Satyaa
Re: The decision is about to be made, so speak now or forever hold your peace
Tommy S wrote:
I was looking for a second body to complement my R6 to stop juggling the lenses. I analyzed all Pros & Cons of entering the new MFT system. I think I did my homework well enough and I am not wrong to buy OM-1 with 12-40 and 40-150 F2.8 Pro lenses.
- Better F-speed for 200-300mm of FL equivalent (40-150 F2.8 vs EF 70-200 F2.8)
I do not understand that point. Wouldn't 150mm on m43 give you close to the same FOV as 200mm on APSC (R7)? What do you mean by F-speed?
I am going to keep R6 with EF 24-70 F2.8 for short distances and shallower DoF, I think 2 such different systems will complement each other much better than another body of Canon R system. I will also return to taking the camera with me on vacation. MFT knocks out FF in this area.
APSC ML bodies are not much bigger. Among FF 70-200/2.8 zooms, the RF version is the the lightest.
If I was in this situation with an R6 and wanting a second body, I would probably go with R7. You mention some disappointments in another reply above. I am not sure what that is.
I am open to your comment even if you think I suffer from GAS
The other thing I want you to consider is the high ISO performance. I often shoot up to 6400 on D7200 with 70-200/2.8. I am doing that with 40-150/2.8 on GH5M2 and I am not 100% convinced that IQ is comparable at higher ISO. I get the same f/2.8 exposure (with more DOF), the same 300mm FF FOV with lighter gear, but not the same ISO 6400 IQ. Coming from FF, you will probably see even more difference.
I don't know if OM-1 is one stop better than GH5M2.
All the best.
See my profile (About me) for gear and my posting policy.
