Distortion questions
Myrddhn New Member • Posts: 2
Hi,
I am very new to the Canon M50 and advanced photography, and may ask dumb questions, but I'm a bit disappointed by some of the pictures I've taken with the Canon.
I have all the options for Lens Aberration Correction applied, but am now wondering if applying them may not even be the cause of the problem.
Any comments and suggestions would be appreciated!
This Image was taken two weeks ago:
What irritates me is that the two buildings on the sides seem to be leaning in on each other.  Other images I've taken don't show this effect as profoundly.
The questions I have around this:
1) Does aperture have anything to do with aberration? (this is the dumb question)
2) This was shot with the general purpose standard lens that came with the M50, i.e. no wide angle and no telephoto.  Is this a perhaps a wide angle artifact because of the all-purpose nature of the lens?
3) It seems like the in camera settings for aberration correction had no effect, or would it have been worse without them enabled?
4) I haven't tried any software, not even the Canon Utilities.  Would they be able to correct this, since the effect goes quite far into the center of the picture?
Anyway, it's not the worst shot I've taken, so I'm not having sleepless nights over it, but I would like to understand the lens artifacts a bit better.
Thank you!
Andi
Canon EOS M50 (EOS Kiss M)
Larry Rexley Senior Member • Posts: 1,238
Re: Distortion questions
Myrddhn wrote:
Hi,
Thank you!
Andi
Welcome to the Canon M forum!
Keep in mind that 'distortion correction' term used in photography and 'perspective correction' are not the same thing.
When a camera corrects distortion, it tries to make straight lines in the image as straight as possible. Pincushion or barrel lens distorion would make straight lines near the edges of the frame slightly curved, and lens distortion correction should correct this.
The buildings lean towards the center because the camera is pointing slightly upwards. The camera was not level. This appearance is normal and natural, your eyes see it too but we don't really notice that because of the way our mind processes images. Sometimes photographers want to make the 'angled' lines vertical again --- this is referred to as perspective correction. General purpose image editing software often does not contain tools to do perspective correction, but it can be done in more advanced programs or in separate programs such as DxO Viewpoint.
It does look like distortion correction was applied to your image, as the lines are relatively straight. Perspective correction would not be applied by the camera to make the building walls vertical and parallel --- this would have to be done in special software. However, correcting perspective can be tricky and can only go so far... small amounts of correction can be done without reducing the image quality, but the more correction needed (as much as or more than your image needs) becomes tricky because parts of the image need to be stretched out, and there may not be enough resolution detail, so those parts start to look muddy and blurry.
To avoid the need for perspective correction, try to shoot with the camera 'level' - not pointing upwards, which usually requires a pretty wide angle lens if you're close to the buildings (or subject), or stepping back if possible (often this is not possible to get the shot and angle you want). Use the rear screen or viewfinder image while shooting to try to line up the sides of the buildings with the side of the frame as perfectly as possible.
The Canon EF-M 11-22mm f4-5.6 lens is a great, sharp ultrawide angle lens which is quite a bit wider than the kit EF-M 15-45mm kit lens that M cameras often come with. Lots of folks here use the 11-22, it's one of the best and most useful lenses on the mount. Shooting with that lens would give a better ability to get straight, vertical buildings.  After shooting, you can then crop the image to get the composition you want (because shooting with the camera level often gives you too much in the bottom of the frame, and you want to cut it off).
There are some even more extreme, more expensive wide angle lenses such as the extremely wide Laowa 9mm f2.8 manual-focus lens which are about as wide-angle as you can get, keeping lines parallel, without distortion, and without the need for perspective correction if you hold the camera level.
 Larry Rexley's gear list:Larry Rexley's gear list
Canon EOS M6 II Canon EOS M200 Canon EF-M 18-55mm f/3.5-5.6 IS STM Canon EF-M 22mm f/2 STM Canon EF-M 11-22mm f/4-5.6 IS STM +21 more
JRET
JRET Contributing Member • Posts: 840
Larry Rexley wrote:
Myrddhn wrote:
Hi,
Thank you!
Andi
great answer !
GENESIS 1:3
 JRET's gear list:JRET's gear list
Canon EOS M6 II Canon EF 100mm F2.8L Macro IS USM Canon EF-M 11-22mm f/4-5.6 IS STM Canon EF-M 18-150mm F3.5-6.3 IS STM Canon EF-M 32mm F1.4 +7 more
JustUs7 Senior Member • Posts: 4,327
Very thorough answer!
Short answer, turn on the level in your EVF and keep the camera level. Not only tilt, but front to back. Green line all the way across.
 JustUs7's gear list:JustUs7's gear list
Canon EOS 1000D Canon EOS Rebel SL1 Canon EOS RP Canon EOS M6 II Canon EF 75-300mm f/4.0-5.6 III +10 more
Andy01 Veteran Member • Posts: 5,188
In addition to the comprehensive answer above, it should be noted that 15mm (even on a crop camera) is wide angle. The 15-45mm might be the "standard" zoom that came with the camera, but 15mm is still classified as wide angle.
Converging diagonals is I think the term, and it is quite common with most wide angle lenses and as above can be mitigated (by keeping the camera as level as possible), but it is a common problem - hence the existence of tilt-shift lenses.
 Andy01's gear list:Andy01's gear list
Canon EOS M5 Canon 6D Mark II Canon EF 100mm F2.8L Macro IS USM Canon EF-M 22mm f/2 STM Canon EF 35mm F2 IS USM +5 more
OP Myrddhn New Member • Posts: 2
Larry Rexley wrote:
Myrddhn wrote:
Hi,
Thank you!
Andi
Hi Larry,
Thank you for the comprehensive answer!  It's now clear that the issue is related to perspective and not distortion, no blame on the the camera or the lens.
R2D2 Forum Pro • Posts: 26,528
Re: Distortion answers
Myrddhn wrote:
Hi,
Welcome to the Forum, and thanks for posting!
Every question has an answer. And good answers have been provided thus far, so I'll be brief (plus I have to head to work!).
Every camera presents its own challenges. It just takes a while to work through them.
I apply them to all images.
Nicely photographed actually.
This is a physical effect called Keystoning, caused primarily by tilting the camera up or down, and also by your shooting location. You might not be initially aware that you're doing it, but it will profoundly affect your images (as you've seen here).
Keystoning is a type of perspective distortion, and has been around since the beginning of time. You would have to place the blame on Aristotle rather than Canon methinks.
Fortunately there are things you can do to mitigate these effects while you are shooting (do a search), or to "correct" the distortion in post processing (I too like DxO's Viewpoint software). DxO has (IMHO) the world's best noise reduction technology in their Photolab 6 software, and the two programs go hand in hand.
No. And aberration has nothing to do with perspective distortion.
The wider the angle, the more pronounced the distortion can be (perspective distortion is really determined by your viewpoint actually).
https://www.bhphotovideo.com/explora/photography/tips-and-solutions/perspective-distortion-photographic-composition
BTW 15mm (on a crop-sensor camera) is considered to be very wide angle. Anything wider would be considered to be Ultra-wide angle.
No effect. Aberration correction basically straightens bent lines, not converging lines.
If you use Photoshop, you can correct with certain techniques. Here's one tutorial...
https://www.photoshopessentials.com/photo-editing/keystoning/
Fortunately there are things that YOU can do to minimize this effect (if so desired). Or you can use this effect to your advantage creatively even. Knowledge will open new doors for you!
Thank you!
Andi
Enjoy your new camera!
R2
Myrddhn wrote:
Larry Rexley wrote:
Myrddhn wrote:
Hi,
Thank you!
Andi
Hi Larry,
You're welcome. Here's a post I wrote in the DxO thread on using DxO Viewpoint to do both vertical and horizontal perspective correction. Other software can also do perspective correction, but how it's done probably varies.
https://www.dpreview.com/forums/post/66132882
With wide angle lenses, sometimes it's helpful to stretch the image horizontally as well to make it look more natural or improve the overall composition.
Kjeld Olesen
Kjeld Olesen Veteran Member • Posts: 4,588
Distance perspective not related to lens distortions
All parallel lines appear to converge at a distance no matter whether they go up, down, left or right - it is not really distortion in any way, but a consequence of the fact that things look smaller at a distance or distance perspective.
As was probably mentioned, the convergence is easily corrected in in software, obviously at the cost of cropping out some of the image
 Kjeld Olesen's gear list:Kjeld Olesen's gear list
Canon EOS M Canon EOS 6D Canon EOS M5 Canon EOS R6
Re: Distance perspective not related to lens distortions
+1 The cropping that happens is something (else) that has to be taken into account when composing.
R2
MyM6II Senior Member • Posts: 2,424
This does not look right. The towers lean slightly outwards. For correct perspective, they should lean slightly inwards.
To me it looks overcorrected.
 MyM6II's gear list:MyM6II's gear list
Canon EOS M6 II Canon EOS M6 Canon EOS M200 Canon EOS M50 II +1 more
