Weird behavior - quick refocus when zooming DA*16-50/2.8 PLM on K-3 III
MarBa Senior Member • Posts: 1,038
Hi everyone,
I noticed that sometimes when zooming with the DA*16-50 lens, the K-3 III camera would activate AF (red light turns ON for a short moment) and refocus the lens quickly back and forth (very obvious in the OVF!). This happens always at the same focal length when zooming in or out .. but it does not seem to be always the exact same focal length on different occasions (not 100% sure about that). Interestingly, the "MF" symbol also appears in the viewfinder at the same time when AF is activated. I tried to clean contacts on the lens and the camera but it still happens. But often .. a bit later in the day .. it just stops doing that ... so it's weird, not perfectly reproducible.
Anyone noticed something like that? With this combination, or other lenses/cameras?
Best,
M
 MarBa's gear list:MarBa's gear list
Pentax K-1 Pentax K-3 Mark III Pentax smc FA 31mm F1.8 AL Limited Pentax smc FA 43mm F1.9 Limited Pentax smc FA 77mm 1.8 Limited +6 more
Pentax K-3
Kobie M-C
Kobie M-C Contributing Member • Posts: 701
Re: Weird behavior - quick refocus when zooming DA*16-50/2.8 PLM on K-3 III
MarBa wrote:
Hi everyone,
Best,
M
I've noticed it on my 55-300 PLM on occasion when zooming. It'll re-focus on its own. Not all the time though. I haven't noticed in the 16-50 PLM. I use the lenses differently though (I don't zoom after focus with the 16-50). I'm guessing that it's something with PLM behavior.
I am not a Pentax insider. I just have a unique way of gaining insight.
 Kobie M-C's gear list:Kobie M-C's gear list
Pentax K-30 Pentax K-3 Pentax K-3 Mark III Pentax smc DA 18-135mm F3.5-5.6ED AL [IF] DC WR Pentax smc DA 50mm F1.8 +6 more
KPM2 Senior Member • Posts: 2,076
Hello MarBa
MarBa wrote:
Hi everyone,
Best,
M
I have not this lens and also not this camera, therefore I need your help for to answer your question:
1.) You are at 16mm and focus - now you switch off the camera - than you zoom to 50:
Is the 50mm position very unsharp now ?
2.) you switch on the camera - get the 50mm position now suddenly in focus ?
When you think that the camera use a focusing:
start again with step 1.)
and than: cover the lens with the cap, switch than on the camera, wait a little bit, switch off the camera - put off the lens cap: is the 50mm position suddenly sharp ?
My 55-300mm PLM must change the position of the focusing lens group, when I zoom, for that the lens is able again to focus from infinity to the min. distance in this other zoom position. This happens not mechanical by changing the zoom position.....it is done by the PLM itself, who move it's focusing lens group to a new position. But it do this so good, that the lens looks like a parfocal lens. Maybe your lens do the same, and all what you see is that after this generell position change (do to a zoom position change) your camera do a new focusing at specific changes for to stay very precise on the focus you had before you zoomed.
best regards. KPM2
