DynV wrote:
I have a 3D camera with an attachable viewer but looking at its 3D content uses about the same battery as taking it; I'd rather use the battery the least possible as I know it has a limited # of cycles. I've looked for affordable 3D viewing, both VR headset and monitors, in vain. I know there's non-dedicated solution like Google Cardboard but I don't know its effectiveness.
I've been thinking that even though my FreeSync 4K monitor with 1ms response, a U28E590D, is not made for viewing 3D that maybe there's a way for my SBS (side-by-side) 3D content to be shown in 3D on it since the bottom half of it is free to display something else during that viewing, as it's currently doing (another window content or the rotating background of my desktop), and that bottom half could be showing an indicator for which eye is to be hidden and that 3D polarizing glasses would detect it and act accordingly.
The polarizing shutter glasses react to either an infrared trigger pulse (Samsung, older Sharp) or a proprietary 2.4GHz signal (newer Sharp). You need a monitor that supports backlight strobing, because your 1mS freesync has way more than 1mS persistence, a quad buffered video card (not cheap) that supports sending trigger pulses to the glasses, and older drivers (nVidia, for example, stopped adding sequential 3D support to their monitors around 2019.
So that after installing the 3D polarizing glasses driver or 3D viewing software, viewing the 3D content without those glasses the bottom would be showing switching content from black to another color (ie white), through the 3D polarizing glasses the bottom would only be black.
You would have to build a device that could target the bottom of the screen and then rebroadcast the sync signal in a format compatible with your glasses.
I assume since the total response time for the 3D content would be 2ms, that it would be slower than with a specialized 3D monitor,
That assumption is both correct and incorrect. Good 3D monitors have strobed backlights, so they could even be 8mS response and be just fine.
I could just move my head & eyes slower and doing so would result in something quite close to if I'd move as slow on a monitor made for 3D viewing.
You lost me.
Thank you kindly for your assistance
Update 1
For an example of the content I referred to, see the playlist SBS 3D of my channel.
The term "mirrorless" is totally obsolete. It's time we call out EVIL for what it is. (Or, if you can't handle "Electronic Viewfinder Interchangeable Lens" then Frenchify it and call it "LIVE" for "Lens Interchangeable, Viewfinder Electronic" or "Viseur électronique").
Stanley Joseph Wisniewski 1932-2019.
Dad, so much of you is in me.
Christine Fleischer 1947-2014.
My soulmate. There are no other words.
Rahon Klavanian 1912-2008.
Armenian genocide survivor, amazing cook, scrabble master, and loving grandmother. You will be missed.
Ciao! Joseph
www.swissarmyfork.com
