Canon EF 50mm f/2.5 Compact Macro Puzzle
Edymagno Veteran Member • Posts: 3,695
I am looking for a used copy of this lens to scan my 35mm slides and negatives.
The lens picture and videos clearly show this lens with barrel extended up to 1:1 magnification.
In my book 1:1 magnification is real size (meaning I can fill my R5 sensor with a 35mm negative)
This seller says the lens doesn't achieve 1:1 magnification. A Youtuber says the same thing.
So, why does this lens shows 1:1 magnification on the barrel?
Thanks in advance
Edu
 Edymagno's gear list:Edymagno's gear list
Sony RX100 III Sony a6000 Canon EOS R5 Sony E 30mm F3.5 Macro Sony E 50mm F1.8 OSS +6 more
Canon EOS R5
OP Edymagno Veteran Member • Posts: 3,695
Re: Canon EF 50mm f/2.5 Compact Macro Puzzle
Further research here and else, answered my question.
Simple as this lens was designed to be matched with Canon Life size Converter.
This lens is almost prehistoric!
Best
GammyKnee Contributing Member • Posts: 985
Best
It's definitely from a bygone age, but it's still a surprisingly good lens. I had one for a while and though its bokeh was not the best I found it to be trustworthy, with accurate and consistent AF and of course good sharpness.
 GammyKnee's gear list:GammyKnee's gear list
Canon EOS R Canon EOS R6 Canon EF 85mm F1.8 USM Canon EF 135mm F2L USM Canon EF 17-40mm f/4.0L USM +4 more
Best
I found a very well kept used EF USM 100 Macro and went for it. I could use it too as a portrait lens and despite not an RF, I expect it to feel more contemporary and better matched to the R5. Paid only a third of the price of a new current EF 100 Macro L.
Best
