Image extrapolation for stereo photography?
Paul Houle New Member • Posts: 23
I first got into stereo photography because my son had found some stereograms on the web and an early thing we tried was making a stereogram from some anime art by creating a depth field and sliding the pixels around accordingly.
This failed, of course, because in a stereogram slightly different fields are visible to the left and right eye and it showed up in that attempt as black fringes around the edges of objects because I didn't have any data to put there.  Here is an image for one eye:
What it comes down to is that different things are obscured for the left and the right eye so there is really more information in a stereogram than an ordinary photo.  Maybe some of why emotional scenes in the cinema work well in stereography is that you get to see a little bit more of the expressive muscles on the sides of the face that are normally obscured.
For the anime art this can fixed by emulating the "multiplane camera" that is used to composite cels, if I have separate character and background cels it is straightforward to generate images for the left and right eye... But I need either a complete background or enough of the background to fill into those areas that are black.
I shoot stereograms today with a QooCam Ego and often get good results.  I wish though sometimes the interaxial distance was not fixed or that I could otherwise manipulate the depth map of the image.
Some similar scenarios would be:  making a stereogram with a normal photograph plus a depth map (there are good algorithms for guessing a depth map from a single frame),  making a stereogram from a light field camera, etc.
With all the image synthesis stuff being developed today such as diffusion models and NeRF it seems you should be able to make something up for the pixels that are obscured in the original frame.  Usually I find that stereograms work better if the left and right images aren't too far from each other and in that case the fringe areas aren't very large and not so hard to interpolate.  I've also read that they had tools in the movie industry by 2008 which could apply depth maps to an ordinary movie to "depth grade" it and make a stereo movie.  I don't know how much labor that takes as Hollywood pays a lot of people to touch up frames for movies.
So I'm wondering:  what kind of tools are out there for extrapolating pixels to set stereo photos free from a fixed interaxial?
Turbguy1
MOD Turbguy1 Senior Member • Posts: 1,467
Re: Image extrapolation for stereo photography?
I believe there are tools to REDUCE the interaxial (reduce deviation) in a stereo pair, but not INCREASE it (very well), due to the guessing required for the missing obscuration that would emerge.
 Turbguy1's gear list:Turbguy1's gear list
Minolta DiMAGE 7 Konica Minolta DiMAGE Z5 Konica Minolta DiMAGE A2 Fujifilm FinePix Real 3D W3 Nikon D300 +3 more
Joseph S Wisniewski Forum Pro • Posts: 35,462
Search for "stereo inpainting" or "disocllusion"
The term for that is "occlusion". It's a well-known problem in converting 2D images and videos to 3D (2.5D is a more accurate, but less common term) stereo images.
I think the greater emotional effect is in the separation of characters from background.
The algorithms that generate that are referred to as "occlusion inpainting" or "disocclusion" algorithms. Google those things and you can find all sorts of papers and experimental software.
If you're only concerned about manually converting a relatively small number of 2D images to 3D, try the inpainting features of your photo editor, such as PhotoShop "content aware fill", Affinity "inpainting brush", or the G'MIC plug-in in Gimp.
Disocclusion is less of a challenge for video, because you can build up the background as foreground objects move. There are a dozen different under-$100 2D to 3D video conversion programs such as Video Solo or 3D Combine.  My Sharp 3D TV and Sony 3D blu-ray both have real-time 2D to 3D conversion, but it's nothing to write home about.
If you want that sort of thing, there are Stable Diffusion plugins for PhotoShop, the Gimp, Krita, etc.
A lot of labor. But not as much as shooting in 3D, especially when you compositing stereo video with CGI.
I think I already answered that.
The term "mirrorless" is totally obsolete. It's time we call out EVIL for what it is. (Or, if you can't handle "Electronic Viewfinder Interchangeable Lens" then Frenchify it and call it "LIVE" for "Lens Interchangeable, Viewfinder Electronic" or "Viseur électronique").
Stanley Joseph Wisniewski 1932-2019.
Dad, so much of you is in me.
Christine Fleischer 1947-2014.
My soulmate. There are no other words.
Rahon Klavanian 1912-2008.
Armenian genocide survivor, amazing cook, scrabble master, and loving grandmother. You will be missed.
Ciao! Joseph
www.swissarmyfork.com
 Joseph S Wisniewski's gear list:Joseph S Wisniewski's gear list
Nikon D90 Nikon D2X Nikon D3 Nikon D100 Nikon Z7 +48 more
