Why am I getting this instead of my video in Premiere
Alex Ethridge
Alex Ethridge Veteran Member • Posts: 5,424
Using Adobe Premiere Elements 2019.
Why, when I export a video, do I see this screen instead of the video I just exported to 1280x720?  It just sits there still as the indicator at the bottom moves across the screen as though it is playing something.
 Alex Ethridge's gear list:Alex Ethridge's gear list
Panasonic Lumix DMC-FZ300 Panasonic Lumix DMC-G1 Panasonic GH5 Sony a7 III Nikon AF Micro-Nikkor 60mm f/2.8D +10 more
Sean Nelson
Sean Nelson Forum Pro • Posts: 16,109
Re: Why am I getting this instead of my video in Premiere
This is that Premiere shows if it can't find the clip that you imported into the project.   For example, if you renamed the clip or moved it to a different directory after you created the project, this is what you'd see.
Alex Ethridge
OP Alex Ethridge Veteran Member • Posts: 5,424
OK, makes sense because I have been moving the files around (not copying) but there is a right arrow at the extreme right of that image and if I click on that, the video that I want, plays.  Strange.
No matter, though, just strange.
