Live view autofocus on Pentax cameras
KPM2 Senior Member • Posts: 2,076
Re: Maybe Catch In focus
Hello JeremieB
JeremieB wrote:
Yes it works very well, I used it with the old M* 300mm lens and I had good success rate with seagulls in flight so not bad Not as good as with AF lens but clearly much better than in pure MF.
Thank you for this info !
best regards  KPM2
OP mainoo Contributing Member • Posts: 592
KPM2 wrote:
Hello JeremieB
best regards KPM2
Thanks so much for this tip. When I was looking into the fantastic focus gimmickry on the Panasonic S1 family (pre-focus, etc) I wondered why this feature had not been implemented. I have the following questions:
My understanding is that this functionality is restricted to the viewfinder because it relies on PDAF and that functionality exists only in the viewfinder for most Pentax cameras. Since the K70 allows PDAF on the LCD, does catch in focus working live view on the K70?
The K3 iii is rather pricey - which sub 1000 Pentax cameras would have the best catch in focus implementation?
Does catch in focus work in burst mode?
Thanks very much.
Re: ... Zeiss ZF.2
KPM2 wrote:
BTW: about the K70 and how the camera make a picture when it is in LV:
https://www.dpreview.com/forums/post/66612619
maybe you don't like it !
best regards. KPM2
Thanks. you are right - I wouldn't like it.
Hello mainoo
mainoo wrote:
KPM2 wrote:
Hello JeremieB
best regards KPM2
Thanks very much.
The catch in focus use the centre AF point. When you half press the shutter release and the camera notice that this centre AF point is in focus, it show that in the OVF and you can do a picture, or when you fully press the shutter release button, the camera do at once a picture or pictures (when in series mode) when the center AF comes in focus . When the centre AF is or get out of focus, the camera do not or stop making pictures.
Therefore, with the catch in focus. it's good to have the AF button set to disable AF or AF only by the AF button, because than you are able to do pictures, even when the centre AF is not in focus (for example: you focus to your subject and than you recompose, and do to that the centre AF is now out of focus).
I don't think that the K70 has catch in focus in LV, but only users of this camera could give a right answer.
best regards. KPM2
JeremieB Senior Member • Posts: 2,041
KPM2 wrote:
Hello mainoo
mainoo wrote:
KPM2 wrote:
Hello JeremieB
best regards KPM2
Thanks very much.
There used to be a "bug" affecting some K3III (including mine), because of it you could select other AF modes than center spot in CIF with MF lens ! Like sel S and move the points around with the joystick.
That was super excellent, sadly they fixed it
I'm not sure about what you describe, but to do that I would just switch off CIF and consider the focus alert on center then recompose and that's all ?
The main interest of CIF in my opinion is that it triggers only when focus is acquired ? Maybe I miss something.
best regards. KPM2
 JeremieB's gear list:JeremieB's gear list
Pentax K-70 Pentax K-3 Mark III Pentax smc FA 50mm F1.4 Pentax smc DA 18-55mm F3.5-5.6 AL Pentax smc D-FA 100mm F2.8 Macro WR +9 more
MrB1 Contributing Member • Posts: 605
Re: Live view autofocus on Pentax cameras
mainoo wrote:
What unites the Fuji, the Panasonic and any Pentax camera I get is the tilt LCD. I shoot only using the LCD
Thanks in advance.
I don't understand why Pentax is part of the discussion if there is no need for the size, weight and extra complexity of a pentaprism and mirror.
Similarly. I don't understand why anyone would introduce the K-3III into the discussion when it has a fixed rear screen.
Philip
Hello JeremieB
JeremieB wrote:
KPM2 wrote:
Hello mainoo
mainoo wrote:
KPM2 wrote:
Hello JeremieB
best regards KPM2
Thanks very much.
about this
It takes time to go to the menu and disable the catch in, therefore this is a fast solution when you just use the catch in but you will deactivate it for that you can do the picture.
You can use it for both (normal focusing or as a trigger ) with your old manual lens and you must not always switch on or off the catch in in the menu, when you use the AF button.
best regards. KPM2
best regards. KPM2
MrB1 wrote:
Thanks in advance.
surely this depends on what your criteria are. Perhaps there are other things about Pentax that outweigh the size and weight (image quality, ergonomics, customisability). I don't like the trend for small dinky cameras hence my choice of the Panasonic S1R and the Fujifilm X-H1.
Agree - for me this makes the K3 iii a non-starter.
I have decided to wait until Pentax offer a tilt lcd with PDAF and catch in focus on the LCD. I will be first in line.
Thanks for engaging.
Philip
