App to rename images individually? (not batch)
Felix E Klee
Felix E Klee Regular Member • Posts: 394
I am looking for an app where I can swipe through images one by one, then rename them without going through a menu. Ideally the current image is displayed with a prompt underneath, showing its current file name, and which can be easily replaced.
 Felix E Klee's gear list:Felix E Klee's gear list
Sony ZV-1 +1 more
I2K4
I2K4 Senior Member • Posts: 1,441
Re: App to rename images individually? (not batch)
Piktures gallery app is free in the Play Store, rename from the "three dots" - probably not unique:
I haven't seen a "dedicated" single shot renaming app.  Some file managers will rename in thumbnail view.
Felix E Klee
OP Felix E Klee Regular Member • Posts: 394
Thanks for the suggestion, but exactly the menu is what I want to avoid. It is just tedious.
That sounds like an improvement, especially if one could increase the size of the thumbnails to fill the screen. (like in Bridge)
Sony ZV-1 +1 more
I2K4
Xplore (Lonely Cat) is free and dual pane (I prefer, others don't.) Decently viewable thumbnails (including DNG) and simply check its box for the center Rename button. Tap the image to bring up its own image viewer. I haven't used anything else for a while. (The user can adjust those center buttons up and down or remove them to personalize.)
Felix E Klee
Thanks, I just looked at it, but it's still too many buttons to press: long-press on file, select rename from the menu, and only then enter the name. Also, I first have to navigate to the DCIM folder.
Sony ZV-1 +1 more
