A Computer for Minable Video Playback?
Started 4 months ago | Questions
Richard Frederick
Richard Frederick Senior Member • Posts: 1,143
I need a simple and small Windows computer than can play 30 fps 1080p videos.  Hdmi, and USB  outputs, optional ethernet input.  Nothing else.
Can anyone offer a suggestion or what specs to look for?
TIA,
Dick Frederick
 Richard Frederick's gear list:Richard Frederick's gear list
Ricoh GXR Mount A12 Sony Alpha NEX-7 Nikon D800E Nikon D500 Fujifilm X-Pro2 +2 more
NickZ2016 Veteran Member • Posts: 5,836
Re: A Computer for Minable Video Playback?
Honestly virtually anything sold today. The issues are the format of the file. Maybe.
Many small laptops have dropped ethernet connections but the other stuff? Shouldn't be challenging.
Form factor? Budget?
 NickZ2016's gear list:NickZ2016's gear list
Nikon D800 Nikon AF-S Nikkor 50mm F1.4G Nikon AF Nikkor 35mm f/2D Nikon AF-S Nikkor 50mm F1.8G Nikon 85mm F1.8G +4 more
Richard Frederick
OP Richard Frederick Senior Member • Posts: 1,143
Yes, that was my thought until I bought a small desktop as a close-out at a major chain.  It choked on 30 fps 1080p (.mp4).
I'll look around.
Dick Frederick
What file format? Which software?
DMKAlex
DMKAlex Veteran Member • Posts: 6,721
TIA,
Download Potplayer or VLC and it should work.
I have a 10 year old Celeron with virtually no ram and it plays 1080 without a hitch.
 DMKAlex's gear list:DMKAlex's gear list
Panasonic GH5 Panasonic Leica Summilux DG 25mm F1.4 Samyang 7.5mm F3.5 Fisheye Panasonic Leica 12-60mm F2.8-4.0 ASPH Panasonic Leica DG 50-200mm F2.8-4 +2 more
sludge21017
sludge21017 Veteran Member • Posts: 3,813
Which was?
Off The Mark Veteran Member • Posts: 6,934
I'll look around.
Something sounds fishy...
Please share the specs of that computer (CPU, graphics card, RAM , hard drive type / speed, operating system version - windows 11? Windows 10? Vista???).
Really, my old core2 duo running windows 7 with 12gb of RAM and spinning hard disks plays 1080p 30fps fine, and that computer was made around 2005 or sometime around then.
What Middle School Is Really Like:
https://youtu.be/Q1Xtz5EqMuo
 Off The Mark's gear list:Off The Mark's gear list
Sony a6000 Sony a5100 Sony a6300 Olympus E-M1 II Sony a6500 +16 more
Markr041 Forum Pro • Posts: 10,078
It is Not Resolution or Frame Rate - It is the Codec and Other Factors
Older Intel computers completely choke on HEVC 10bit 422 color, no matter what the resolution or frame rate and no matter what the player or editor.
Later Intel chips hardware decode HEVC 10bit. But it is necessary that the players/editors make use of that capability.
So, it is possible for an old computer to choke on merely 1080 video, if the codec is demanding.
The simplest solution to having a cheap computer that will in hardware decode and encode any codec - an m1 Apple computer. Mac mini m1 with 8GB does fine, as does a MacBook Air m1.
 Markr041's gear list:Markr041's gear list
Panasonic ZS100 Olympus TG-5 Canon EOS M Panasonic Lumix DMC-GH4 Nikon Z6 +5 more
Richard Frederick
Re: Problem Computer Specs
It did surprise me that the computer I bought would not play the videos I wanted.  Perhaps something else is the problem.  I have posted the specs as JPGs for your information.
Thanks for the replies.
Dick Frederick
You haven't mentioned what file types and what software. That's a seven year old CPU but even so I'd expect VLC to play most stuff.
sludge21017
It should handle a little bit of some video.
Intel HD Graphics 530 - Cpu Benchmark Specs & Test (cpu-benchmark.org)
But like NickZ16 asks - what are you trying to play?
It should playback Youtube in 1080p.
Richard Frederick
Re: File Types
I have both Ifranview and VLC, but neither will play the following file types on the problem computer.
The files are 30 fps,1080p, .MP4s that were rendered by Davinci Resolve Studio.
and yes, I would think any contemporary the computer should handle those which is why I bought the thing on price rather than specs.
Dick Frederick
Re: File Types
Does it play inside of Resolve? What did you render out to? 264?
Something doesn't make sense
Richard Frederick
Re: File Types
I am in a computer replacement project currently, so I cant check for sure, but the files played in Resolve and were probably rendered in 264 rathe than 265.
Dick Frederick
Re: File Types
Something weird IMHO is going on.  I can't think what.
sludge21017
Re: File Types
neither will play... no error message? just black screens?
How does the default windows 10 media player do?
H265 should give you problems unless you have the codec installed.
POT player has been mentioned in the forums before (I've never tried).
PotPlayer - Microsoft Store Apps
8 bit or 10bit videos?
And when did you buy this system?
Richard Frederick
Re: You Guys Are Correct
Thanks for the input.  I relieved the little computer from running an Irfanview slideshow 24/7, created new 30 fps 1080p .mp4 and .mov files.  They ran just fine like you said they would.  Indeed, something else was wrong when files failed to run at the start of this.
Thanks again,
Dick Frederick
