How Do You Like the RF-S 18-150mm?
CamerEyes Regular Member • Posts: 266
For those who bought the bundle of either the R10 or the R7, any feedback on how you find the EF18-150mm lens? Have an option to purchase one for $300 U.S. and it's practically brand new since the owner bought it with a package and only tested it for a few shots but uses his EF70-200mm almost hundred percent of the time for sports.
Plan to use it for travel (landscape, cityscape, street), when having a couple of primes may not be practical.
TIA!
 CamerEyes's gear list:CamerEyes's gear list
Sony a7C Canon EOS R7 Canon EOS R6 Mark II Canon EF 50mm f/1.2L USM Canon EF 50mm F1.4 USM +12 more
Canon EOS R10 Canon EOS R7
Photato
Photato Veteran Member • Posts: 3,152
Re: How Do You Like the RF-S 18-150mm?
TIA!
I usually stay away from these super zoom lenses, but since it is currently the better option out of the only two true native lenses available I went ahead and got it as a kit with the R10.
It turned out to be a good decision since it is has been better than expected, perhaps I got lucky with a good copy, who knows.
I compared it with almost all my other lenses where they share same focal length and I was surprised how sharp it is for such a long FL range, (with or without lens corrections).
It works best as a general purpose lens in good light, it is convenient, fun and light weight, it is relatively compact for what it does, but a bit longish compared to primes, probably twice as long as the other kit lens, so I wouldn't call it ultra portable.
But it focus fast, accurately and is very quiet, the OIS also works great.
One of my biggest surprises was that it almost matches the same resolving power as my Panasonic P&S superzoom FZ1000 at 400eqv vs this lens 240eqv ! mostly due to the sensor differences but still a great performance.
For landscape and cityscape might be narrow at 18mm (29mm eqv) but you already knew this. If this lens started at 15mm, instead of 18, it would be perfect IMO.
So, it is a very good lens if you can live with its limitations, mainly small apertures and not being wide enough at the wide end.
 Photato's gear list:Photato's gear list
Panasonic LX100 Canon EOS M Canon EOS M6 Canon EOS M6 II Canon EOS R10 +22 more
MAC Forum Pro • Posts: 18,487
TIA!
good summary
lens changes would drive me crazy since 24 mm on my RF 24-105 F4L is a staple for me
 MAC's gear list:MAC's gear list
Canon EOS 7D Mark II Canon EOS RP Canon EOS M6 II Canon EOS R8 Canon EF 70-200mm f/2.8L USM +7 more
chrisis
chrisis Forum Member • Posts: 63
TIA!
I’ve been pretty happy with mine. I bought it as a kit lens with my R7 since that was the fastest way (at the time) to get the camera, but also because I had the M version on my M6 MKII and was happy with that. I didn’t expect to use it much since I already had a small stable of RF L lenses for my R5 and a large stable of EF lenses to adapt. However it Is so small and light that I often just leave it on the camera when I am walking about, or traveling.  The quality is much better than the price would indicate.
It’s no “L” lens by any stretch of the imagination. But its a good buy.
Against stupidity the gods themselves contend in vain
 chrisis's gear list:chrisis's gear list
Canon EOS 7D Mark II Canon EOS M6 II Canon EOS R5 Canon EOS R7 Canon RF 24-105mm F4L IS USM +5 more
RDM5546
RDM5546 Senior Member • Posts: 3,654
MAC wrote:
TIA!
One of my biggest surprises was that it almost matches the same resolving power as my Panasonic P&S superzoom FZ1000 at 400eqv vs this lens 240eqv ! mostly due to the sensor differences but still a great performance with bad lighting.
good summary
I have plenty bigger heavier and more expensive lenses that might be used. I also bought the R7 with the 17-150 zoom to get quick June 20 delivery by buying an R7 kit rather than the body only product.
I did not expect this much performance from the 17-150 and was amazed with the performance. Much like the RF 24-240 this RF-S lens was very good a superzoom. These new RF mount lenses are impressive.
Is also use the EF-S 10-18mm with R7 for an ultrawide lens. It is has been small, light and great too as a companion to the RF-S 18-150 to get light and handy high quality coverage from 10-150mm FL. Both lenses are excellent for traveling and work well for outside photographic lighting. I have the compact brighter 16,24, 35, 50 primes but the darker zooms are much easier to use except indoors.
 RDM5546's gear list:RDM5546's gear list
Canon RF 100-500mm F4.5-7.1L IS USM Canon G5 X II Canon EOS 70D Canon EOS 7D Mark II Canon EOS 5D Mark IV +47 more
OP CamerEyes Regular Member • Posts: 266
TIA!
Thank you, looks like a reliable all-rounder!
TIA!
Thanks, this is helpful in terms of managing my expectations of this lens.
oppy
oppy Contributing Member • Posts: 502
Guess I'll be the one dissenting opinion.  I find it to be kind of soft, with unimpressive DR, and the AF/IS has been a bit on the unreliable side compared to my other lenses.  It's not awful, but I think the 18-135 kit lens I got with my 80D takes much better photos.
I'm not saying don't buy it, since $300 is a good price.  Just don't have unrealistic expectations.
 oppy's gear list:oppy's gear list
Canon EOS 80D Canon EOS R7 Canon EF 70-200mm F2.8L IS II USM Samyang 14mm F2.8 ED AS IF UMC Canon EF-S 10-18mm F4.5–5.6 IS STM +6 more
Alastair Norcross
Alastair Norcross Veteran Member • Posts: 9,874
Excellent lens. Very sharp, light, and versatile. Better than the EF-S 18-135 (all versions). It even seems a bit better, to me, than my EF-M 18-150.
“When I die, I want to go peacefully in my sleep like my grandfather. Not screaming in terror, like the passengers in his car.” Jack Handey
Alastair
http://anorcross.smugmug.com
Equipment in profile
 Alastair Norcross's gear list:Alastair Norcross's gear list
Canon G7 X II Canon EOS M6 II Canon EOS R7 Canon EOS R6 Mark II Canon RF 35mm F1.8 IS STM Macro +24 more
Alastair Norcross
DR? What does that mean? Usually, 'DR' is used to mean 'dynamic range', but that's a property of sensors, not lenses. What are you using it to mean?
Alastair
SteveinLouisville
SteveinLouisville Senior Member • Posts: 1,586
More like $500.
https://www.bhphotovideo.com/c/search?Ntt=canon%2018-150mm%20lens&N=0&InitialSearch=yes&c3api=4680%2C%2Ccanon%2018-150mm%20lens%2Ce&msclkid=019f73fec0ff173ba1d21055d5fd8ff7
 SteveinLouisville's gear list:SteveinLouisville's gear list
Canon EOS RP Canon EOS R7 Canon EF 17-40mm f/4.0L USM Canon EF 40mm f/2.8 STM Canon EF-S 24mm F2.8 STM +9 more
oppy
SteveinLouisville wrote:
More like $500.
Right, it's $499 new, so $300 would be a good price.
Andreas Berglund
Andreas Berglund Contributing Member • Posts: 894
I used the R7, 18-150 (and the EF-S 10-18) on my recent trip to Portugal and Sweden. I shot about1600 images, = 56gb. I think the 18-150 is a much better kitlens than what I expected:
  • Surprisingly sharp in all of the range including at 150.
  • Only a handful images were oof in good conditions, a few in lowlight for sure when I was pushing it indoors, but fast silent AF.
  • Light with a huge range
  • IS in the body makes for great pretty sharp images indoor at churches etc, outdoor at night at say down to 1/15th of a second and ISO 1600.
  • I wish it was 24mm FF equivalent (= 15mm crop) at the wide end, the 10-18 takes over then but it is annoying to change all the time in city landscapes
Andréas Berglund
delapsus resurgam
 Andreas Berglund's gear list:Andreas Berglund's gear list
Nikon D2X Canon EOS M5 Canon EOS R5 Canon EF-S 17-85mm f/4-5.6 IS USM Nikon AF-S Nikkor 16-35mm F4G ED VR +26 more
Thank you, this testimony matters as I am about to pay for the lens in a few hours!
Appreciate this, very helpful - especially since I plan to use it primarily for travel, for when carrying heavier lens sometimes reduce the joy of exploring streets, food, culture.
Messier Object Forum Pro • Posts: 12,693
I would like it more if it was
* 14mm at the wide end,
* constant f/4
* weather sealed
I wouldn't mind if it was shorter at the long end, say 100mm or even 80mm if that would make it easier for Conon to make it more compact
But what I'm asking for is a better quality lens almost to 'L' level and giving me 24-105mm coverage without having to carry a FF camera - something Canon has always seemed reluctant (if not stubbornly resistant) to do for crop lenses
Peter
Alastair Norcross
* constant f/4
* weather sealed
It would still be much bigger and heavier. Look at the EF-S 15-85.
Peter
Alastair
Tweakers Net New Member • Posts: 24
In my experience, the 18mm is not wide enough. Canon lenses should start at 15mm because of the 1.6 crop.
palane Contributing Member • Posts: 617
It starts at 18 so canon can sell the 10/11-? that will come in 2023.
For me 24(15X1.6) IS wide enough, so Canon could only sell me 1 lens instead of 2.
CPNock
CPNock Contributing Member • Posts: 685
Had a M50 for a few years and my 18-150 was fine, when I switched to the R7 I got the new one as kit lens. It feels the same lens and happy with the results so far
 CPNock's gear list:CPNock's gear list
Panasonic ZS100 Canon EOS R7 Canon EF 50mm F1.8 II Canon RF 100-400mm F5.6-8 IS USM Canon RF-S 18-150mm F3.5-6.3 IS STM +1 more
