EZGritz
Re: Tempted to enter MFT system for sports and action photography
I bet the OM-1 DR is much better. You haven't tried it. The 40-150 PRO is ~ 2lbs with a 2X TC but also f/5.6 is much brighter with better IBIS and a bigger sensor that captures more light. It will work better in lower light and enable you to shoot a higher shutter speed. The kit will be 1lb+ heavier than your SONY bridge camera.
I almost never need 600mm though. 80-90% of my sports photography is 300mm or shorter. The 1.4XTc takes it to 420mm which gets me to 98% of the needed reach and is f/4, brighter still.
The OP says he needs 200mm or less. The 40-150 f/4 beats that by 50%, weighs less than a pound, and satisfies his need for reach. This kit is lighter and much more compact than your SONY. When he uses the 12-45 f/4 it's half the weight and much smaller than your SONY. You can crop M43 images 100%-200%. 10MP is way more than enough for big, high-resolution monitors. The websites I shoot for publish 2MP. It's all you need unless you print large format. If you do, 16MP is more than enough for a 12X18 print. Bigger prints take up a lot of wall space. Few images are printed bigger.
If he needs 14-150 range f/4-5.6, that kit weighs less than your SONY and takes as good or better image.
The OLY 12-200 (24-400mm) weighs one pound. The kit weighs less than your SONY and in either case, the OMS kit enables you to mount a shorter lens and configure a 1.5lb or less zoom kit when he doesn't need the range. Why do you want to carry around a 2.5lb bridge camera to shoot 24-90 when you can do it with a brighter lens with a 1.5 lb kit?
When I used bridge cameras I thought a 28-280 was long enough. Panasonic make an excellent 100-400 bridge camera I'd consider but same issue. When I want to shoot 12-90 what do I need to lug that thing around for when I can make a better image with any M43 camera and a 12-45 f/4 and carry a compact kit that weighs 1.5lbs?
The SONY bridge camera is good only if you need the entire range out to 600mm in the same shoot. FF Sony kits are much heavier than the M43 solution. Using a lens that isn't long enough and cropping the resolution in half is a handicap, not a benefit. It's using a shotgun to spray and prey rather than using a sniper rifle to take one photo and know you have it. Much less work.
BTW, the sensor in OLY/OMS bodies are Sony sensors. The OMS/OLY bodies have a long list of things they can do that aren't in the SONY bodies. IBIS is much better in the OMS/OLY bodies. Sonys are better for high-resolution landscape images.
