lokatz
Re: OM-1 + M.Zuiko 100-400mm F5.0-6.3 ---- Is My Lens Copy Soft?
Schoonderwoerd wrote:
It is not my intention to insult you, but to me this photo is not sharp or a good example what can be achieved with this lens.
Or your copy is not so good as mine or perhaps it is the relative slow shutterspeed.
Concerning the shutterspeed I agree to disagree on this matter
I also suspect that my copy isn't the best around, so we can agree on that. (Fortunately, I have the 150-400, which gets preference anyway.) Consider the low light situation the shot was taken in, though.
Regarding shutter speeds, I don't mean to insult either, but watch some videos from renowned wildlife photographers (Steve Perry, for example, one of the Nikon "gurus", has a video specifically on this). You'll find yourself in a clear minority. Perched birds rarely make movements that cannot be frozen at 1/800s.
I'm glad that we agree on the 'no insult eachother part'. That's cleared.
Considering the shutterspeed, maybe I'm in the minority. The only thing I know that it works for me, and that it is not only (if so) movements from the perched bird, but also my little movement (I mainly shoot handheld). That being said I probably also have some nice shots with a slower shutterspeed but they are in the minority.
Maybe I'm wrong, but you can give it a try, shooting a series with a higher and slower shutterspeed. Your photo (handheld) was taken at 1/250 and I'm curious how it would have come out with 1/500, 1/640 or 1/800
We will never know for sure.
I've taken thousands (seriously!) tests shots of the same subject at various shutter speeds, all handheld as I rarely use my tripods, and I feel I have a pretty good understanding of what shutter speed to use in what situation. It all depends on the movement of the bird, though.
If it sits perfectly still, you're going to get a sharp image with a 400mm lens at 1/40s, even below that, just fine most of the time. (Consider that this requires only about 4-5 stops over the old "inverse of FL" rule. The OM-1 IBIS easily delivers that. Most good tele lenses do that, too.)
If the bird moves, it depends a great deal on the kind of bird. With large ones, 1/250s still cuts it in my experience, whereas this can be way too slow with a small bird that is always on the move. However, you may not have the luxury to go much higher unless you accept seriously high ISOs, and 1/250, even slower than that, can still be fine with a small bird. [Just FYI, I plan to start a new thread on this very subject later today.]
Anyway it was only my intention to give you a tip from what I experienced and not to start a discussion who is wright or wrong.
Fair enough and much appreciated.
In practice, shooting perched birds at 1/2000s+ means you either have to use very high ISOs, or you restrict yourself to bright sunlight. Pushing ISOs higher for fear of not getting the sharpest shot, or only shooting in bright light, both mean you're picking one poison over another.
I'm not sure about 1/2000s+ (this is a leap from your example shot taken at 1/250) why not 1/800 which you mentioned before as an example?
Well, you're the one who suggested that 1/800s is not enough. (It was actually the OP shooting at that speed, not me bringing it up.)
Anyway i agree about the 'poison' of higher iso hence noise.
To a certain degree noise can be 'solved' in PP where as a photo is unsharp, it cannot be fixed.
Did you ever try Topaz Sharpen AI? I think you're wrong when thinking sharpness cannot be restored, at least not to a degree. I am continually blown away by how well that software restores even seriously unsharp photos. There is a limit to everything, but still...
So it depends on the situation/object if I start with lower shutterspeed/lower iso or with a higher one. Am I able to check my results or is a once in a lifetime shot. In that case I would go for a sharper but maybe more noiser photo.
"Once in a lifetime" may be overly dramatic. However, I tend to do most of my bird shooting while traveling foreign countries, though, so if in doubt, I have to assume that I won't get another opportunity. Currently in Australia, then New Zealand, then Indonesia.
Anyway, I'll try to find a balance and try not to forget that we have a nice m4/3 platform, but iso wise and maybe resolving power wise, we are not shooting with FF cameras
[Well, here I will again refer to that other thread 'll start later. ;-)] I came to MFT from several FF bodies and realize this full well. Yet, I think the difference is often overestimated.
The bird box shot I shared was taken during a week during which I was constantly switching between my Canon R5 (FF) with the RF 100-500 lens and my OM-1 with either the Oly 300 f4 or the PanaLeica 100-400. In fact, I have taken this very shot and several similar ones with all three combinations. (If you'd like to know more, please take a look at this report on my website, but be warned that it is loooong.) The Canon and OM-1+Oly shots were pretty much at par, the OM-1+PL shots clearly not at the same level but still quite decent.
(By the way, I should have mentioned that the bird box shot was taken through glass at an angle, which won't help sharpness-wise. I remember this only now but should have told it to the OP.)
I am not overly concerned about ISO noise since removing it is so effective nowadays. (I started shooting at a time when this was WAY different...)
