Capture 1 2022 and Ventura
Simon57 Junior Member • Posts: 36
I have a problem with Capture 1 Pro 2022 and a M1 MacBook Pro running Ventura 13.0.1 When I put in an SD card and do import it does not find any pictures. If I use a M1 MacBook Air running Capture 1 Pro 15.3.0.109 under Big Sur, it works fine.
JPAlbert Senior Member • Posts: 1,290
Re: Capture 1 2022 and Ventura
This may or may not help.
I believe that Ventura has some new "feature" by which the user must give permission before the OS will connect to USB drives, etc.
Have you looked into this?
(I'm not a Ventura user, just something I read about it)
OP Simon57 Junior Member • Posts: 36
I will have a look at this thanks,
