OM-1 + M.Zuiko 100-400mm F5.0-6.3 ---- Is My Lens Copy Soft?
OP Co172 New Member • Posts: 22
Re: OM-1 + M.Zuiko 100-400mm F5.0-6.3 ---- Is My Lens Copy Soft?
tammons wrote:
Co172 wrote:
@tammons
I forgot to ask... so based on your comments, you agree that the sharpness is not great? Did you see any noticeable difference between the 2 photos or they were both the same to your eyes?
They are very close. I think the 2nd copy is slightly softer.
@tammons
Appreciate this back and forth!
These were all shot with e-shutter (it's all I use on the camera - love the fast readout).
For each focal length (100, 200, 300, 350, 400mm), I shot wide open, 1 stop and 2 stops down with 3 timed captures for each. I used both C-AF and S-AF modes for each of these configurations. Obviously, I only shared the 400mm, 1 stop down, S-AF pictures, but they are very representative of the others.
Regarding the sharpness, I think I agree that the 2nd copy is slightly less sharp (or has less contrast?), but probably not by enough to notice the difference in normal use.
@finnan haddie
Understood that there is always diffraction.  In my experience it wouldn't be easy to visually pick out until the aperture is even smaller. The review for the lens linked here didn't comment on visible diffraction until F16: https://mirrorlesscomparison.com/micro-four-thirds-lenses/olympus-100-400mm-vs-panasonic-100-400mm/#quality
That said, photographing stuffed animals is a bit different than a lens chart!  Your comment is appreciated.
 Co172's gear list:Co172's gear list
Panasonic FZ80/FZ82 OM-1 Olympus 100-400mm F5.0-6.3 IS
finnan haddie
finnan haddie Contributing Member • Posts: 659
Co172 wrote:
@finnan haddie
Diffraction doesn't "pop in" at some aperture or another, it just reduces maximum sharpness of a lens when stopping down past about f/8. Compare the MTF curves for different pixel densities. For more background information I recommend https://www.lensrentals.com/blog/2013/03/overcoming-my-fentekaphobia/
 finnan haddie's gear list:finnan haddie's gear list
Panasonic Lumix DMC-GM5 Olympus Zuiko Digital ED 14-35mm 1:2.0 SWD Olympus M.Zuiko Digital ED 75mm F1.8 Leica Nocticron 42.5mm Panasonic Leica DG Summilux 15mm F1.7 ASPH +95 more
Brandon birder Veteran Member • Posts: 5,314
Co172 wrote:
Schoonderwoerd wrote:
Alltough not having your gear I had similar experience with my Panasonic G9 + PL 100-400.
Looking at your info, for me at 400 mm (800 FF) a shutterspeed of 1/800 is to slow. My own movement, a branch that maybe moves a little by the wind etc. can already give some motion blur.
Try the combo with a higher shutterspeed and for test sake forget/ignore a higher iso/noise. For me this was a game changer.
Wonderful shots you've got there!
Oh, I do agree that higher shutter speed will net sharper images in the case of moving birds. That said, when I rattle off 50+ shot bursts of a perched bird at 1/800, I'd expect to get a few sharp ones in the lot, but I'm seeing none. And I have a slew of tripod shots of stationary objects that look soft as well. Just not sure where my expectations should be tempered. Your shots here leave me wanting more!
When a wren is singing it vibrates continuously and so you may just need a higher shutterspeed.
Cheers, Brandon.
Olympus OM1, EM10 mII, Sony RX10 M4, RX100 M7
Nikon V1,V3, D500, D810
FlickR Photostream
http://www.flickr.com/photos/brandon_birder/
 Brandon birder's gear list:Brandon birder's gear list
Olympus E-M1 III Olympus M.Zuiko Digital ED 60mm F2.8 Macro Olympus 12-100mm F4.0 +1 more
