Help - 55-200 vs 56 1.2
britcam
britcam Senior Member • Posts: 2,583
Re: Help - 55-200 vs 56 1.2
bowportes wrote:
I sold my 55-200 because I rarely carried it due to it's size and weight. The 56mm is shorter and lighter and has better subject isolation. I still use it for portraits, but decided I preferred the 50-230 to the heavier 55-200.
I guess the 50-230 is ok if you're happy with f/4.5-6.7 maximum aperture and you shoot in bright conditions. Otherwise, as I found, it needs a good contrasty target to focus on, or you experience focus "hunting" ..
https://www.matthewstorerphotography.com/blog/post/fujifilm-xf-55-200mm-vs-xc-50-230mm
Regards
Rich S
 britcam's gear list:britcam's gear list
Fujifilm X-E2 Fujifilm X-M1 Fujifilm X-S10 Fujifilm XF 35mm F1.4 R Fujifilm XF 60mm F2.4 R Macro +8 more
brownie314
OP brownie314 Senior Member • Posts: 2,139
I ordered a ttartisan 50mm f1.2.  It was way cheap and from all the discussion here - you pretty much have to manual focus the Fuji 56 anyway.  I has not arrived yet - but all the reviews say it is good - not quite as good as the Fuji 56 - but also - for $100 a good deal.  With that - I can also get the 50-230 or stretch to get the 55-200
 brownie314's gear list:brownie314's gear list
Fujifilm X-T2
Martin_99 Veteran Member • Posts: 4,651
If you finally decided for portrait lens, very good option is Sigma 56mm f1.4. If you are not used to manual focusing, it will not be easy with f1.2 lens. Nevertheless enjoy your new lens!
 Martin_99's gear list:Martin_99's gear list
Sony a6400 Sony Carl Zeiss Sonnar T* E 24mm F1.8 ZA Sigma 56mm F1.4 DC DN | C (X-mount) Sony E 70-350mm F4.5-6.3 G OSS Tamron 150-500mm F5-6.7 Di III VC VXD +1 more
Phil BH Senior Member • Posts: 1,043
Re: Top line
brownie314 wrote:
well - I think of the 55-200 as the analog to Canon (or Nikon) 70-200 f/4 lenses. The f/2.8 zooms were the pro lenses - but the f/4 versions were just as sharp - just missing the range from f/ 2.8 - 4.
Actually, before the redesign of the 2.8 model, the Canon 70-200 f/4 L IS was the sharper of the two. I have had my f/4 L for 16 years.
I bought my wife the 55-200 and it is truly a wonderful lens. The choice between the two on your radar is difficult since they are two completely different lenses for completely different tasks. Thanks being said, as long as you like zooms, and aren't looking to go to just prime lenses, you already have 50mm covered. If you think you want to have a longer lens, the 50-200 would be a great choice. I use all prime lenses, but I love the 50-200.
Phil
Clive99 Senior Member • Posts: 1,389
The old xf56 focuses just fine on my xt3. Just don't plan on it for sports. I think the "issues " are a bit over blown. It's slower on my xe3. More of an issue with the older cameras.
 Clive99's gear list:Clive99's gear list
Fujifilm XF10 Fujifilm X-E3 Fujifilm X-T3 Fujifilm XF 18mm F2 R Samyang 8mm F2.8 UMC Fisheye +16 more
brownie314
I am right on the border of 'older camera'.  I have an x-t2 body.  My understanding with AF is - 'better than x-t1, but light years behind x-t3'.
Fujifilm X-T2
My XE3 is the same generation as your XT2. As i said above - the XF56 focusses much better on the x-trans IV (XT3/XT4/XE4) generation than on the x-trans III (XT2/XE3) generation.
Erik Baumgartner Senior Member • Posts: 6,894
I wouldn’t say that at all. I’d say the X-T2 is light years beyond the X-T1, and the X-T3 is a little better. I have no trouble whatsoever focusing the old 35 and 56 on my X-T2.
Sony RX100 Fujifilm X100V Fujifilm X-T2 Fujifilm X-T20 Fujifilm XF 35mm F1.4 R +5 more
brownie314
Well, as I said - I ordered the ttartisan 50/1.2.  I got it yesterday and shot it today.  It is pretty good.  Not bitingly sharp at f1.2 - but that is to be expected.  The manual focus - I think it is about as good as manual focus can be.  The focus peaking helps a lot.  I was able to get most images in good focus.  When stopped down to f2 and beyond, the sharpness goes way up and the focus gets more forgiving.  I do find I miss autofocus.  But - for $100 - I think I can live with manual focus.  And since it was so cheap - I think I can stretch just enough to get a used 55-200.
I have to say - I have had the x-t2 for a while now with just the 16-50 lens.  I have been somewhat underwhelmed with that combination (yeah, I know - predictable).  But - the x-t2 with the fast near tele prime - it is a really really great combo.  As long as things are not moving too fast - this combo makes some really nice images.
Fujifilm X-T2
Solomon
Solomon Senior Member • Posts: 2,160
I've got both lenses. The TTAritisan 50mm f/1.2 is an incredible value. But if anyone told you it was in the same class as the Fujifilm 56mm f/1.2 R, they misled you. It is not. And there is no problem with autofocus of the 56 R. Newer lenses focus quicker, but that does not mean that the 56 has a problem.
Sol
 Solomon's gear list:Solomon's gear list
Fujifilm X10 Panasonic Lumix DMC-LX7 Fujifilm X-E2 Fujifilm X-T3 Fujifilm XF 18-55mm F2.8-4 R LM OIS +6 more
brownie314
I also now have the 55-200 on order.  I know many here have said the 50-230 is probably as good and less expensive - but I am indoors a lot and I will need all of the aperture I can get
Fujifilm X-T2
Really, 55-200 for indoor shooting? I would say that both lenses are slow for that. Also is 200mm needed for indoor? 🤔
gdanmitchell
gdanmitchell Veteran Member • Posts: 7,991
To the OP:
When looking at such radically different lenses, I think you need to step back and ask yourself how you'll use the new lens and let that drive your decision. Those are such different lenses in almost every way, that the open question is sort of like asking, "should I get a truck or a sports car?" It depends.
I had the 55-200mm lens at one time. It has its pluses and minuses, and it is well suited to some kinds of use and not so well suited to others. First, the...
PLUSES — Inexpensive. Packs very small. Covers a fairly large focal range. Gets out to quite long at 200mm, the angle-of-view equivalent to 300mm on FF. Has IS.
MINUSES — It isn't the most solidly constructed lens. When I had it, there were sometimes issues getting it to AF successfully at 200mm with low-contrast subjects. Because of the variable aperture design, you don't have many useful apertures between "wide open" and the onset of diffraction blur at 200mm.
Who is it for? It can be a fine lens for travel, where you often want to get maximum coverage from smaller and lighter lenses, and this one packs quite small. It pairs well with lenses like the 18-55mm kit lens.
The 56mm f/1.2 is about as different a lens from that as you can imagine, excepting that its focal length is within (barely) the range of the zoom. I do not own the lens, so my thoughts are based on what I know about it and experience with similar lenses.
PLUSES: The lens is well constructed. It obviously will do well in low light with that huge maximum aperture. It can control depth of field and produce narrow DOF.
MINUSES: It isn't cheap, though I think it may be on sale right now. It it is regarded as being a bit slow to AF — though so is the 55-200. It is a pretty big and heavy prime. Obviously, it doesn't have the functional flexibility of the zoom.
Who is it for? People looking to closely replicate the function of the large aperture 85mm "portrait" lenses on FF systems. Possibly for people photographing handheld in very low light.
When in doubt, doubt.
www.gdanmitchell.com
Powerdoc Veteran Member • Posts: 3,941
brownie314 wrote:
OK - I know - WTH right? Why even compare these two - they are apples and space ships.
OK - I am on a limited budget. I have an x-t2 and a 16-50 (not 16-55). I am making my first major lens investment in Fuji.
I don't have a tele option on my x-t2. I really miss that option from my Nikon days.
I also don't have a really great portrait lens. I also miss that from my Nikon days.
Photography is definitely a hobby for me - a hobby that has been sidelined for a few years now. I mostly just shoot candid images of my family (wife, kids, extended families). I do some studio head shots (I have some strobes and triggers).
The 56 would be great and match my style of taking candid shots of people as they do things. But - man - I really miss being able to throw on the tele and go out and get some really great people and landscape shots with a very versatile lens.
The other reason I am comparing these two is I can get either of them for around the same price (used of course).
Biting fingernails here - don't know which way to go.
56 mm isa portrait lens , the other is a zoom. The zoom can do portrait, at the wide end It's a sharp zoom, not as good as the 50-140 but still a great performer.
If you just practice portrait the 56 is fine, but if you want a more versatile lens , the zoom is the way to go
It's all about photography
 Powerdoc's gear list:Powerdoc's gear list
Fujifilm X-T1 Fujifilm X-H2S Fujifilm X-H2 Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm XF 27mm F2.8 +13 more
brownie314
maybe you don't know that volleyball, swimming, gymnastics - all happen indoors?
Fujifilm X-T2
brownie314
I also feel like - since this is a fuji x forum - there is a bias towards prime lenses - more so than there would be in, say - a Canon R mount or Nikon Z mount forum.  I am coming from Nikon F mount DX.  So, while not prime lens level IQ - I am sure the 55-200 will be more than what I was used to on Nikon F mount with the plastic 55-200 lens (although it wasn't that bad either).
Fujifilm X-T2
sir_c Contributing Member • Posts: 740
The 55-200 has a linear motor it I am not mistaken. It focuses much faster and more confidently than the 56/1.2. The latter uses a DC motor and has to move a lot of glass. Under circumstances where it matters, the difference is very noticeable.
 sir_c's gear list:sir_c's gear list
Fujifilm X-T1 Fujifilm X-T4 Fujifilm XF 35mm F1.4 R Fujifilm XF 14mm F2.8 R Fujifilm XF 18-55mm F2.8-4 R LM OIS +5 more
I saw no mention about indoor sport in your post, I expected outdoor use. I shoot indoor sport only rarely, but I think, that lens with faster aperture would be certainly better, as there is often not much light.
From my example of table tennis shot, you can roughly calculate what parameters you would need to use with 55-200 in the same conditions.
Shutter speed is set to 1/500 (reasonable minimum)
Aperture f1.4, lets say, that you would use f4, it means...
...that instead of ISO 800 you would have ISO6400, which is usable, but far from optimal on apsc sensor.
I would recommend to rather buy 50-140f2.8 or 90mm f2 for this purpose (or maybe even Sigma 56f1.4 as me).
f1.4, 1/500s, ISO800
brownie314
I plan to use the 50mm f/1.2 manual focus lens for high shutter speed indoor sports.  I know it isn't ideal - but if you can anticipate where the action will be - it can work out.  I tested it outdoors with my erratically running daughter - I kinda knew she would be running to a certain location and focused on that location - and when she got there - I took the shot mid-run.  It worked out well in that situation.  I imagine for table tennis it might work out too - since the action will likely be kinda predictable.
Fujifilm X-T2
gdanmitchell
I haven't seen the entire thread, so this may have been mentioned already, but...
... manually focusing on sports, etc. is not ideal. Sometimes, even with AF lenses, the pre-focus solution is appropriate, but it isn't typically the kind of technique that you want to use  on a regular basis.
