OP
Co172
New Member
Re: OM-1 + M.Zuiko 100-400mm F5.0-6.3 ---- Is My Lens Copy Soft?
Hi Dan. Thanks for weighing in!! Agreed that technique is super important, especially for these long zoom, distant subject situations.
JoiseyM43 wrote:
Hi. I shoot with the same set up and found that my results have improved over time with practice and by learning from folks on this site.
It might not be the lens. Paying attention to settings might help.
Absolutely. I've studied the available settings thoroughly. I also spent a lot of time reading through preferred settings of others such as Mathieu over at Mirrorless Comparisons: https://mirrorlesscomparison.com/guide/om1-settings-birds
I believe I've tried most combinations.
Have you updated to FW 1.3? I took some bird shots the day I updated and got some fantastic shots, better than I had achieved in the past.
Yes! Upgraded to v1.3 right away, especially since OM seems to still be tweaking C-AF which I use mostly.
Do you have release priority turned on or off? Try turning it off.
I do have this set to OFF
What IS settings are you using?
In normal shooting, lens IS on and IBIS set to S-IS (auto) or S-IS1 (all direction). I have tried all other combinations with little change, but not under controlled conditions.
Are you stabilizing yourself when you set up for the shot.
Try breathing slowly and deliberately and consciously pressing the shutter release without jerking the camera.
I normally shoot from a monopod and have worked on breathing techniques for the past few years. When handheld, I try to use my environment to my advantage (like resting against the side of a tree).
Try electronic shutter or other shutter settings that help deal with shutter shock.
I only shoot with electronic shutter. That was one of the selling points for me on OM-1 - sensor readout time that was fast enough to avoid rolling shutter effects.
Try raising the shutter speed.
Understood. With M43 it's always a bit of a battle with available light and high iso. The bird example I posted was shot at 1/800 which could possibly have been higher, but the entire burst series of 30 shots ranged from soft to very soft, even when the subject wasn't moving.
Keep practicing and I think things will get better.
I will strive to do so!
Yes, post processing can save a shot that didn’t come out well, but i would prefer to get good results right out of the camera. The only way to gain comfort that you dont have a bad copy of the lens is to actually prove it. PP software doesn’t do that.
The controlled condition experiment on a tripod was my attempt to prove the copy was soft or not. Can you recommend additional testing that I can do?
Having said all that, this lens performs best in good light and when the shot is taken as close to the subject as possible. I would focus your next round of tests in as bright light as possible and on subjects closer than that bird was. Subjects can be anything.
Good Luck!
Much appreciated!!
Dan
