Query: Canon R6 Mark II with EF 100mm F2.8L
XN_Stein Forum Member • Posts: 55
Hi, I am using the Canon R6 Mark II with EF 100mm F2.8L. I used the Electronic first-curtain shutter and also ‘Low-speed continuous shooting’. For some reason, I always find that the keeper using the Canon R6 Mark II with EF 100mm F2.8L is low, and the photo is not sharp. I am trying to figure out is it user problem or what other possible reason that may result in this (e.g. higher aperture required?). I do not feel that my keeper is low with the EF 100-400mm F4.5-5.6L II lens though.
Kindly advise. Thank you.
Shot in raw .cr3 format using the Canon R6 Mark II with EF 100mm F2.8L and converted to .JPG without any edit using DPP4 Aperture: F2.8 Shutter Speed: 1/4000 ISO: 1000
AF point and histogram from DPP4
Shot in raw .cr3 format using the Canon R6 Mark II with EF 100-400 mm F4.5-5.6L II and converted to .JPG without any edit using DPP4 Aperture: F5.6 Shutter Speed: 1/60 ISO: 1000 Focal Length: 400mm
Canon EF 100-400mm F4.5-5.6L IS II Canon EF 100mm f/2.8 Macro USM Canon EOS R6 Mark II
Mike Engles Senior Member • Posts: 2,573
Re: Query: Canon R6 Mark II with EF 100mm F2.8L
One thing to try, is to AF on a spot using the spot AF no servo, then x6 the EVF, then try to see if you can get a better manual focus and then do another AF again. If there is no change, manual focus and spot AF are the same. If there is a change, the AF is off
tkbslc Forum Pro • Posts: 17,522
I would do some controlled tests with a static subject.  That is a very small moving subject with shallow DOF so plenty of room for user error.
OP XN_Stein Forum Member • Posts: 55
Thanks I will try it out.
Thanks. I will try out on a static object first. This is a lens that I really like as it give me excellent quality when I was able to nail the photo. Hopefully indeed is a user error.
