Konica Minolta Dynax/Maxxum 5D (2005); RTC-battery..? (Real-Time-Clock battery). Condensator..? Loca
Arnstein Bjone
Arnstein Bjone Forum Member • Posts: 91
I just bought this camera* for fun/comparison. It doesn't hold the time and date (of course), but I was hoping to fix that.
Service manual: http://www.bjone.no/Konica_Minolta_Dynax_Maxxum_5D_service_manual.pdf
*) 35 USD for Camera + AF DT 18-70mm + Tamron 70-300mm f4-5.6 AF LD + flash Minolta Program 3600 HS D :-).
No charger, but a new batteryplate (3 USD) for my Andoer 4-channel charger is on its way, + two Digieye NP-400 batteries (15 USD)
 Arnstein Bjone's gear list:Arnstein Bjone's gear list
Canon EOS 5DS R Canon EOS 90D Canon EF 300mm f/2.8L IS II USM Sigma 24-105mm F4 DG OS HSM Canon EF 11-24mm F4L +25 more
FrancoD Forum Pro • Posts: 19,261
Re: Konica Minolta Dynax/Maxxum 5D (2005);
You can see where is located in the &D here :https://www.pbase.com/pganzel/a_look_inside_the_maxxum_7d
Maybe it is around there in the 5D too.
BTW, I had a look into that 5D service manual but I could not find a single reference to that internal battery.
Arnstein Bjone
OP Arnstein Bjone Forum Member • Posts: 91
Thanks a lot. That will probably help me.
Any idea where to find that (main)board..? I once fixed something "deep inside" a shirt pocket camera, but I'm far from familiar with this kind of work.
Is it this one? (purple circle). Inside the back panel, I assume..?
I never opened one of those cameras but I do think that you have the right board there.
Odd that I cannot find any reference to it on the Net.
A lot of  (all ?) cameras at the time had a similar internal battery . I think now they all have a supercapacitor.
