Re: High IQ BUT Awkward to use
Jan Steinman wrote:
cba_melbourne wrote:
Cyvan wrote:
erichK wrote:
I find that almost anytime I use this lens, it is usually set to the wrong focus-range, and quite awkward to change. Like its image quality, but capturing the image comes first.
What I do is set the focus limiter straight to 1:1 then move in closer to the subject until its in focus. MF ofcourse or Single Focus if I want the camera to lock in at the last moment.
After awhile you get a sense of the distance 1:1 represents.
The reason the lens has a 1:1 focus setting is this:
As long as you do NOT change focus away from 1:1, and only focus by changing the distance to the object, you can take measurements of objects in the picture - without having to place a ruler besides it before taking the picture.
This is why the Telescoping Extension Tube I mentioned — as well as almost all bellows used for macro — has a millimetre scale on it.
With the millimetre scale and the focal length of the lens, one can always calculate the final reproduction ratio. This is because in the past, macro was very often used for scientific photography.
Yes, and you could measure distances directly on the film using a graduated loupe. I still have this excellent Swiss made 8x F+C Optik model, sadly it does not get much use anymore today
However, you still had to determine a correction factor for your individual lens sample. Back then lenses had even greater focal length tolerances than today. Today the FL tolerance is only about +/-3%.
Measuring distances on a print was much harder, not only because the lens used in the enlarger also had a focal length tolerance and distortions on it's own. But the photographic print paper did also shrink/expand considerably depending on moisture, up to 10%. Later RC papers had easily 10 time less expansion with humidity.
This is still possible with modern electronic lenses with software that lets you read all the EXIF data, including the focus distance.
Yes, the free EXIF tool (https://exiftool.org/) will give you this information. You have to remember to turn off the lens corrections in the PP software, then you can measure directly on the display monitor.
But, remember you need to determine separate correction factors for your individual lens for every magnification you intend to use. Because focal length of macro lenses can change dramatically, up to 100%, at closeup distances!!!And now you hit a huge problem with modern fly-by-wire lenses: how do you determine the magnification? With the 60mm it is easy but only if you preset it to 1:1 with the limiter and do not touch the focus anymore. Any other setting and you introduce a huge error because the readout scale is way too coarse. And you cannot read the accurate exif data, before having taken the picture in the fist place
If you use microscope camera software, it lets you even measure with the mouse on the screen. Now that is very comfortable and fast, since you can zoom-in to measure accurately and the software automatically takes the zoom factor into consideration. Still have to calibrate your lens the first time though.
