OP
Co172
New Member
Re: OM-1 + M.Zuiko 100-400mm F5.0-6.3 ---- Is My Lens Copy Soft?
Hi Dan,
Thanks for circling back!
JoiseyM43 wrote:
Colin,
I’m sorry I was slow to respond.
I believe that I exported raw files to jpg using Dxo photolab. It does apply a base level of sharpening unless you turn off the base adjustments that it makes.
Rightio. I also use PL6. After setting up my camera and lens, the default adjustments it makes for me are: DxO Smart Lighting, RGB White Balance, Color Rendering, Lens Sharpness, Chromatic Aberration, Distortion, and I believe DxO Denoising Technologies (but defaults to High Quality rather than DeepPRIME). Applying all of these does seem to "tidy" the picture up quite a bit for me. But then developing the JPEGs does take quite some time on my machine. especially with DeepPRIME.
The first picture I do believe that I lifted the exposure a bit. I included it because it had something in its beak and it appeared to be interesting.
Yes I think the bird detect picked the bird on the left in the third picture. However, I don’t think there is that much of a difference in sharpness between them.
The new firmware came out literally hours before. I installed it and ran right out to test it as I have been questioning the sharpness of the lens. I took a hundred or so shots, many of them in small bursts. I didn’t really intend to do anything with them, so I didn’t do any processing on them other than what DXO did on export that is.
Sounds just like what I would do.
Interestingly enough, I’ve been using that folder of images to test my initial installation of Photo Mechanic Plus for culling and cataloging images. PMP renders images from raw files using the imbedded jpg image and does no processing. Almost all of those images are sharp. I can share some as exports straight out of PMP if you’d like. I don’t see any difference between them and the exports from DXO.
Similarly, I had taken some shots back in the summer of squirrels in the yard. The yard has decent shade coverage and the little buggers were about 60 feet away. The images are like the one you had in your OP. Days later there was one in the front yard in a bush eating berries. I was closer and It was in direct sunlight. You can count his whiskers. Could share those too if you’d like also from PMP exports.
I also have several squirrels, but not much sunlight ;(
In the same time period, I shot some high school baseball in bright sunlight and was quite pleased with the results.
The take aways for me are, keep the firmware up to date, pay attention to settings, pay attention to set up and technique, get as close as you can, expect your best results in good light.
My speed in getting the needed settings applied for the shot are certainly improving and sunlight/good weather will certainly net better results. I just hope my expectations didn't overshoot reality.
Good Luck!
Dan
Really appreciate the input from friendly folks like you (and the others on this thread). I'll try to get back an update my findings later on.
