RF 100-500 bayonet mount change problem
kevinduell New Member • Posts: 7
I had to change the mount on my RF 100-500 as it was damaged - the lens would detach by itself.  Other than that the lens was working perfectly. I replaced the mount - an easy enough procedure just requiring one ribbon cable to be disconnected and then reconnected.  Now the lens does not communicate with the camera at all.  There is no error message, but I cannot set the aperture and the autofocus does not work.  I have tried reconnecting the cable but it is still the same.
Is there a secret reset to the lens that I don't know about?  Anyone got any ideas on how I should proceed.
 kevinduell's gear list:kevinduell's gear list
Sony RX100 V Olympus TG-5 Canon EOS R Canon EOS R5 Canon RF 100-500mm F4.5-7.1L IS USM +1 more
Will T
Will T Regular Member • Posts: 425
Re: RF 100-500 bayonet mount change problem
Photos of the lens apart might help!
Will T.
"Galleries don't hang DxO charts" David Hull
