Those who have 55-200, was it worth getting the 55-250?
jackwelch Senior Member • Posts: 1,087
So just out of curiosity, for those that have the ef-m 55-200mm, was it worth getting the ef-s 55-250mm STM?
I can get one for $170 new and this is pretty much the best price you'll see in Malaysia.
Would love to hear your experience
Dareshooter Veteran Member • Posts: 5,842
Re: Those who have 55-200, was it worth getting the 55-250?
Jack the 55-250mm is better for close ups than the 55-200 mm. At normal distances on the copies I owned both were pretty much identical. The only disadvantage I found with the 55-250 mm was it felt a bit more front heavy on my M50 . If you can live with that then the 55-250 mm STM plus adaptor would be a better choice IMHO.
DerGuator
DerGuator New Member • Posts: 15
I already had the 55-200 when I bought the 55-250. I only bought it because I wanted a compact super-tele lens and I saw here on the forums how some folks were using it with a 1.4x extender.
For normal use I prefer the 55-200 though because it's a native lens and therefore so much smaller.
OP jackwelch Senior Member • Posts: 1,087
I'm asking because I already have the 55-200mm, and I am seeing the 55-250mm STM less and less on the market as "new" lately, so might be the last time to snatch one new before it's gone completely.
My heart says buy, but my mind says no, you already have an identical lens
That extender is quite pricey where I'm at, I too also thought about getting one, but at nearly $200, it's like buying a new lens. I would prefer to put that money into something like the tamron 100-400mm or sigma 150-600mm.
Or even this ef-s 55-250mm STM
And you're right, who knows 1 year down the road someone might want to sell his kenko 1.4x teleplus hd cheaply so it would be cool to pair it with the 55-250mm STM.
User1303423862 Senior Member • Posts: 1,070
You can find older EF 1.4 Kenko teleplus extenders on ebay for a lot less than $200. You then just need to follow Larry Rexley's instructions to remove the pcb from the inside and then you have a sharp 77-350 setup. That gives you a full-frame equivalent of 560m at the long end, which is capable for wildlife etc. A worthwhile investment in my opinion. I have a 2X extender made by Larry, but the 1.4X is the easier conversion. You'll need an EF rear mount plate conversion for the lens as well. They can also be found on ebay.
55-250 + Rexley-Kiron 2X extender
I am not a number. I am a free man.
How the heck did I end up with this username?
 User1303423862's gear list:User1303423862's gear list
Canon EOS R Canon EOS M6 II Canon EF-M 22mm f/2 STM Canon EF-M 28mm F3.5 Macro IS STM Canon 70-300 F4-5.6 IS II +4 more
nnowak Veteran Member • Posts: 9,076
I shot the EF-S 55-250mm STM side by side against the EF-M 55-200mm STM.  With my copies, the EF-S lens was noticeably sharper at the long end and basically the same at the wide end.  This is on top of also having more reach.  It was years ago, but the EF-M lens was purchased new and the EF-S lens was either used or refurbished, can't remember for sure.  Larry Rexley did a similar comparison a few months ago and came to the opposite conclusion.  As with most lenses, sample variation appears to be an issue.
Here is another way to look at it...  If you need 250mm of reach, you would need to crop the 32mp M6 II down to 20mp to get a similar field of view with the 55-200mm lens.  If you are using one of the 24mp bodies, this crop would drop you to 15mp.
MyM6II Senior Member • Posts: 2,424
I have both.
I like the EF-S, but I love the EF-M. I’m going to keep both.
 MyM6II's gear list:MyM6II's gear list
Canon EOS M6 II Canon EOS M6 Canon EOS M200 Canon EOS M50 II +1 more
Digirame Forum Pro • Posts: 41,839
I have been using the Canon 55-250mm lens with my DSLR camera.  I also use the lightweight Canon 55-200mm lens with my Canon M50 MKII.  There's times I like to have that extra 50mm focal length reach.  Both of them give me clear sharp pictures.
JRET
JRET Contributing Member • Posts: 840
Has anyone compared either the 55-200 or 55-250 to the EF 70-200 f/4 on an M body, perhaps the M6II?
GENESIS 1:3
 JRET's gear list:JRET's gear list
Canon EOS M6 II Canon EF 100mm F2.8L Macro IS USM Canon EF-M 11-22mm f/4-5.6 IS STM Canon EF-M 18-150mm F3.5-6.3 IS STM Canon EF-M 32mm F1.4 +7 more
Not on the M6 II, but tested on other bodies.  From best to worst...
  • EF 70-200mm f/2.8 IS L II
  • EF 70-200mm f/4.0 IS L
  • EF-S 55-250mm IS STM
  • EF-M 55-200mm IS STM
  • EF-S 55-250mm IS II
Thank you for the info, definitely something I'm looking out for. And I've been monitoring but even these other models/variants are pricey where I am at.
R2D2 Forum Pro • Posts: 26,530
Definitely something to consider.  I did the “Larry Rexley” conversion on my other 55-250 STM, with a Kenko 1.5x (plus eBay backplate) and it works great!  A few samples here…
https://www.dpreview.com/forums/post/66535831
R2
Larry Rexley Senior Member • Posts: 1,238
I 'second' this post --- the optical quality of the EF-M 55-200 and the EF-S 55-250 are quite similar, it really isn't easy to tell images made with them apart.
It really comes down to whether you prefer the compact and lighter 55-200 or the extra range, slightly brighter max aperture, and possible teleconverter use of the EF-S 55-250. And now with the refurb EF-S 55-250 IS STM (and the refurb Canon EF - EOS M adapter) being such a low price, cost may now be a deciding factor as well. If I had to choose only one --- I need the reach and would opt for the 55-250, no question.
I own both and take one or the other with me in my camera bag much of the time (but never both) depending on what else is in the bag and what I think my needs are. There are so few telephoto lenses for EOS M mount that I like having both and would not consider selling either.
Normally I'm shooting the EF-S 55-250 with a 1.5x teleconverter making it more of a 90-375mm lens.
 Larry Rexley's gear list:Larry Rexley's gear list
Canon EOS M6 II Canon EOS M200 Canon EF-M 18-55mm f/3.5-5.6 IS STM Canon EF-M 22mm f/2 STM Canon EF-M 11-22mm f/4-5.6 IS STM +21 more
KEG
KEG Veteran Member • Posts: 4,909
I compared 70-300 f/4-5.6L to both of them and it is sharper.
KEG
 KEG's gear list:KEG's gear list
Canon EOS M6 Canon EOS R Canon EOS M6 II Canon EF-M 32mm F1.4 Canon RF 50mm F1.8 STM +21 more
Maxmolly7
Maxmolly7 Senior Member • Posts: 1,481
I have both and use them for different set-ups.
  • The EF-S 55-250mm STM IS goes with M6ii and 1.4  converter for extra reach.
  • The EF-M 55-200mm is permanently on one M100 body (15-45mm on another one) in 1 small messenger bag as light dual camera setup.
As stated, EF-S has closer focus distance and thus better macro capabilities. I have not yet done a benchmark test on IQ.
May THE LIGHT be with you!
 Maxmolly7's gear list:Maxmolly7's gear list
Sony RX10 IV Sony RX100 VII Canon EOS M6 II Canon EF-M 11-22mm f/4-5.6 IS STM Canon EF-S 55-250mm f/4-5.6 IS STM +16 more
Alan WF
Alan WF Veteran Member • Posts: 3,806
If you're thinking of changing to R sometime in the future, then you'll be able to adapt the 55-250. For that reason alone, it might be worth getting one while they're still available.
Alan
 Alan WF's gear list:Alan WF's gear list
Canon EOS M50 II Canon EF-S 18-135mm F3.5-5.6 IS STM Canon EF-S 55-250mm f/4-5.6 IS STM Canon EF-S 10-18mm F4.5–5.6 IS STM Canon EF-S 24mm F2.8 STM +21 more
KEG
Alan
I am kind of interested in one of the crop Rs as soon as they hit M50 pricepoint.
KEG
5
KEG wrote:
Alan
I'm not interested in crop Rs at ALL. No matter the pricepoint.
Alan WF
Let's keep it OT, ok?
Let's try to keep the conversation on-topic.
If someone is interested in an R, then there is a specific advantage to an EF/EF-S lens over a similar EF-M lens, and that's relevant for this discussion.
However, I don't think stating personal positions on R in this context really helps anyone.
Alan
