Fuji x100 low light
Miskec Senior Member • Posts: 1,941
Fuji x100 low light
Hi all!
I plan to take photos of a party with my X100 F. I have decided not to use the flash and will allow the camera to go all the way to ISO 12800 with minimum SS of 1/60, since there will not be much light and my priority is to get photos.
Also, I will shoot B&W (RAW + JPG). Would you reccomend Acros and which (Red,Yellow,Green?)
I dimmed the lights in my house and try the settings out. I was shocked, my X100 F almost allways picked the ISO 12800 and the shutter speed even went bellow 1/60.
Did anyone tried something similar?
Thank you
Neven
Fujifilm FinePix X100
paulhoppe_photography
paulhoppe_photography Regular Member • Posts: 256
Re: Fuji x100 low light
It's not really the best camera for low light...just to make sure aperture was f2?
If you shoot RAW you can use the Fuji X-Raw software to develop each raw in whatever film sim and color filter you like. Lightroom or C1 ca do the same.
 paulhoppe_photography's gear list:paulhoppe_photography's gear list
Fujifilm XF 16mm F2.8 Fujifilm XF 27mm F2.8 R WR Fujifilm XQ2 Ricoh GR III Nikon D80 +4 more
OP Miskec Senior Member • Posts: 1,941
Yes, F2
It's not a paid gig or something. I want to take better than smartphone snaps of my work collegues, dancing, cheering and having fun. All without flash not to bother anyone.
The party is tommorow and I am sure ISO 12800 should be enough. Maybe the light wont be as low.  Maybe I will lower the SS to 1/40 but that's it. I originaly planned to go 1/100. Noise doesn't bother me, blur does.
Neven
Erik Baumgartner Senior Member • Posts: 6,893
Miskec wrote:
Hi all!
Thank you
Neven
Make sure the ND filter isn’t engaged (3 stops, I think in the F). I shoot in low light with my X100 (V) all the time, the ISO will be very high, but in a “normally” lit interior space, you really ought to be able to get away below ISO 12800. I would seriously want to avoid going below 1/80” with people, 1/125”+ would be better if you can manage it. Don’t “dim” the lights. You will likely get significantly better results shooting RAW, especially if you want some in color. If you must shoot in jpeg, I would probably go with a B&W sim without a color filter, interior light will already give you an orange/red effect. Go RAW+Jpeg for maximum flexibility.
Sony RX100 Fujifilm X100V Fujifilm X-T2 Fujifilm X-T20 Fujifilm XF 35mm F1.4 R +5 more
Erik Baumgartner wrote:
Miskec wrote:
Hi all!
Thank you
Neven
Thank you for you helpfull tips. I will try to do my best and catch some light on peoples faces. I will use acros or maybe monochrome.
Neven
DirkPeh
DirkPeh Contributing Member • Posts: 520
I would use the flash, dial it down a few steps. Otherwise you might get some keepers, but most of the pics will be blurry or overly noisy. If not using flash, look for some places with halfway acceptable light or even talk people into posing with the available light in mind or use some people as assistants and hand them some flashlights to lighten your subjects.
 DirkPeh's gear list:DirkPeh's gear list
Panasonic LX10 Ricoh GR III Fujifilm X100V Sony a6400 Sony E 50mm F1.8 OSS +5 more
stephenseriously
stephenseriously Regular Member • Posts: 103
Miskec wrote:
Hi all!
Thank you
Neven
Neven
There's a pretty encouraging write-up of the x100f's low-light capabilities on Shark & Palm:
https://www.sharkandpalm.com/photography-tips/high-iso-on-the-fuji-x100f-is-low-light-shooting-possible
topline takeaways:
1.) sounds like you should be fine going as high as 12800 in Acros, but color starts breaking down after 6400.
2.) AF is quick with the illuminator light, but will probably struggle without it. manual focus with peaking on may be your best bet if you don't want the illuminator constantly flashing.
3.) might not hurt to reconsider using the onboard flash in some situations. it looks pretty well balanced. you could also get a small godox, meike, or similar flash with a swivel head and bounce some low-power flash off a ceiling or wall if you just want to avoid blinding people.
 stephenseriously's gear list:stephenseriously's gear list
Fujifilm X100V Fujifilm X-T30 Fujifilm XF 18mm F2 R Fujifilm XF 23mm F1.4 R 7artisans 35mm F1.2 +3 more
DirkPeh
I have good results with flash compensation dialed down -2 or -3 in similar situations.
That 90s in the face flash if done right is the flavour of the month anyway.
I never used the inbuilt flash of my cameras prior to owning the x100v, but with the x100, I have become a fan.
If using the flash, don’t use auto-iso!
Threaded Veteran Member • Posts: 4,180
The available light is the available light, if you want dim lights at your party then you have to accept the camera is going to have to compensate, either through high ISO, low shutter, wide aperture, or most likely a combination of all three.  The X100F’s lens can only go to maximum f2 which is ok but not great, bearing in mind that’s cutting out half the light available to an f1.4 lens for example.
Your only real answer is to increase the available light, either through switching on the flash, or turning those dimmer switches the other way!
 Threaded's gear list:Threaded's gear list
Fujifilm X-Pro3 Fujifilm X-E1 Fujifilm XF 35mm F1.4 R Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm XF 23mm F2 R WR
I will consider using flash. I would rather not, but it will be the only way. Thank you.
stephenseriously wrote:
Miskec wrote:
Hi all!
Thank you
Neven
Neven
I have red it before. Very encouraging.
topline takeaways:
Will shoot raw plus jpg and convert aome shots to colour after.
No illuminator light will be used, dont want to bother people
Maybe, it all depends how dark it will be
Thank you
Neven
DarnGoodPhotos Forum Pro • Posts: 11,881
A couple of things:
Short bursts instead of single shot. It's a good way to make sure you get the best facial expressions and body positions while people are dancing. If you are shooting groups of non-moving people then a burst will let you get one photo that is sharper than the others if you need to use a slower shutter speed.
Shoot Raw because it will let you underexpose by one or two stops when shooting, so you can have a faster shutter speed or lower ISO, and push the exposure afterwards with no extra noise.
Be prepared that your F have have a harder time acquiring focus if you try to get it on something lower contrast like faces so use something like the person's clothing and focus and recompose. You may even choose to shoot a little wider so you can crop afterwards. If you still cant acquire focus, angle the camera a little and then recompose.
There is nothing about your X100F which makes it fundamentally worse than an X-T2 for this kind of shooting. An f1.4 lens wouldn't be better because what good is faster aperture when it means that some people will be soft due to the shallower depth of field.
www.darngoodphotos.com
 DarnGoodPhotos's gear list:DarnGoodPhotos's gear list
Fujifilm X100V Fujifilm X-T5 Fujifilm XF 18mm F2 R Fujifilm XF 55-200mm F3.5-4.8 R LM OIS Fujifilm XF 27mm F2.8 +3 more
It's not my party, i can not control the light, only use availabe.
Yes, i know. It frustrates me when I realize x100 can not do the task and so far I used it for so many things. It allways did well.
Like i said, ghe dimmer is out of my reach 😀
DarnGoodPhotos wrote:
A couple of things:
Excellent tips! Thank you
I will try do do my best
Neven
It’s academic of course, and also entirely subjective, but I don’t agree with this - a 23mm 1.4 would work just fine for a party. Yes the DOF would be narrower at 1.4 but by no means problematic for most shots at a typical distance, and closer a little separation could work well to separate individuals or intimate small groups together. If it was me, and my X-Pro2, that’s the lens I’d be using. Not an option for the OP though obviously.
Re: Fuji x100 low light- done
Hi all! First off a big thank to anyone who chimed in on my topic. Photographing done yesterday evening, must say I am satisfied. The venue was fairly dark. I shot 1500 photos, ony a dozen using flash.  I tried go stay above 1/100 and the ISO was between 4000 and 128000. All shot in acros. Raw developed in fujifilm RAW studio with occasional 2/3 EV compensation.  Next time i will not let ISO go that high but 6400 ISO is perfectly fine. Many were 8000 and also good. I Shot in burst mode, and got a lot of keepers. Shots that I deleted were because of bad focus. Focus hunted but not many times. People were dancing and leaned towards me so i could not get the focus to follow them. Also, few photos were shot at 25600 iso (spinned the wheel accidentaly).also,  In all the comotion I bumped  the exposure comp dial to minus 3 and could not figure out what was wrong. I must say I used my x100f properly the first time. No messing with the settings, being low profile as possible and I think i have captured the mood of the party.
What would I change next time? Keeping ISO bellow 10000 ( i think that noise begins to suffer higher of 8000). Shutter speed 1/125 or higher. Maybe one auto iso setting for "portaits" with 1600 iso, SS 1/80 and I would use the flash. The other auto ISO 10000 and SS 1/200 for dancing floor.
Keeping my eye on x100 line, maybe get a V. Seems like a step up from F in terms of focus speed and lens sharpness.
To sum it up, the x100 is really fun camera to use. I will post a few photos shortly...
Neven
Photos - Fuji x100 F low light
Some photos...
ISO 10000, 1/200, f 2.0.
ISO 12800, 1/100, f 2.0.
ISO 1600, 1/60, f 2.0. - flash on
ISO 2500, 1/100, f 2.0.
ISO 10000, 1/125, f 2.0.
1/200, f 2.0. - ISO 25600 picked by my mistake...
ISO 12800, 1/200, f 2.0.
nysteveg Junior Member • Posts: 43
Re: Photos - Fuji x100 F low light
I am looking on a 14 inch screen on my Mac Book.  Your pictures look GREAT given the lighting limitations.  I also have a 100F and while trading up is tempting, how much would your pictures improve if they had been taken on a 100V instead?
 nysteveg's gear list:nysteveg's gear list
Fujifilm X100F Fujifilm X-T30 Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm XF 35mm F2 R WR Fujifilm XF 23mm F2 R WR +6 more
Thank you. As i wrote, the noise did not bother me at all. I would say 6400 was perfect and 10000 really acceptable. Only two highhest settings were a bit too noisy  The most challenging part was the focus. I used singe focus and back button focusing tehnique. I presume that switching to V would get you slighty better AF and sharper pics due to new lens. And tilt screen would make me even less noticable. Next time I will shòot iso 8000 max and maybe close the apperture only a smidgen. I will underexpose and brighten in post.
Thank you for looking
Neven
Neven
The V is definitely sharper a f/2 and at close range, but the F's sensor is a bit better in the noise department. As far as AF goes, I think you'd be well served to forget about BBF and just use AF-S single point, AF box on the subject (face sized in low light) and full-press the shutter button all the way down (no pause at a half-press). You will get the snappiest AF response and the exposure at the moment of focus acquisition not a split second later after you or your subject has moved enough to screw things up - this works on moving targets as well and is miles better than AF-C in low light with that camera too. Did you use Acros with or without a color filter? Your images look very nice and punchy, whatever you did. If you can turn off the artificial grain that is normally a part of Acros, that might be a good idea as you'll get plenty without it in that kind of light. I don't see ISO 12800 really being an issue with these kinds of shots, the noise looks OK in B&W and could certainly be cleaned up quite a bit with the RAW files if you wanted to. Your shots came out great in any case. Well done.
I'm not saying this necessarily looks better (you'd get better detail, less plasticky skin and fewer artifacts with the RAW) , but even these noisy jpegs can clean up pretty well if you want to dial down the grain a bit (yes, maybe dialed down a bit too much here)...
A few tweaks in Lightroom with a little Topaz DeNoise.
