A Bit Of Work To Do (MD7)
Hike Pics
Hike Pics Senior Member • Posts: 2,917
Since Turbguy1's post about infrared with his DiMAGE 7 I have been interested in obtaining one. Recently I found one with the original box and paperwork.
However, it came with a bit of corrosion to clean. Thankfully the metal contacts can be removed and cleaned easily. The internal contacts look good.
I was a bit surprised that it came with some sort of IR filter. I can't find any info on it online but when held up to a very bright light it looks like a redish-burgundy color. The camera came with a 1GB CF card that had 2 thumbnail photos taken with the filter. The effect looked nice. I'm going to post on the Open Talk forum to see if anyone knows about the filter.
neilt3
neilt3 Veteran Member • Posts: 3,008
Re: A Bit Of Work To Do (MD7)
Looks like a store branded filter . You'll soon see if it's any good .
If you do get another, I can recommend a B&W 092 filter . It lets light past down to 695nm rather than the usual 720nm , your still getting the effects but as your letting a bit more light in it improves the shutter speed for hand held shooting.
I use one on both film ( Rollei Infrared ) and digital , though i do use some 720nm as well .
I'm sure the camera will be working fine , but make sure you have a spare set of batteries with you when you go out with it .
Look forward to seeing your results.
 neilt3's gear list:neilt3's gear list
Minolta DiMAGE 7 Minolta DiMAGE 7Hi Konica Minolta DiMAGE Z5 Konica Minolta DiMAGE A2 Konica Minolta DiMAGE A200 +68 more
