Blue Spruce Forest aka Frozen Soap bubble
Rodger in Edmonton
Rodger in Edmonton Veteran Member • Posts: 4,599
12
A fun winter macro exercise - the patterns are temperature and humidity dependent.
This was done at about - 20 C
Cheers
Best Regards, Rodger
Save Lives - Be an Organ or Stem Cell Donor.
Quaecumque vera
DNSJR
DNSJR Veteran Member • Posts: 6,508
Re: Blue Spruce Forest aka Frozen Soap bubble
simply outstanding Rodger!
DNSJR
 DNSJR's gear list:DNSJR's gear list
Sony a6300 Sony E 50mm F1.8 OSS Sony E 35mm F1.8 OSS Sony FE 90mm F2.8 macro Sony E 18-135mm F3.5-5.6 OSS +3 more
Rodger in Edmonton
OP Rodger in Edmonton Veteran Member • Posts: 4,599
Thank you for the kind words and Merry Christmas D, the frozen bubbles have been making the macro rounds - they are quite easy. The morning sun is the holy grail since the bubble crystals will break up the spectrum.
Give it a shot - its quite fun - here I used a flash shooting back through the bubble - back light works well..
Quaecumque vera
Ernie Misner
Ernie Misner Veteran Member • Posts: 9,506
Very, very nice macro photography Rodger!  Did you freeze your fingers?
Cheers
Ernie Misner
http://www.flickr.com/photos/erniemisner/
Light pollution does not only erase our view of the stars. Scientific evidence suggests that artificial light at night has negative and deadly effects on wildlife, including amphibians, birds, insects, and mammals. ~ Bin Chen
 Ernie Misner's gear list:Ernie Misner's gear list
Nikon Z6 Nikon Z7 II Nikon AF-S Nikkor 24-70mm f/2.8G ED Nikon AF-S Nikkor 50mm F1.4G Nikon AF-S Nikkor 70-200mm F4G ED VR +5 more
Rodger in Edmonton
Cheers
Thank you kindly Ernie... almost - it was pretty freakin' chilly and the fingers were like ice but then I saw my bigger gloves could operate the camera. I only have to set the focus the use a 2 s delay on the shutter button.
So the first round the fingers were freezing but the 2nd was much better.
The real deal is a bubble backlit by sunrise because the water crystals will break the light spectrum up and it has a rainbow effect
Quaecumque vera
Ernie Misner
Cheers
Thanks, that was brilliant my friend.
Ernie Misner
jmiller1948
jmiller1948 Senior Member • Posts: 1,173
Amazingly Beautiful!
Astounding!  Did you alter the color in post?
 jmiller1948's gear list:jmiller1948's gear list
Nikon D850 Nikon AF-S Nikkor 16-35mm F4G ED VR Nikon AF-S Nikkor 70-200mm f/2.8G ED VR II Nikon AF-S Micro-Nikkor 105mm F2.8G IF-ED VR Nikon AF-S Nikkor 24-120mm F4G ED VR +8 more
Rodger in Edmonton
Re: Amazingly Beautiful!
Thanks JM,
Yes, I did a series of test shots with gel on flash  and colored backgrounds but the effect was the same , so I then did them in white light / Speedlight only rather than fixing gels to the Speedlight as white can be changed in post.
Now I have a Lume Cube Panel Pro so I can put the desired color SOOC.
As noted , teh real magnum opus with these is natural sunlight at low angle.
It gives a golden  kaleidoscope look with each ice facet breaking the spectrum.
I tested many colors of gels and backgrounds but blue and white seemed to work best w/o direct sun.
On FB Macro there are many examples - its an easy one.
Quaecumque vera
jmiller1948
Thanks for the info, Rodger.
