More re Crops
ozdean
ozdean Forum Pro • Posts: 28,665
More re Crops
5
More tests - Very interesting.
I have come to the conclusion that when the crop modes are activated all other pixels (Photo sites) outside the crop are turned Off ie they don't register on the sensor, here's why;
If you look at 1.7 the exposure is duller but more accurate to a 18% grey card and White Balance is correct.
In the 1.3 crop the exposure is lighter and WB is starting to tend toward Magenta both trying to compensate for the darker blue background of the desk.
With no crop their is much more blue desk in the Original Photo (before equalizing the crop) and we see the lightest exposure and most magenta.
I have to also expect that crop modes will decrease writes speeds and hence increase buffers in Hi Speed Shutters - more testing to come.
CONCLUSION; It is definitely worth cropping in Camera rather than Post - You are eliminating a lot of unwanted Light.
Original Shots
Regards Dean - Capturing Creation
N.B. All my Images are Protected by Copyright
 ozdean's gear list:ozdean's gear list
Pentax MX-1 Pentax K-5 IIs Pentax K-3 Mark III Pentax smc DA* 55mm F1.4 SDM Pentax smc DA 15mm F4 ED AL Limited +14 more
Kobie M-C
Kobie M-C Contributing Member • Posts: 701
Re: More re Crops
Original Shots
Interesting. About the buffer, no, it makes no difference. Full image, or either crop will fire off the same burst amount. They don't seem to process any faster either.
I am not a Pentax insider. I just have a unique way of gaining insight.
 Kobie M-C's gear list:Kobie M-C's gear list
Pentax K-30 Pentax K-3 Pentax K-3 Mark III Pentax smc DA 18-135mm F3.5-5.6ED AL [IF] DC WR Pentax smc DA 50mm F1.8 +6 more
ozdean
OP ozdean Forum Pro • Posts: 28,665
Re: More re Crops
I wonder why the buffer and write speed don't Change? The file is smaller.
TBLF Senior Member • Posts: 1,390
Re: More re Crops
Just a WAG, but maybe because it's a completely different bottleneck elsewhere in the system? Or maybe pixel mapping forces ones or zeros into those unused areas in order to meet some kind of CRC while it offloads the sensor and it strips them later as the file is written? I dunno, but you are right, it is odd that the designers would leave money on the table so to speak, if it was doable, you'd think they would have done it and bragged on it too.
EricV
 TBLF's gear list:TBLF's gear list
Sony a7R V Sony FE 200-600 F5.6-6.3 Sony FE 55mm F1.8 Tamron 24mm F2.8 Di III OSD 70-200mm F2.8 GM II +1 more
ozdean
Re: More re Crops
Yes Eric I know nothing about programming but I'm sure the outside areas are turned off after this test - you'd think there would be a capacity advantage?
MrB1 Contributing Member • Posts: 605
Re: More re Crops
The specifications show only one raw file size.  Perhaps that, and this info from Kobie, might suggest that the camera always captures the raw data for the full APS-C frame, processes it, then crops the resulting JPEG to 1.3 or 1.7.  The time differences to record different size JPEGs are possibly very small compared with the overall image capture and  processing time.
Philip
KPM2 Senior Member • Posts: 2,076
Re: More re Crops
Hello ozdean
That is an interesting test !
Your test may show that the metering react on the crop mode.
I checked my K5 once how (for the flash pictures) the matrix metering react on a mini light spots. The 77x segment matrix of the K5 do not cover the boarders. So in a test a mini light spot at the boarders do not get involved into the matrix metering.
In your case of the crop mode: why should the K3 III meter in regions, which get not into the picture. Maybe the K3 III do therefore let it's RGB sensor metering use always only the crop area than. You can try this out very easy with a mini pocked lamp (but please not with a super bright pocked lamp), the camera in M mode and watch the bar graph when your mini lamp is in the crop area and when it is outside.
But, because the crop can redone in the DCU, when it is a RAW file, the camera captured always the fully sensor pixels, only the jpg get the crop when saved in the camera.
BTW: When I use the crop or square mode with my K1 and I use RAW, I can not use the camera's picture editor for to get the FF format back. I can do this only in the DCU. Can the K3 III do this in it's picture editor ?
BTW II: I think the different crop modes would be good for the K1, K1II too, for non FF lens . Some you should use only with an APS-C crop, with others you can use a 1.3x crop, because the boarders still would looks good enough in this 1.3x crop. And for an easy use, you see the 1.3x crop frame in the OVF.
best regards KPM2
ozdean
Re: More re Crops
Hi KPM 2
That is a good idea to use a small light and just check the metering , this would confirm if the metering is confined to the crop area.
I have just done it and the metering really drops off in the outer area but still works. I guess it is still getting glow from the light in the cropped area.
RBIV Senior Member • Posts: 1,295
Re: More re Crops
If this series was taken with Automatic White Balance ON,  I'd have to wonder if the color of the table the manual rests on is contributing to differences.
Theoretically, the manual should be on an 18% gray table.
When I worked in a commercial photo lab, none of our printers could render accurate color balance if an object that required correct color balance was on a colored background.  We had 5 different types of color printers, and all failed that.
Might this explain color shift here ??
 RBIV's gear list:RBIV's gear list
Pentax K-5 Pentax KP Nikon Z fc Pentax smc DA 21mm F3.2 AL Limited Pentax smc DA 40mm F2.8 Limited +3 more
ozdean
Re: More re Crops
Yes it is and that proves that the area outside the OVF crop frame is discarded in determining WB & EXP - Camera was kept at the same height above the desk.
John Cal
John Cal Regular Member • Posts: 465
Re: More re Crops
That's odd I thought the Crop function was sold on the faster fps and buffer increased?
 John Cal's gear list:John Cal's gear list
Panasonic Lumix DMC-TS1 Pentax K10D Pentax K-7 Pentax Q Pentax K-01 +18 more
ozdean
Re: More re Crops
Yes John - It would be good if it could but doesn't seem to.
John Cal
Re: More re Crops
That's so strange but in this crazy world 🌎  nothing is certain, apart from Pentax ergonomics which are yet to be surpassed. Keep up the good work Dean, you get some beautiful BIF always an ambassador for the Pentax brand 😀 👍
James O'Neill Veteran Member • Posts: 6,117
Re: More re Crops
Not having the camera I'm guessing.
You had a theory that what is read from the sensor in crop mode is different,
I believe this for the K1 because in crop mode the FPS goes up. This suggests to me that the time to reset the sensor for the next frame reduces. The mechanical parts will go at 7 fps but the read out from the chip will only go support 4 fps in full frame mode, but the will go faster in crop mode. Since the chip can be told to give a video res frame at more frequent intervals, there must be ways of asking it for different things.
I've also wondered about where in the pipeline the buffer is.
There is a pipeline of sensor (A-D converter) , Prime chip, memory card. There's no real lower limit for the speed of the memory card, so it has always seemed the sensible thing to have the buffer after the prime chip, and what we see in the specs backs this up. It looks like frames arrive in the buffer as fast as they are shot, so the prime can process something like 160MPixels / sec.
However I've wondered if there is a way of doing it the other way around. Slow the prime chip down (and generate less heat and use less power) to match the write speed of the memory card, and buffer the unprocessed frames, although frames in buffer doesn't change with different file options, the number of frames to stall the buffer does. (if the buffer is 10 frames, and you can write 1 in the time it takes to shoot 10 you stall at 11, but if you can write 5 in the time it takes to shoot 10,  you have 5 still in the buffer after 10, and you'll have shot 20 by the time the buffer is full).
If the crop happens in processing AND an "early" buffer is imposing a limit, that would explain it. It might be more simply explained by something in the firmware not raising a limit when the mode changes.
 James O'Neill's gear list:James O'Neill's gear list
Pentax K-5 IIs Pentax K-1 Pentax smc FA 50mm F1.4 Pentax smc DA 18-250mm F3.5-6.3 Pentax smc FA 43mm F1.9 Limited +3 more
ozdean
Re: More re Crops
Thanks John.
ozdean
Re: More re Crops
Thanks James I appreciate your knowledge re the technical side of this.
To my simple (Mechanical) mind it seems the crop is done on the sensor and there should be less info to pass through the system.
I realize the frame rate can't change as that is mechanical but it would be nice if write speed could be enhanced?
