Tokina Lens correction data on Canon R bodies ?
Photato
Photato Veteran Member • Posts: 3,153
Planning on buying the Tokina atx-i 11-16mm f/2.8 CF (latest version 2019)
But the CA seems bad.
So the only way I could go ahead with it is IF Canon R bodies can do CA correction, mainly for video.
Does any one know if newer Tokina lenses correction data plays well with Canon R bodies ?
TIA
 Photato's gear list:Photato's gear list
Panasonic LX100 Canon EOS M Canon EOS M6 Canon EOS M6 II Canon EOS R10 +22 more
Photobygms
Photobygms Regular Member • Posts: 296
Re: Tokina Lens correction data on Canon R bodies ?
Only the  Canon lenses do have profiles available.  third party lenses are do not have profiles available. You will have to use profiles for those lenses with other (photo edit) programs. like photoshop or similar
.....Of course I'm out of my mind. It's dark and scary in there.....
Mostly analog at: https://www.flickr.com/photos/photobygms
Digital and some analog at: https://www.instagram.com/photobygms/
 Photobygms's gear list:Photobygms's gear list
Canon PowerShot SX740 HS Canon EOS 5D Mark IV Canon 6D Mark II Canon EOS R Canon EOS RP +46 more
Photato
OP Photato Veteran Member • Posts: 3,153
Not true.
My Sigma 100-400 lens has corrections which my R10 body can apply in-camera.
I’m not sure if is the same with Tokina lenses, but would like to know before buying that lens.
Photobygms
Photato wrote:
Not true.
As far as I know it's a trick that Sigma figured out with the EF Lenses in their Global Vision line (A,C and S series), But there are no profiles in camera for Sigma or other third party lenses. Canon has never build third party corrections in in their firmware for the various Eos cameras. Sigma lenses use a generic profile of a profile from an existing Canon lens
I own two Sigma Global Vision lenses (150-600 and 100-400) and there are some corrections available but also issues with those if you enable all options, If I remember correctly even Sigma has stated to not use Lens corrections like Lens abberation correction
Edit:
All recent Canon Eos DSLRs have profiles for many different Canon EF lenses standard, but you still have to or can  add other Canon EF lens profiles with their Lens registration tool program and there are no third party profiles available with that tool.
Other side note: Canon RF lenses do have their own profile (in lens firmware) and will communicatie/upload that to a Canon Eos R series body, R series body do have many EF lens profiles like the DSLRs loaded in their (in camera) firmware. EF lenses don't upload their profiles to the camera, EF lenses are not that sophisticated or smart like the RF lensesĀ
Photato
Photobygms wrote:
Photato wrote:
Not true.
Edit:
I think, for a while now, newer lenses (8 years back?). Started incorporating their lens corrections profile with the Exif and newer cameras bodies started reading them.
Those profiles can also be preloaded to some cameras.
