Live view autofocus on Pentax cameras
mainoo Contributing Member • Posts: 592
Hello
I am looking for advice on the possible purchase of a Pentax camera. My main camera is a Panasonic S1R on which I mainly shoot manual focus lenses - for my AF needs (which are minimal), my strategy was to use my Fuji X-H1. But I don't get on well with modern lenses and haven't loved any of the Fuji lenses I have tried. I have finally settled on Zeiss classic lenses (the 50, 85 and a planned 135) and the Pentax FA 31 (which I love). I realised that since the FA 31 is AF and Pentax IQ looks fantastic, I could perhaps find a camera to do AF with the FA 31 and get a zoom for the rest of my AF needs (thinking of the 55-300 PLM). To clarify, I bought the FA 31 to use as a MF lens - the AF is a bonus.
What unites the Fuji, the Panasonic and any Pentax camera I get is the tilt LCD. I shoot only using the LCD so whatever Pentax I get must have good MF aids (magnification and peaking), good zebras/highlight alerts in real time and acceptable  AF via the LCD (and the LCD must not be a selfie one). My research indicates that good AF via the LCD may be a problem. I am good with just AF-S and I am usually not shooting anything faster than a jogger or a cyclist. My question is which of the recent Pentax cameras offers the best AF via the LCD. My research indicates that nothing has changed in this area since the K3. What is the scoop?
Thanks in advance.
Fujifilm X-H1
petrock Regular Member • Posts: 207
Re: Live view autofocus on Pentax cameras
The Pentax K-S2 (20mp), the Pentax K70 (24mp) and now the Pentax KF (24mp), are the only Pentax DSLR's that have the 'selfie' LCD. And I share your requirement for it.
Sorry, I mis-read your post, about the 'selfie', which you do not like !
Adam007 Contributing Member • Posts: 805
Pentax LV is behind other cameras, but it works just fine. The K-1 display could be more detailed.  I tend to use LV for still subjects.  Never a problem.
If you were otherwise happy with your S1R, I'm not sure why you would add a K-1. As you observe, you can adapt Pentax glass, and it doesn't; sound like AF is a key concern for you. I had an S1R for a month, and I did end up sticking with my K-1. My reasons might not be your reasons:
https://www.dpreview.com/forums/thread/4452904?fbclid=IwAR1_MbfHuucULUxxewR5vljG85OYSuRHlNNgk4tiR_lAdBn5qmnu0wuV-oM
Good luck!
 Adam007's gear list:Adam007's gear list
Fujifilm X100F Pentax K-1 Pentax K-3 Mark III Pentax smc DA* 300mm F4.0 ED (IF) SDM Pentax smc FA 31mm F1.8 AL Limited +7 more
MaKeR Senior Member • Posts: 1,006
Live view autofocus on Pentax KP camera
You ask "which of the recent Pentax cameras offers the best AF via the LCD". I can't answer which one offers the best. I do use AF via the LCD when shooting landscapes on my KP, and it works perfectly well. The AF area is a square of fixed size that can be positioned almost anywhere in the frame, or locked to the centre. It is white, and turns green when achieving focus, or red if focus cannot be obtained.
Other AF Active Area options for Live View, which I do not use, are Face Detection, Tracking, and Multiple AF Points. For the latter, the sensor is divided into 35 areas (7 horizontal by 5 vertical), from which you can select and position a rectangular array of 1, 9, 15, 25, or 35 of those AF areas.
AF Active Area can be assigned to one of the customizable buttons on the camera, for quick and easy switching on the fly without entering the menu. Although it's available, I don't use it in LV, but I do sometimes use it for switching between Select and Spot in AF through the viewfinder. I don't even have to take my eye away from the viewfinder to do this.
In Live View, when AF Active Area is Select or Multiple AF Points, and you are positioning the AF area, pressing the Green button (a hard button next to the LCD) instantly returns the AF area to the centre of the frame.
Two types of focus peaking are available: Highlight Edge and Extract Edge. Both are a boon to manual focusing in Live View, especially when combined with magnification, which is available up to 16x. In magnified view, after you have panned around the image, the Green button returns the magnified area to the centre of the frame.
Histogram Display and Highlight Alert (the blinkies) are both available options for Live View.
The KP has a tilting screen, not a "selfie screen". I find tilting it very useful, and have never had a problem with it in nearly five years of use. An Arca-Swiss plate is permanently attached to my camera, without interfering with the screen.
One or more of the features mentioned above (besides the tilting screen) are not available on the K-3.
I use manual-focus Zeiss and Voigtländer lenses on my KP. Of course, they are a pleasure to focus using focus peaking in magnified Live View on a tilted screen. The ergonomics - and the results - are excellent.
The one drawback I would point out is poorer battery life when using Live View on the KP, compared to the K-5 and K-3 lines of cameras.
The KP is discontinued, unfortunately, but available on the used market.
OP mainoo Contributing Member • Posts: 592
Good luck!
Thanks very much for responding. I am very happy with my S1R and the K1 is, indeed, not my target pentax camera. The second camera will ideally  have
  • great IQ
  • better low light performance than the S1R (ie not a high MP sensor)
  • a tilt LCD with MF aids and decent AF-S (able to accurately focus a moving target in AF-S mode)
  • lens options that I like (FA 31 and a decent zoom)
  • ideally APS-C (for longer reach with the zoom
  • ideally touch screen (for easy placement of AF target)
  • ability to adapt nikon, M42, sony A mount, etc lenses
The pentax KP is my current target (though I realise the LCD is not touch enabled).
Thanks again for responding.
KPM2 Senior Member • Posts: 2,076
Hello mainoo
You did asked for the LV AF, but for your lens you must make a decision, if you will use them on FF or with a 1,5x crop APS-C. For example your 31mm is nearly a normal 46,5mm lens on a APS-C.
Only the K1 and K1 II are FF cameras. Their LV use CDAF and it is not so fast as cameras with PDAF/CDAF for LV. The only PDAF/CDAF for LV camera is the K70 and the new KF, but that are APS-C cameras.
The DA 55-300mm PLM is not a FF lens. I use mine with my K1 in the crop mode of the camera, or when I use FF, I crop later in PP.
I never tried out to use with my K1 the LV for a picture of a bicycle driver...I use the OVF and it's faster PDAF for that. So, sorry, I can't say much about that if that would work. I only see, that when I move myself and move to an object my LV focus is 'watching'  the picture is not in focus. For stills, the LV is good.
best regards. KPM2
Re: Live view autofocus on Pentax KP camera
Thanks very much for your detailed and helpful response.
I also do not use face detect and am more concerned with the ability of the AF system to acquire focus on the subject under the focus rectangle and take the photo quickly.
The KP is the camera I am targeting and I am aware of the limited battery life. The only reason I need a second camera is for events (such as horse festivals in Spain and the UK) where I would use the AF camera with a telephoto (eg 55-300)  and either a wide (FA 31) or portrait (zeiss 85mm) on the S1R. The fact that I would also be able to AF using the FA 31 is an added bonus.
Thanks again.
JeremieB Senior Member • Posts: 2,041
My understanding is that the K3III would have the best LV AF. The K70/KF should normally be the best as it shares something with MILCs (phase detect AF points on the sensor supposed to help CDAF in LV), but in the end not really - I'd say K3III is better.
You don't get zebras but red highlight alerts. You can't change the color.
On K3III you have 2 focus peaking modes: one that emphasizes contours, the other shows only contours. Both can be useful.
Even with K3III, AF in LV is rather slow. With K3III you have less risk of having it focusing all the way from close to infinity and back (which can take ages on K70). So it's delicate, and AF C of joggers or other moving things can be frustrating honestly. With patience and precision it's usable not much more. On static subjects it's ok.
You get face detection and AF tracking, but not both at the same time: it detects the faces correctly but won't AF-C on detected face(s).
Personally 99% of the time when I use LV, I use it in manual focusing with focus peaking (landscape, macro). Whenever fast AF matters, I use OVF.
 JeremieB's gear list:JeremieB's gear list
Pentax K-70 Pentax K-3 Mark III Pentax smc FA 50mm F1.4 Pentax smc DA 18-55mm F3.5-5.6 AL Pentax smc D-FA 100mm F2.8 Macro WR +9 more
Maybe Catch In focus
Hello JeremieB
I did read that the Catch In focus works very fast with the K3 III. Maybe that would be a good solution for the OP, when he use his manual focus lens, to use the OVF and Catch In focus for moving subjects ?
Did you try out already the Catch In focus with your K3 III ? ... do it react really very fast ?
Best regards. KPM2
KPM2 wrote:
Hello mainoo
best regards. KPM2
Hello KPM2
Thanks for your helpful response. I am looking for an APS-C camera but hadn’t realised that the 55-300 PLM was an APS-C lens.
Given that the K70 has hybrid AF on the LCD, I imagine that would be much faster. If anyone has a view on how AF on the K70 LCD compares with the KP (for instance), I would be interested in hearing. One downside of the K70 is its selfie screen. As I would mainly be using the camera for AF at events, I may still consider it the AF implementation is surer.
Thanks again
mainoo
bokesan
bokesan Contributing Member • Posts: 776
Re: ... adapting lenses to Pentax K
That won't work. M42 yes, but Nikon F to PK adapters have to contain optics to be able to reach infinity focus. You don't want that. Same for Sony A, as it's flange distance is less than Pentax K.
- Chris
Thanks for your very useful response.
To be clear I wouldn’t be relying on AF-C for joggers but on AF-S and mashing the shutter button (having already pre-focused in the area). Because all the cameras I like have rubbish AF-C (panasonic, Fuji and now, pentax), I have accepted that AF-C is a non-starter (as is tracking). On panasonic and Fuji, I get better results just relying on the speed of focus acquisition in AF-S and not leaving a lag before i take the photo. As long as the subject isn’t moving fast, I can get a good result. The question is how good is the LV AF-S on these cameras? Unfortunately, for many shots, I don’t like the angle I get standing upright with the camera to my eye so the viewfinder isn’t for me.
- Chris
Thanks for pointing that out. That’s only a nice to have - all my important lenses (zeiss primes) will be nikon mount zf.2s but I am mainly shooting them on my S1R. As my subjects are rarely more than 3 metres away, I wonder if i would get away with using a dumb adapter with the zeiss  primes.
Thanks again
mainoo
bokesan
Re: ... Zeiss ZF.2
mainoo wrote:
- Chris
I'm not aware of really thin dumb adapters, just a rather thick one sold as "Macro adapter" (truth in advertising, for once). If you can find a reasonably thin one, I think it should work at least for the 85.
On the subject of ZF.2, I do hope you get the 135. The 50 (assuming it's the 1.4 and not the Macro) and 85 you own were redesigned for the Milvus line, and with good reason. The 135 APO-Sonnar is in a different league.
- Chris
Re: ... Zeiss ZF.2
Hello bokesan and mainoo
bokesan wrote:
mainoo wrote:
- Chris
- Chris
I don't know if you will do this, but LEITAX can change the mount :
http://leitax.com/Nikon-lens-for-Pentax-cameras.html
and also to other brands.
BTW: about the K70 and how the camera make a picture when it is in LV:
https://www.dpreview.com/forums/post/66612619
maybe you don't like it !
best regards. KPM2
Re: Maybe Catch In focus
KPM2 wrote:
Hello JeremieB
Best regards. KPM2
I tried catch in focus but only through OVF.
Hello JeremieB
JeremieB wrote:
KPM2 wrote:
Hello JeremieB
Best regards. KPM2
The catch In focus works only with the OVF.   Was it fast and accurate with your K3 III ?
best regards. KPM2
Re: ... Zeiss ZF.2
bokesan wrote:
mainoo wrote:
- Chris
- Chris
Thanks for responding. Before i bought the 85, I did compare it to the milvus using my flickr wall of pictures test and I preferred the rendering of the classic notwithstanding the better sharpness, less aberrations and better cross frame performance (if i recall correctly from reading this comparison) of the milvus. Ditto for the 50.
Regarding the 135, I agree completely.
KPM2 wrote:
Hello JeremieB
JeremieB wrote:
KPM2 wrote:
Hello JeremieB
Best regards. KPM2
best regards. KPM2
Oh ok I misunderstood,
Yes it works very well, I used it with the old M* 300mm lens and I had good success rate with seagulls in flight so not bad Not as good as with AF lens but clearly much better than in pure MF.
