I tried to clean my Fuji X-S10 sensor and made it much worse. Did I also break something?
rbrown97 New Member • Posts: 4
I tried to clean the sensor on my Fuji X-S10 using the Pentax Sensor Cleaning Kit (https://www.amazon.com/dp/B000QUYERE?psc=1&ref=ppx_yo2ov_dt_b_product_details). In terms of removing dust, I completely failed. There is a lot more dust on the sensor now than before. I will try to wet clean it using this next (https://www.amazon.com/dp/B01B0TX6UA?psc=1&ref=ppx_yo2ov_dt_b_product_details).
I'm more concerned about something else though. The pictures below show test frames to see the sensor dust. The first one is after I used the Pentax the first time. The second one is after I used the Pentax again. And then the third one is after I used the Pentax a third time.
I know it's hard to see without being able to flip through them, but the dust pattern is essentially the same, but shifted slightly between all the pictures. Between first and second, the pattern shifts down and a little to the right. Between second and third, the pattern shifts up and left. But there is still a difference between the first and third patterns.
First question: what happened? Did I push to hard with the Pentax and somehow drag the glass covering the sensor, shifting it slightly each time? Or did something else happen? Has anyone seen this before?
Second question: is this a problem? If the glass covering the sensor was shifted slightly, would that affect my image quality at all?
 rbrown97's gear list:rbrown97's gear list
Canon G5 X II Fujifilm X-S10 Fujifilm XF 18-135mm F3.5-5.6 R LM OIS WR
Morris0
Morris0 Forum Pro • Posts: 32,181
Re: I tried to clean my Fuji X-S10 sensor and made it much worse. Did I also break something?
11
Everything is probably fine.  Do the wet cleaning and with the amount of dust you have it may take a few passes.
What you broke is probably a sweat!
Morris
Fujifilm X-T3 Fujifilm X-H2S Canon EF 200mm f/2.8L II USM Nikon AF-S Teleconverter TC-17E II XF 90mm +11 more
Ringwraith69
Ringwraith69 Veteran Member • Posts: 3,407
Morris
Agreed! And for what it's worth, I highly doubt it's even possible to 'drag' the glass covering the sensor by applying some force to it. It's an integral part of the image sensor, not just a loose piece of glass mounted above the sensor. If you applied enough force to break the glass loose from the sensor, you would have basically wrecked the camera and that doesn't seem to be the case here.
(We are only immortal for a limited time)
 Ringwraith69's gear list:Ringwraith69's gear list
Sigma DP1 Fujifilm FinePix X100 Fujifilm X-S1 Sony RX10 II Sony RX10 IV +42 more
Jeff Biscuits Senior Member • Posts: 1,167
I confess I’ve never come across a cleaning kit anything like that Pentax one.
My sensor cleaning hierarchy goes:
1. Blower; then if there are still marks,
2. Dry wipe with a swab as per your second link; then if there are still marks,
3. Wet wipe with same; then if there are still marks something’s probably wrong.
 Jeff Biscuits's gear list:Jeff Biscuits's gear list
Ricoh GR Digital II Ricoh GR Digital IV Fujifilm X20 Fujifilm XF10 Ricoh GR IIIx +14 more
OP rbrown97 New Member • Posts: 4
Thanks for the comments and advice. Just a quick update, I used the wet cleaning and it was much easier and more effective than the Pentax. Sensor is pretty much pristine now. I must have done something wrong with the Pentax but I'm not sure what. Anyway, the wet cleaning works great for me.
If I did damage my sensor, I haven't noticed anything obvious yet. Anyone know what symptoms I might see? Is it just glass in front of the sensor, or also some filters or special coatings?
Thanks again. I appreciate all the responses.
a_c_skinner Forum Pro • Posts: 13,047
If you damaged the camera the first, very first, look at the first image would immediately say to you that it was wrecked and needed repair.  Don't worry.
I hate sensor cleaning.
Andrew Skinner
Fujifilm X-T2 Fujifilm X-E3 Fujifilm X-H2 Fujifilm XF 35mm F1.4 R Fujifilm XF 14mm F2.8 R +7 more
baobob
baobob Forum Pro • Posts: 18,248
With IBIS be careful
https://www.fujirumors.com/sensor-cleaning-and-ibis/
Bob
Sony RX100 Panasonic ZS200 Fujifilm X-H2S Fujifilm X-H2 Fujifilm XF 35mm F1.4 R +16 more
Night Pixel
Night Pixel Contributing Member • Posts: 976
This type of sticky gumball product has been around for a long time. It has generated some controversy. It can be very sticky and I would not use it on an IBIS camera.
Stick with traditional wet swabs and you will get better results.
Here is an 8 year old review of the Sensor Gel Stick which is the same product:
**** REDACTED ****
 Night Pixel's gear list:Night Pixel's gear list
Sony RX10 IV Fujifilm X100V Fujifilm X-H2 Fujifilm XF 80mm F2.8 Macro Tamron 150-500mm F5-6.7 Di III VC VXD +4 more
