Re: IBIS good but over hyped
Gary from Seattle wrote:
Tom Caldwell wrote:
I think your comment on weather sealing definitely goes to OM-1; but you have left out one of the greatest advantages of Olympus/OMD gear, industry tops IBIS. The only real need for a tripod in this family of gear is for low light macro focus stacking or bracketing or for long duration astro images.
Canon R6II:
- Built-in image stabilization rated to 8.0 stops
the era of Olympus|OMDS wearing the IBIS crown has ended
Peter
Olympus made a rod for their own back when they based their claim for greatness of how good their IBIS was. It was a good selling point once but now that all cameras have IBIS its sales benefit has been neutered.
So IBIS is very useful but its benefit has been over-hyped to the point where the number of stops runs into crazy-land as if nobody can hold a camera steady and fast lenses have become a joke.
Not at all, Tom. Where IBIS really makes a difference is with long telephotos. In birding, one might shoot in good light and then the next bird will appear in shade. Great IBIS compensates on those images one otherwise messes up if the bird is sufficiently still.
Well before IBIS I had a bunch of Canon EF telephoto lenses and I really appreciated their lens-IS - they were virtually rock-solid when used their Len-IS was very good and tailored to each lens. I agree that IBIS must be very good for telephoto and for birding.
I did not say that IBIS was not useful. But there are some that think that their photography will fall in a heap if they do not have IBIS. That is the over-hyped bit.
The pious hope that IBIS will cure everything including capturing images whilst break dancing ...
Vast overstatement. Who here is suggesting that?
There are plenty of comments about the living breathing excellence of even more stops worth of IBIS. I was just being a bit theatrical .... sorry.
Looking forward for a claim of 20 stops when just 2 stops might be quite good enough.
2 stops would often not suffice to shoot a bird image. Even in mountain landscape or forest shots, I am comfortable going to 1/4 second standing in very low light.
Magnification is very close to 1:1.
In landscape it is often true that one needs to have an aperture of F6.3 to F8, so more demanding on SS.
An excellent proof - I take it that you will not be needing 20 stops worth ....
I say that in jest.
I have some Canon OIS binoculars which demonstrate the efficiency of lens IS in a dramatic way. Hold them up and find your subject matter - and then press the OIS button - the images just stop the slightest dither - I could not see how they could be made more stable than rock solid.
So I agree that IBIS is great, it technically allows every lens mounted to be stabilised even though with manual lenses there is a huge difference in the need for stabilisation between fast wide lenses and long slow lenses - especially when in indifferent light or stopped down.
If I remember right the Olympus 300/4.0 needed some support from in-lens stabilisation because the IBIS in Olympus camera bodies did not always provide enough amplitude to cover this movement in this excellent lens. It was probably the same reason why that other great (one of many) Olympus lens the 12-100/4.0 also performs so well with lens-IS.
Notably that latter lens kicks the IBIS facility off the G9 (no offence to Panasonic's IBIS) but the results are stable excellence nonetheless leaving a very stable lens-IS platform. Furthermore the 12-100/4.0 makes the GM5 an equally stable platform. I have bene very happy with what in-lens IS can do.
Therefore IBIS is good, but Lens-IS is not bad either. We just need to appreciate them for what they are and it is a pity that the hype of IBIS might mean that camera bodies without it are going to be very hard to sell.
