Best Lens for Sports Photography
Started 4 months ago | Questions
dwmcreative Forum Member • Posts: 73
I have a Fuji XH2s. I need to take photos for a basketball tournament at my job in January (I work at a high school). I have a lot of Fuji lenses but I don't think I have anything that is amazing for sports. What is the best lens you'd recommend for sports? I have a 90mm f2 but unfortunately I've missed a lot of shots due to the lack of zoom capability (That said when the subjects are at the right distance the shots are great). Any recommendations would be greatly appreciated. I tested out the new Fuji f4 18-120mm but I don't think there is enough light there and when I bump up the ISO it's pretty grainy. Hoping someone has a better recommendation! Thanks
 dwmcreative's gear list:dwmcreative's gear list
Fujifilm X100V Fujifilm X-H2S Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm XF 10-24mm F4 R OIS Fujifilm XF 56mm F1.2 R +3 more
Powerdoc Veteran Member • Posts: 3,941
Re: Best Lens for Sports Photography
For sports the best lens is the 50-140 m F2,8.
It's all about photography
 Powerdoc's gear list:Powerdoc's gear list
Fujifilm X-T1 Fujifilm X-H2S Fujifilm X-H2 Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm XF 27mm F2.8 +13 more
GMacF Contributing Member • Posts: 999
IMO there is only one lens for that particular job and it's the 50-140, nuff said.
For sports, the photographer (shooting Fuji in this instance) should have at least two lenses - 50-140 and one of the long telephoto zooms - be it the 100-400, 150-600 or even the Tamron 150-500.
The latter three would not be ideally suited to indoors so that leaves 50-140. Luckily it's one hell of a lens!
 GMacF's gear list:GMacF's gear list
Fujifilm X-E3 Fujifilm X-H2S Fujifilm X-T5 Fujifilm XF 27mm F2.8 Fujifilm XF 10-24mm F4 R OIS +9 more
RodandEva Regular Member • Posts: 309
Indoor sports or low light, definitely 50-140 2.8
longer reach the 100-400 or 70-300
the 50-140 is probably the best option paired with a teleconverter for more reach
 RodandEva's gear list:RodandEva's gear list
Nikon AF-S Nikkor 17-35mm f/2.8D ED-IF Nikon AF Nikkor 85mm f/1.4D Nikon AF-Nikkor 80-200mm f/2.8D ED Canon EOS 40D Fujifilm X-T2 +16 more
Peter Foiles
Peter Foiles Senior Member • Posts: 2,389
Because you work at the HS I suspect you may have court side access. If you are that close the suggested 50-140 may still be too tight if you are shooting from under the basket for example. In that case the 16-55 may work for you.
 Peter Foiles's gear list:Peter Foiles's gear list
Sony a1 OM-1 Fujifilm X-H2S Fujifilm X-H2 Sony a7R V +23 more
Tim van der Leeuw Senior Member • Posts: 1,364
Depending on budget and how much reach you need:
  1. 50-140mm f/2.8 -- Relatively fast lens, fast AF.
  2. 200mm f/2.0 prime -- Crisp and sharp, fast AF, but less flexible as it's not a zoomlens
If you're still battling with noise in the images, try DxO for DEEPPrime noise reduction as first step in your image post processing (assuming you shoot in raw format). Otherwise try Topaz Denoise or Topaz Photo AI which can also remove noise from JPEG files.
 Tim van der Leeuw's gear list:Tim van der Leeuw's gear list
Canon EOS M5 Fujifilm X-H1 Fujifilm X-T3 Fujifilm X-H2S Sigma 2x EX DG Tele Converter +17 more
Craig268
Craig268 Senior Member • Posts: 2,005
For basketball (as with many sports) you'll need also need some shorter focal lengths.  For zooms the XF16-55 paired with the 50-140 should work well.
If faster glass is desired, many options exist with primes.
 Craig268's gear list:Craig268's gear list
Fujifilm X-T1 Fujifilm X-T10 Fujifilm X-T4 Samyang 85mm F1.4 Aspherical IF Fujifilm XC 16-50mm F3.5-5.6 OIS +11 more
Samuraidog Senior Member • Posts: 1,672
The 200mm f2 would be amazing if it fits the budget.
 Samuraidog's gear list:Samuraidog's gear list
Fujifilm X-T30 Fujifilm X-H2S Fujifilm XF 35mm F1.4 R Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm XF 27mm F2.8 +13 more
biza43 Forum Pro • Posts: 15,074
Are on the sidelines, or below the basket? Do you need to cover both near and far? If yes, you can get a suitable f/2.8 zoom, or a shorter and longer primes.
www.paulobizarro.com
http://blog.paulobizarro.com/
 biza43's gear list:biza43's gear list
Fujifilm X-T3 Fujifilm X-T4 Fujifilm XF 16mm F1.4 R WR Fujifilm XF 70-300 F4-5.6 R LM OIS WR Fujifilm XF 33mm F1.4 R LM WR +1 more
johncecilian Senior Member • Posts: 1,123
Fits the budget is a funny comment since the poster said he worked in a high school, If he can afford a $5000 Fuji lens for some high school sports action, well, I would like a job at that high school.
 johncecilian's gear list:johncecilian's gear list
Fujifilm X-T5 Carl Zeiss Touit 1.8/32 XF 90mm +1 more
OP dwmcreative Forum Member • Posts: 73
I should clarify that I'm a bit of a hobby photographer and I'll pay for the lens myself
bobby350z Senior Member • Posts: 1,621
For Basketball??
baobob
baobob Forum Pro • Posts: 18,248
I use the excellent XF 50-140mm f 2.8 with the XH2s with great success
In most locations indoors I use ISO 1600 or 3200, sometime 6400 when light is a bit dim.
Sony RX100 Panasonic ZS200 Fujifilm X-H2S Fujifilm X-H2 Fujifilm XF 35mm F1.4 R +16 more
baobob
I also use my Viltrox 85mm f 1.8 when light is too dim
With the XH2s AF is nor a Ferrari but decent for the job anf 1.8 allows to get enough light at reasonable ISO setting
For Basketball??
Well I recommended that lens only for fast AF and wide aperture which would allow for lower ISO thus less noise.
Not specifically for this sport.
I guess though that if it'll work for anyone depends on distance to the action and if they can use the lens on a 2nd body or not -- in this case not very likely indeed.
And disclaimer: I do not own this lens myself either.
baobob
In my experience for handball or frisbee the FL I most use is around 70 to 80mm plus 100 to 120mm for detailed expression
yes a second body with aWA zoom is an asset to shoot the whole game (16 to 40mm FL)
casey1823
casey1823 Senior Member • Posts: 1,858
A lot of good comments. Here's my take. The 50-140 is versatile but if the gym is poorly lit, then I'd rather use the 90 & 50 F2.
I actually like shooting better with my primes as I tend to focus more on just getting the action. The zoom is nice but I find I spend time zooming in and out and I tend to miss some shots.
The 200 F2 is my favorite lens, but it's a little long inside a gym. If the gym has a larger area at each end, then it can be ok. I use it in volleyball but I really concentrate on getting more close-up emotions of the players. I tend to use a monopod if possible with the 200.
 casey1823's gear list:casey1823's gear list
Fujifilm XF 200mm F2 Fujifilm X-T4 Fujifilm X-H2S Fujifilm XF 50-140mm F2.8 Fujifilm XF 16mm F1.4 R WR +6 more
nnowak Veteran Member • Posts: 9,082
I will agree with all of the other posts that the 50-140mm f/2.8 is a fantastic lens and probably your best option.  However, we should probably back up a bit....
Are you just covering the home team, or are you going to be tasked with photographing every team and every game?  Do you need to get action photos of every player on the team, or just a few key shots for an article?  Are the photos going to be printed for display in the halls of the school, or will they be reduced for use on the school website.  Will you be courtside or in the stands?  If you are courtside, will you be able to move around to different locations throughout the games?
Define the expectations and deliverables first.  If you need to document everything and everyone, you probably want to be mid-court with the 50-140mm f/2.8.  If you just need a couple of key shots, you could use a shorter and brighter prime under the basket. If the photos are just going on the school website, don't be afraid to use a wider lens and then do some extreme cropping.
Looking at your current gear list, you could cover a lot with just the X-H2S + 90mm f/2.0 alongside your X100V.
DDaugherty Junior Member • Posts: 31
It depends on where you are at.   If you are under the basket to one side, you can shoot the entire game with one of the faster 35mms (effective 50mm) with some cropping but you will probably want something to cover the defense on the other side unless you want to alternate what you cover during the game and even then it can be hard to get faces on defense unless you are at the opposite end.  The 40-150mm is the option but f/2.8 at 1/1000 can be an issue in darker gyms.   If you are somewhere up top and middle of court with good mobility, the 200mm f/2 could be fantastic based on the size of the gym. Depending on budget vs. scope of images you need, I would try to field two bodies, one with a fast prime for under the basket, or other court level positions and the 40-150mm or 200mm f/2 to grab defense shots down the court.
G3_4_ME
G3_4_ME Regular Member • Posts: 355
The 90f2 is my goto action/sports lens.  I initially got it to shoot my son playing indoor hockey in municipal arenas which can have poor lighting.  I’ve used it to capture hundreds of soccer, water skiing, dog agility and more.  If you can make the focal length work, the 90f2 delivers in spades - it’s one of the best Fuji primes.  Fast focusing, can get a bit wet and  amazing image quality.
Marc
 G3_4_ME's gear list:G3_4_ME's gear list
Fujifilm X-H2 XF 90mm Fujifilm XF 18mm F1.4 R LM WR Fujifilm XF 33mm F1.4 R LM WR
