D Mark II Canon EOS RP Canon EOS M6 II Canon EOS R8 Canon EF 70-200mm f/2.8L USM +7 more
Photato
Photato Veteran Member • Posts: 3,152
Re: Purchase Complete, Initial Impressions
Glad you like it, $300 is a good deal for it.
The lens hood for it is the same as the EF-M 18-150 or EF-M 18-55. As a matter of fact any lens hood for the Canon EF-M is mountable on the RF-S lenses. AFAIK
BTW, unrelated question.
I noticed you have both the RF16 and RF24.
Is the RF24 bayonet lens hood mountable on the RF16?
I know it would vignette but not when using it with an APS-C body.
TIA.
 Photato's gear list:Photato's gear list
Panasonic LX100 Canon EOS M Canon EOS M6 Canon EOS M6 II Canon EOS R10 +22 more
TIA.
No. The grooves in the 16mm are wider (24mm's slimmer) so despite the same diameter on where the hood can be mounted, it wiggles when mounted on the RF16mm.
The lens hood of the RF50mm f/1.8 fits the 16mm perfectly (and as you already indicated, you'd use it for cropped shots anyway so vignette won't be an issue). This hood btw won't rotate at all (therefore cannot be mounted) on the RF24mm.
Photato
TIA.
Thanks for let me know.
A couple of days ago upon checking some pictures I decided it was better to get the RF50f1.8 hood instead. Glad you confirmed it works on the RF16 as well since I have both lenses.
I also ordered the hood for the RF 100-400 and is arriving today, I’m expecting it to be compatible with the RF85 f2
TIA.
You're welcome. My turn to ask: The hood for such long lens fits the 85mm?
Photato
TIA.
It did not, unfortunately.
The RF85 f2 hood mount diameter is a tiny bit bigger like 1 mm more, I even tried to force it but nothing.
More likely Canon deliberately designed it this way so people don't use the wrong hood on FF cameras.
A shame since the length when reversed for storage, fits the shorter 85 lens length perfectly.
Not a big deal, but I was hoping to have the extra shading coverage this longer hood provides and also for sharing this hood between these lenses.
TIA.
Well, you tried!
It will be an adventure to find lens hoods for my 18-150mm and my newest 15-30mm.
Photato
TIA.
Well, you tried!
For the 18-150mm it is straight forward unless you want to use the longer EF-M 55-200 hood when using specifically the 55-150 range.
I'm not 100% if those are compatible but all my Canon EF-M lens hoods are compatible with each other.
For the 15-30 when on the R7 there might be alternatives but is hard to find out.
natrpixvet Junior Member • Posts: 42
I have the 18-150 and consider it to be more than adequate with a very useful range for travel and landscape work. Pair this with the ef-s 10-18, which is amazingly good for its price,  for your wide angle work and this should cover most of want you want to do.
 natrpixvet's gear list:natrpixvet's gear list
Canon EOS 5D Mark IV Canon EOS R7 Canon EF-S 10-18mm F4.5–5.6 IS STM Canon EF 16-35mm F4L IS USM Canon EF 50mm F1.8 STM +3 more
davev8
RF-S 18-150mm sharper than the RF24-105F4L?
CamerEyes wrote:
For those who bought the bundle of either the R10 or the R7, any feedback on how you find the EF18-150mm lens? Have an option to purchase one for $300 U.S. and it's practically brand new since the owner bought it with a package and only tested it for a few shots but uses his EF70-200mm almost hundred percent of the time for sports.
Plan to use it for travel (landscape, cityscape, street), when having a couple of primes may not be practical.
TIA!
here is a vid comparing the 18-150 to the RF 24-105 both on a R7,, the 18-150 seems amazing sharp ..but remember the 24-105 is a FF lens and is disadvantaged when fitted to APS-c but nobody would complain about the performance of the 24-105 on APS-c
https://www.youtube.com/watch?v=sxDr67weTGQ
RDM5546
RDM5546 Senior Member • Posts: 3,654
Re: RF-S 18-150mm sharper than the RF24-105F4L?
TIA!
I found this review very interesting.  I have both lenses.  I love the RF-S 18-150.   I have the R7 and the R5.   My RF 24-105f4L IS is big and heavy while no better than the 18-150.
I had low expectations for the 18-150 kit lens when I bought it to get quick delivery of the R7 but was very surprise by how good it is for such a small and light weight lens.
 RDM5546's gear list:RDM5546's gear list
Canon RF 100-500mm F4.5-7.1L IS USM Canon G5 X II Canon EOS 70D Canon EOS 7D Mark II Canon EOS 5D Mark IV +47 more
Alastair Norcross
Alastair Norcross Veteran Member • Posts: 9,874
TIA.
Well, you tried!
Yes, I am using the same hood I bought for my EF-M 18-150. It's the JJC LH-60F, easily available on Amazon for $9.99.
“When I die, I want to go peacefully in my sleep like my grandfather. Not screaming in terror, like the passengers in his car.” Jack Handey
Alastair
http://anorcross.smugmug.com
Equipment in profile
 Alastair Norcross's gear list:Alastair Norcross's gear list
Canon G7 X II Canon EOS M6 II Canon EOS R7 Canon EOS R6 Mark II Canon RF 35mm F1.8 IS STM Macro +24 more
