K3mk3 XS/1.7X crop pics.
joelbolden Regular Member • Posts: 195
I've been leaving the camera in this mode for the last week. There definitely seems to be some AF improvement also.
 joelbolden's gear list:joelbolden's gear list
Konica Minolta DiMAGE Z6 Konica Minolta DiMAGE A2 Fujifilm XP120 Pentax K20D Pentax K-7 +16 more
kypfer Contributing Member • Posts: 985
Re: K3mk3 XS/1.7X crop pics.
Nice pix
I had a play with this feature for the first time a day or two ago, indoors under controlled lighting on a tripod with a static subject, and there certainly does seem to be slight differences between the resultant JPGs.
I've put Crop Mode onto my Control Panel so I can access it easily and will have a more in-depth assessment next time I'm out and about.
The only reservation I have is, if I'm in Crop Mode and a subject turns up that is "too close", will I have time to revert to "Normal" … I'm thinking remain in "Normal" and only choose Crop for distant subjects that I'd be cropping anyway, then revert immediately … just got to get into the habit of using the new feature to advantage
 kypfer's gear list:kypfer's gear list
Pentax *ist D Pentax *ist DS Pentax *ist DL2 Pentax K200D Samsung NX5 +7 more
ozdean
ozdean Forum Pro • Posts: 28,665
Yes it certainly is confining the light onto the sensor to within the crop area which has to be a good thing.
Regards Dean - Capturing Creation
N.B. All my Images are Protected by Copyright
 ozdean's gear list:ozdean's gear list
Pentax MX-1 Pentax K-5 IIs Pentax K-3 Mark III Pentax smc DA* 55mm F1.4 SDM Pentax smc DA 15mm F4 ED AL Limited +14 more
