Focus Stacking With My Brand New Sony A7RV
AeroPhotographer Regular Member • Posts: 462
This is the first Sony camera to offer focus stacking.  It arrived yesterday and I immediately tried stacking.
I've never done this with any camera, but found it easy.  Before the shot you select the spacing between shots (which is an arbitrary number from 1 to 10) and the maximum number of shots.  Tutorials recommend setting a large maximum, like 50 shots.  It begins where you focus (nearest spot in the scene) and steps outward until focus reaches infinity and the sequence stops, hopefully short of your maximum.
The rate is about 2 shots per second.
Here is a stack of 20 frames, downsized for sharing.  I set the max at 50.  It stopped after 25 frames.  I discarded the last 5 frames and stacked the first 20.
I first tried stacking in my (favorite) ACDSee editor, but did not succeed.   Then I tried Helicon Focus which took less than 30 seconds to merge twenty, 61mp frames.
grsnovi Veteran Member • Posts: 3,030
Re: Focus Stacking With My Brand New Sony A7RV
Very nice!
And with the 28-60 no less - which is really a great little lens!
I've only used the in-camera option a few times with my gx9 and on top of that I've only recently really figured out how to select between the in-camera option that provides a similar interface. You can select an increment value, number of exposures and then you can either go from closest point incrementing further away or you can select a mid-point and increment either side of that closer and further away. This results in a number of individual images that you are then left to focus stack on your own.
The Panasonic in-camera method shoots 4K video of your scene and then stacks in-camera to give you a focus-stacked jpg.
- Gary
 grsnovi's gear list:grsnovi's gear list
Panasonic Lumix DMC-GX85 Sony SLT-A65 Sony a7R III Panasonic Lumix DC-GX9 OM-1 +11 more
oneofone25
oneofone25 Senior Member • Posts: 1,586
so the Sony camera itself focus stacks?  Or does it focus bracket only and you must stack externally?
 oneofone25's gear list:oneofone25's gear list
OM-1 Olympus M.Zuiko Digital ED 60mm F2.8 Macro Samyang 16mm F2 +1 more
OP AeroPhotographer Regular Member • Posts: 462
The camera shoots a sequence of images, which must be stacked in a computer.  As I mentioned in the OP, I stacked the images with Helicon software.
Alan
Gopal42986 Contributing Member • Posts: 896
Wonderful...
 Gopal42986's gear list:Gopal42986's gear list
Canon EOS 550D Canon EF-S 55-250mm f/4-5.6 IS
Gilbert1 Regular Member • Posts: 329
Interesting. Can you also use Lightroom for focus stacking? Or is it better to use Helicon in this case?
 Gilbert1's gear list:Gilbert1's gear list
Nikon Z6 Nikon Z 24-70mm F4 Nikon Z MC 105mm F2.8 VR S
I don't use Lightroom.  But I've read that it can stack.
talkin73 Regular Member • Posts: 249
Not in Lightroom, but in Photoshop.
https://www.adobe.com/creativecloud/photography/discover/focus-stacking.html
I’ve read posts from folks that get great results in PS. I’m not sure what they are doing to achieve those results but I’ve never found PS to work nearly as well for me as Helicon Focus. Below was done in Helicon and I find it was easy to learn how to use, at least the basics.
Also great to see that SONY finally added focus stacking. I enjoyed using an A9 and then A9II for awhile. Wonderful cameras and great lenses. The A1 menu update looked really good as well.
Never understood why they took so long to add stacking. Has become such a common tool for both landscape and macro work. Essentially every single other manufacturer has the feature on even their entry level cameras. I believe SONY was actually the only manufacturer of ILCs that did not have this feature.
So, they led the way with mirror less cameras tech and then were last to the party with one of the simplest features that probably took nothing more than a five minute software tweak. Better late than never
Will be interesting to see if the feature carries over to their other models subsequently released. Most manufacturers offer stacking across the board in nearly all their models and don’t limit it only to cameras marketed as those for landscape, for instance.
I own the A7RIV and my excuse for buying the A7RV was that I wanted to try focus stacking.  But now that I have the camera, the feature that I love is the superb IBIS.  And it's not the ability to capture a sharp pic with a slow shutter speed.  Rather it's the ability to apply a precise manual focus tweak while hand held.  I absolutely love that.  The stable view in the EVF makes manual focus so much easier and accurate.
Alan
Alan
That is a nice feature. From the handful of reviews and comments I’ve read, seems like this was a nice upgrade to the mark IV version.
Sasquatchian Regular Member • Posts: 248
Of course you need an autofocus lens for automated in camera focus bracketing and some of the best macro lenses are manual only, so don't let the lack of autofocus keep you from focus bracketing.
Focus stacking in Photoshop is rudimentary at best. It's a two step process where the first step, Align Layers actually works quite well, but the whole thing falls apart when it comes to Blend Layers where the typical crappy results are seen.
The easiest stacking software is Helicon but there are a couple or caveats, having done many hundreds of stacking projects. You absolutely have to go into the Preferences and change the defaults in the interpolation options to whatever is the very slowest option. It makes a huge visible difference in the quality of the stacking and slows down the process. You probably won't get those fast stacking times this way but they will be better.
Secondly, you may have to tweak the preferences for how much resizing or rotation the program is allow to do during the stacking process, particularly with lenses that have a high degree of focus breathing as you move from close to further away. And then, for most stacking operations, Mode C seems to provide the best quality.
There are situations where Helicon falls apart - and those are generally when you have a flat, flatly lit surface with little or no detail that's coming toward the lens. Those flat areas can often get weird banding and other artifacts that will need retouching. When those happen, I've found that Zerene Stacker usually handles those areas quite a bit better, but if you don't want to have multiple stacking apps on hand, I always recommend Helicon first.
 Sasquatchian's gear list:Sasquatchian's gear list
Fujifilm GFX 100
Montanawildlives Senior Member • Posts: 1,845
I've gotten good results with Zerene and Helicon but for my relatively infrequent stacking I have reverted to just using Photoshop. Each program uses it's own parameters and algorithms and, while I might give the edge to the dedicated stacking programs overall, there are times when Photoshop nails it and the others return absurd results. Probably 20% of the time PS nails it and 40% of the time it is Zerene and the same for Helicon, but the ease of use of PS is also a consideration for me. It also seems that PS rarely completely screws up whereas the others can go off the rails sometimes. Manual repairs are also very easy in PS but more complicated in the other programs (maybe just because I am well-versed in PS's masking).
Anyway, I'd suggest trying PS before purchasing another program (assuming you already have LR/PS). The particulars of the photos have a lot more to do with the results than the program used.
 Montanawildlives's gear list:Montanawildlives's gear list
Fujifilm X-T1 Nikon D500 Fujifilm X-T3 Nikon AF-S DX Nikkor 35mm F1.8G Nikon AF Nikkor 50mm f/1.8D +7 more
I've never had Ps nail focus stacking ever. But if you have modest sized files, it's possible that it might be okay for you. I'm generally working with between one hundred and three hundred 600mb files from a GFX 100s and when things are not right, they're really not right.
Fujifilm GFX 100
LOL yeah, 300 x 600 MB files is a bit above my pay grade!
philzucker
philzucker Forum Pro • Posts: 10,390
My experiences here are different. If you have a stack with something like 60 exposures (if you go into very large magnifications that's quite normal) I find repairs in PS almost impossible to do with complex subjects - to find the masks to retouch is really no fun. OTOH the retouching function of Zerene is very intuitive and fast - even for complex projects.
Note that by "retouching" I mean finding and cloning regions from layers not used by the stacking algorithm. I do final retouching in the classical meaning (minor repairs, removing blemishes or "stacking worms") in Photoshop with the resulting flat file after finishing the stacking/retouching process in Zerene.
Agree to that. Also the depth of the stack, I might add.
Phil
