Problems with GPS tagging with new version of camera connect (R5)
SigZero
SigZero Contributing Member • Posts: 686
Hi all.
I have never had problems with GPS tagging via camera connect app, but with the last update (the new UI) everything changed.
Tagging still works - there is no problem with connection between camera and smartphone but the location stopped to be updated frequently - so all photos seem to be taken in clusters in single locations.
Last few days I was walking Amsterdam with my camera and all photos seem to be taken in 4 or 5 places. That's very disappointing. Can You confirm if Your setup also has that problem since update?
Im using EOS R5 with FW 1.6.0 and camera connect (iPhone 13 Pro) version 3.0.1.21
Br, Pawel
My photo-blog: http://pawel.online
 SigZero's gear list:SigZero's gear list
Canon EOS R5 Canon RF 100-500mm F4.5-7.1L IS USM Canon RF 70-200 F4 L Canon RF 14-35mm F4L IS USM Apple iPhone 13 Pro
Canon EOS R5
apersson850 Senior Member • Posts: 2,076
Re: Problems with GPS tagging with new version of camera connect (R5)
You use this method because the R5 doesn't have any built in GPS, like the R3, right?
Anders
 apersson850's gear list:apersson850's gear list
Canon EOS 40D Canon EOS 400D Canon EOS 7D Canon EOS-1D X Canon EOS-1D X Mark II +26 more
SigZero
OP SigZero Contributing Member • Posts: 686
Yes.
I've also have GP-E2 GPS module which works perfect, but I prefer smartphone solution as it is more compact (and I have my phone with me always when making photos)
Br, Pawel
I don't need it, as the cameras I use nowadays have GPS built in. Do you have any feeling for if the communication between phone and camera only happens rarely, or if it could be the positioning service in the phone that just updates now and then?
I'm trying to understand if the problem is that the phone doesn't know better, or if it does, but just doesn't tell the camera frequently enough?
Anders
Quarkcharmed
Quarkcharmed Senior Member • Posts: 2,713
SigZero wrote:
Hi all.
Br, Pawel
Not sure how it works with iOS, but with Android, you'd need to give the app the permission to use GPS while in the background.
But it could well be a bug in the updated app.
 Quarkcharmed's gear list:Quarkcharmed's gear list
Canon EOS R5 Canon EF 70-200mm F2.8L IS II USM Canon EF 24-70mm F2.8L II USM Canon EF 16-35mm F4L IS USM Canon EF 50mm F1.8 STM
koenkooi Contributing Member • Posts: 920
SigZero wrote:
Hi all.
I've had that problem for years with the Camera Connect app, using various cameras (M6II, RP, R5) and various iphones.
 koenkooi's gear list:koenkooi's gear list
Canon EOS 7D Canon EOS M Canon EOS M6 II Canon EOS R5 Canon EF 85mm F1.8 USM +20 more
PicPocket Veteran Member • Posts: 5,897
The problem is more likely to be phone side rather than camera. The first thing to check would be that your location permissions fot the app are set to "Always"
Related thread -
https://www.dpreview.com/forums/post/66432856
PicPocket
 PicPocket's gear list:PicPocket's gear list
Canon EOS R5 Canon EF 24-70mm F2.8L II USM Sigma 135mm F1.8 Art Canon RF 70-200mm F2.8L IS USM Canon RF 100-500mm F4.5-7.1L IS USM +16 more
Tom Bak New Member • Posts: 11
not new, beware of missing time sync
That problem has existed at least for some months now. Even when the app is set to "always" allow connections.
Hint:
You should be aware of the fact that when using only a Bluetooth connection, the camera time is not updated according to GPS time, even though then the camera will not allow you to set time manually.
The only way to sync mobile and camera time is when both bluetooth and Wifi are connected and you explicitly (one-time) push the time from the mobile to the camera.
SigZero
Re: not new, beware of missing time sync
Sure, my app is set to have access to GPS data "always". That also makes it work in the background.
It show the BT connection all the time, so it's not problem o loosing connection between smartphone and camera. With the same firmware in camera (1.6.0) the previous version of Camera Connect worked correctly - all photos were tagged with exact position they were taken.
But still - I see that people had this kind of problem also with older version of Camera Connect, which I did not have.
Br, Paweł.
Hint:
Bigger Contributing Member • Posts: 640
I have seen this problem too with the old version and my R5, and don't have a definite solution. The one thing I have tried is using a GPS or Navigation app to keep the phone constantly updating the GPS position. I'm not sure if the problem is that the Canon app doesn't query the GPS too often to save battery, or if it doesn't communicate it frequently enough to the camera.
 Bigger's gear list:Bigger's gear list
Canon EOS 5DS R Canon EOS R5 Canon EOS R7
Br, Paweł.
Hint:
GP-E2 works better in that regard.
Or you create a tracklog on your phone with OSMAnd (free), which is very precise, and then sync it on PC.
L_David Junior Member • Posts: 29
SigZero wrote:
Hi all.
Br, Pawel
I have the exact same problem with my Canon R6 and Camera Connect, with both the old version and the new version of the app, I've seen no change (iPhone 11 Pro Max). The only way that I can get correct GPS information while I'm walking around is to keep turning the camera off and on all the time, otherwise I just get the location when the camera was first turned on for all pictures. The camera is always perfectly connected to the app, it's not a connection issue. https://www.dpreview.com/forums/thread/4667994
RDM5546
RDM5546 Senior Member • Posts: 3,654
If turning your camera off and on between locations you have a workable solution IMO. The alternative is a clunky thing on your hot-shoe or a hassle to merge phone data in post.
I have the GP-E2 for your hot shoe. It is expensive and bulky. I got the EOS R cameras after Covid came out in 2020 so my traveling has been limited in the last few years.
The 5D mk IV, 7D mk 2 and 6D mk 2 are great old school dslr and they has GPS built in. It sure was nice. Now only the expensive R3 of the Canon mirrorless cameras has built-in GPS.
 RDM5546's gear list:RDM5546's gear list
Canon RF 100-500mm F4.5-7.1L IS USM Canon G5 X II Canon EOS 70D Canon EOS 7D Mark II Canon EOS 5D Mark IV +47 more
robgendreau Forum Pro • Posts: 10,917
I gave up on real time geotagging with an app for the reasons commonly cited.
But I'm wondering if that's the still the only way to use the app to geocode. On an Olympus one keeps the Oly app on and tracking on the phone, but with NO connection to the camera. Then, later, one connects to the camera and syncs, which writes to the images IN the camera. Basically like one does on a computer and a synced GPX file as in Lr, but in the camera. I found it a great compromise, since real time is often unreliable for me.
Or has anybody developed a non Canon app that can do that?
 robgendreau's gear list:robgendreau's gear list
Pentax 645Z
Victor Engel Forum Pro • Posts: 20,968
You're describing the behavior I noticed with the previous version. I tried it and decided to fall back on my tried and true method for geotagging: Use the Viewranger app on my phone to log a gps trail. When I'm finished with my trip, I take a photo of the Clocks app. Then I use Houdageo to sync the log with the photos. Houdageo by default, uses the last image to sync the time. Since in my routine, it's a picture of a clock, I simply enter the time displayed on the clock. All the photos are tagged with coordinates interpolated from the gps log I recorded. It has worked perfectly every time I've tried it. The resolution is as good as I choose it to be in the Viewranger app.
I realize Houdageo is a Mac-only app. I'm sure something similar exists for other platforms. Anyway, this is far more reliable than Camera Connect and doesn't use Bluetooth.
Victor Engel
 Victor Engel's gear list:Victor Engel's gear list
Canon EOS 5D Canon EOS 5D Mark II Canon EOS 600D Canon EOS 5DS Canon EF 50mm F1.8 II +13 more
Kameratrollet Senior Member • Posts: 1,099
I have both M5 and R6 in my Camera connect app. In the app choosing M5 GPS the GPS on the phone is on the whole time and gives me correct positions through Bluetooth when I use R6.
I get a notification sound every time I turn on R6.
Stakeouttoo
Stakeouttoo Senior Member • Posts: 1,297
and that's one of my biggest gripes with Canon not including built-in GPS on their new mirrorless cameras.. we travel a lot these days.. long cruises of 50+ days at a time.. just did the Med 64 days 50th anniversary cruise with my R7 and my 17-40L-- a nice lightweight travel combo for me personally.... just don't want to get involved syncing this--syncing that.. sometimes it works sometimes it doesn't with the Canon Connect app or a separate geotagger unit attaching it to the camera.. mind-boggling that Canon would stop including the built-in GPS in their high end overpriced mirrorless cameras like on my 6DMkII with its built-in GPS
Ray
my Canon 6DMkII sure beats using that ol' Petri 7s 35mm back in 1967 in RVN
 Stakeouttoo's gear list:Stakeouttoo's gear list
Canon 6D Mark II Canon EOS R7 Canon EF 17-40mm f/4.0L USM Canon EF 70-300mm f/4-5.6L IS USM Canon EF 70-200mm F4L IS USM +13 more
I desperately tried to find reasons not to spend money on an R3 I didn't really need. Early reports that the rear buttons were not illuminated, like on the 1DX Mark III, saved me for a while, but they turned out to be false.
Then I tried to cling to the hope that reports of the R3 lacking GPS would save me, but alas, they were also false.
So here I am...
Anders
Sittatunga Veteran Member • Posts: 5,406
I was thinking about a second-hand Canon GP-E2, then I started looking at a Chinese GPS unit with an LCD readout.  Then i realised it cost more than I want to pay for a smartphone...
RDM5546
The GP-E2 works for compass on the R5 and R7 hotshoe. It does not support the compass heading like it does on some of the older models (I like the compass data). Maybe the R5 mk II will have GPS and a compass. You can buy the GP-E2 used for around $150. I like because it works and requires no cables.
There is a cheaper Solmeta for $129. https://www.solmeta.com/Product/show/id/19
However, the website says the Solmeta does not work with Canon Mirrorless (R,R5 etc) cameras.
I know some people on the forum has used the Solmeta in the past. I would rather have the GP-E2 that I trust as long as it is turned on the it shows a lock on the read LCD "GPS" icon on one of the info screens (the busiest one). It works on my older dslrs like the 70D.
The 7D2 and 5D mk IV both have the GPS built it like a professional camera should. My smartphone has GPS built into the EXIF data.
