Never ever try a PRIME lens.. Going back to a ZOOM, you get too obsessed w. IQ
gaul Senior Member • Posts: 1,505
Hello,
My ZOOM on a Full-Frame, Canon EF 24-105mm f/4L IS II USM is certainly no match for a F/2.8 zoom, but it's supposedly a very popular lens, used by pros and amateurs to great results..
This EF 24-105 Mk ii .. as a reminder.. is an "L" lens after all..
BUT ..
As soon as I compare with ANY of my PRIMES, "L" or "non-L" lens, even these cases tech USM lenses... well, the IQ from ALL of my PRIMES will obliterate what I get from the ZOOM..
VS
All of these PRIMES will absolutely smash the ZOOM at DETAIL level at least
To be clear, I have thought I would be harsh and compare the PRIME at 200% rendering vs the ZOOM at 100% rendering..
Well, in every case, it's about what I get in terms of DETAILS..
i.e. my EF 135 F2 on the same scene at 200% on my screen shows even more detail than than EF 24-105 at 100%
Is this my copy of this Canon EF 24-105mm f/4L IS II USM?? or is this expected?
Only good result from my ZOOM, the Canon EF 24-105mm f/4L IS II USM outputs a very good colour rendition.. And yes, if you keep the image small, it does look pleasant enough.. Still, now I have done these comparisons, cannot force myself to come back to my ZOOM ...
Really going to turn into a "Prime snob" I think
Thanks for your feedback, rgds, Gaul
 gaul's gear list:gaul's gear list
Canon PowerShot S30 Canon PowerShot G1 X Canon EOS 6D Panasonic Lumix DMC-GM5 Canon EF 50mm F1.4 USM +7 more
Scott Larson Veteran Member • Posts: 7,505
Re: Never ever try a PRIME lens.. Going back to a ZOOM, you get too obsessed w. IQ
The exceptions are the 70-200mm f2.8 II and the 24-70mm f2.8 II. These two are as sharp as primes and I shoot almost entirely with primes.
 Scott Larson's gear list:Scott Larson's gear list
Sony RX10 IV Canon EOS 5D Canon EOS 5D Mark II Canon EOS-1D Mark IV Canon EOS-1D X +17 more
neilt3
neilt3 Veteran Member • Posts: 3,011
It's hard to comment on the performance of your lenses when you don't provide any sample shots .
I have the 24-70mm f/4 L and 24-105mm f/4 L ( original version ) and I'm happy with the results .
I have several prime lenses that are within or close to those F/Ls (or just over) , and seem every bit as as good and possibly better , but certainly don't put the zooms to shame .
 neilt3's gear list:neilt3's gear list
Minolta DiMAGE 7 Minolta DiMAGE 7Hi Konica Minolta DiMAGE Z5 Konica Minolta DiMAGE A2 Konica Minolta DiMAGE A200 +68 more
(unknown member) Senior Member • Posts: 2,349
gaul wrote:
Hello,
BUT ..
VS
At this stage, it's just an opinion.
I am not judging right or wrong, but only an opinion.
Tannin Senior Member • Posts: 1,510
Cough cough: 100-400 II Stands up in any company.
(And I speak as owner or past owner of 600/4 II, 500/4, 100/2.8L macro, 35/1.4L, Tamron 85/1.8, EF-S 60/2.8 macro, 400/5.6L. The 100-400 II is just an awesome lens.)
 Tannin's gear list:Tannin's gear list
Canon G9 X II Canon EOS-1D Mark IV Canon EOS 7D Mark II Canon EOS 5DS Canon EOS 5DS R +10 more
gipper51 Veteran Member • Posts: 5,904
7
I think "obliterate" and "smash" are a bit of poetic hyperbole here. I won't argue that primes offer better image quality than zooms, but for the better zooms out there (like the 70-200L class, or latest 16-35L or 24-70L versions) the differences aren't that dramatic any more. At least in terms of central sharpness wide open. Stop any of them down to f5.6-f8 and you'll have to 'peep hard to spot the differences across the whole frame from the primes listed.
The caveat is that zooms are far more complex and are much more prone to copy variation. Zooms will often have a weak point in the range, and where it occurs can vary between copies of the same lens. Doesn't mean it's bad, that's just reality. Primes are simpler beings and only have one focal length they need to be good at.
Your 24-105 is certainly going to be outclassed by any of the primes when both are shot at f4. But it shouldn't be terrible ("terrible" is subjective, and you appear to like exaggerated adjectives). If it really is that bad, then perhaps you have a faulty copy or your camera is missing focus and the lens needs MFA adjustment.
Center sharpness wide open should be at least close to any of the primes listed here (edges and corners are a different story). If that's not the case, check focus on a tripod with live view. If it's still mush, I'd say a bad copy.
 gipper51's gear list:gipper51's gear list
Canon EOS 5DS Panasonic Lumix DMC-GX85 Canon EOS R6 Mark II Canon EF 85mm F1.8 USM Canon EF 135mm F2L USM +20 more
Canon_Guy
Canon_Guy Senior Member • Posts: 1,489
gaul wrote:
Hello,
BUT ..
VS
First question: are we photographing or pixel peeping ? These are two different worlds. Since I assume the first is the theme here, the first question should be what print sizes are you speaking about?
24-105/4 II is a great lens although is has some flaws. But its price/performance/versatility ratio is just great. I did use that lens for years, I was very satisfied with it and have lot of beautiful shots with it. Now I have its RF sibling which is a bit sharper in general.
I also have top notch primes 40/1.4 and 105/1.4 but in 99% of cases I use them in situations I want to have a shallow DoF and effects resulting from it, or when there is not enough light. My casual max print size is A3, majority I print on A4s. From the sharpness and details point of view there is literally zero difference on A4 and may be a very small difference on A3 but only when comparing side by side - speaking about the golden ration area of the frame. Corners might be the differentiator. If I was given a random A3 print, I would hardly be able to tell if the picture was taken by RF 24-105, EF 70-200/2.8 II or 104/1.4 if I should only judge by sharpness and detail in the golden ratio frame area.
 Canon_Guy's gear list:Canon_Guy's gear list
Canon EOS R6 Canon EF 70-200mm F2.8L IS II USM Sigma 14-24mm F2.8 DG HSM Art Sigma 105mm F1.4 DG HSM Art Canon RF 24-105mm F4L IS USM +6 more
OP gaul Senior Member • Posts: 1,505
Yes, this is probably "Pixel peeping" from my part..
Canon_Guy wrote:
gaul wrote:
Hello,
BUT ..
VS
Have re-engaged with photography for the last few years and yes, while improving my skills and my kits, sometimes I reach what I think is a malfunction but is in reality only a material limit of the kit and need to come back to realistic expectations
And yes, my tests only apply to "my" lenses.. Will have to get a professional to check my EF 24-105 Mk ii..
Thx, Gaul
Just got an EF 100-400 Mk ii (not yet opened) so will revise my "tests"
Yes, probably a bad copy - Maybe best to buy primes as USED and zooms as NEW
Bought this zoom as 2nd hand
Similar experience with a 24-70 f/2.8 Mk ii where the pics were also very disappointing
Maybe best to buy primes as USED and zooms as NEW.. more fragile
Thx for your advice, rgds, Gaul
Re: Yes, probably a bad copy - Maybe best to buy primes as USED and zooms as NEW
Many of us would like to see your "very disappointing" pics because my 24-70mm f2.8 II is having no trouble next to the primes I shoot with in basketball.
Will T
Will T Regular Member • Posts: 425
Try against the EF 200-400mm f/4 L IS USM!
You will think differently.
Will T.
"Galleries don't hang DxO charts" David Hull
I wish ...
Rodger in Edmonton
Rodger in Edmonton Veteran Member • Posts: 4,601
gaul wrote:
Hello,
BUT ..
VS
The foot mobile will force you back.
Primes are generally sharper but one has conceded range so the foot focus wheel has to kick in and getting great composition with a foot focus is much harder than a zoom frame.
When I was younger, I would head out with the F 135 and while I came back with great shots - I missed many more  because I can't reframe street fast enough on foot or at public events - a set stage like a gym mat wrestling match is ok.
So I am with you but we have to pack the zooms too and that will eradicate all primesnobitis
Best Regards, Rodger
Save Lives - Be an Organ or Stem Cell Donor.
Quaecumque vera
Klaus dk
Klaus dk Veteran Member • Posts: 9,760
Congratulations with finding what motivates you.
Good luck and good light.
 Klaus dk's gear list:Klaus dk's gear list
Sony RX100 II Canon EOS R Canon EOS R5 Canon EF 16-35mm F4L IS USM Canon RF 24-105mm F4L IS USM +7 more
John Crowe
John Crowe Veteran Member • Posts: 3,476
Ten primes, one zoom!
I made this same discovery in 1988 after 5 years into photography.  I have used some of the extremely good zooms over the years but have settled on 10 primes and one extremely good zoom.
There are more high resolution zooms available today than forty years ago, but there are still many poor ones.
Your L II is a huge step up from the original.  It will have a sweet spot in focal lengths and aperture.  I determined what those are for my EF 70-200/4 L and stay in that range when I can.  Sometimes zooms are just a necessary compromise that cannot be avoided.  Sometimes getting the photo is more important than not getting it at all!
Canon EOS 5DS R Canon EF 70-200mm F4L USM Canon TS-E 17mm f/4L Kenko Teleplus Pro 300 AF 1.4x Venus Laowa 12mm F2.8 Zero-D +15 more
trungtran Senior Member • Posts: 1,747
Was true 30 years ago. Zooms have caught up but will always been a compromise, and the reason you use them is for convenience.
I normally have a 24-105 on as well or the 28-75. But I took the 40mm this past weekend. I did it for size and not necessary IQ.
 trungtran's gear list:trungtran's gear list
Olympus OM-D E-M10 Sony a7 II Canon EOS M6
davel33 Senior Member • Posts: 2,978
I have a few questions if you dont mind
#1 Do you crop a LOT,  size and how often ?
#2 When you made this comparison how much did you enlarge them, 100% ?
#3 What res is your monitor ?
I use two Asus ProArt 24" at 1920 x 1200 = 2,304,000
My R6 has a 20mpx sensor 5472 x 3648 = 19,961,856
My Canon photo printer will print 13x19 at maybe that res at max dpi, I would have to check but the amount of ink would bankrupt me
BUT  I do sorta agree with you   When I bought my R the first lens's were all primes rf35 rf1.8, rf 50 f1.8 and RF 85 f2.
I like to do my composition in camera as much as I can which can be hard to do with primes.
I am asking because I was an electrical engineer and one thing that I had to learn the hard way is a closed mind never gets better**, so I ask a lot of questions
Thank you
Dave
** Your mind is like a parachute it MUST be open to work
"Just one more Lens, I promise....."
Dave
 davel33's gear list:davel33's gear list
Canon EOS R Canon EOS R6 Canon RF 35mm F1.8 IS STM Macro Canon RF 24-240mm F4-6.3 Canon RF 85mm F2 Macro IS STM +29 more
Thank you
Dave
Hi Dave,
Yes, I was doing "pixel peeping"
32inch 4k Monitor and yes at 200%
Yes, yes, I am at fault, I confess...
Still, my PRIMES (all of them) did shine more from F/4 to F/5.6 compared to my EF 24-105 F/4 IS Mk ii
But a 2nd batch of test with these 2 parameters changed are interesting too:
- In order to give an advantage to the zoom and benefit from IS, I did reduce the shutter speed for pics with my EF 24-105 F/4 IS Mk ii
- I also included tests at lower apertures as F/8
Both new parameters made the EF 24-105 F/4 IS Mk ii results look more interesting
For what it is worth, following my own humbles tests, UPDATED RESULT:
  • All my primes are much better at normal or high shutter speed than my EF 24-105 F/4 IS Mk ii
  • Apart from focal flexibility.. obviously... I will now consider my usage of my zoom EF 24-105 F/4 IS Mk ii for the following scenario: Slow shutter speeds thanks to IS and low apertures F/8 and less
My primes tend to be "old" ones without IS, so yes, this is not a perfect test of a new prime with IS vs a new zoom with IS
Rgds, Gaul
deanmejos Junior Member • Posts: 26
BUT ..
I'm going to affirm your statement here.  While it is true that primes can win in terms of other areas, even the "basic" L lenses still have something when it comes to color rendering.  Over a decade ago, I had the EF f/4 L trio (17-40/4, 24-105/4 and 70-200/4 non-IS) and there's just something about the colors coming from L lenses.  I remember reading about the 35/2 IS vs the MK1 35L and while the 35/2 comes close in terms of sharpness, the L still wins in bokeh but most especially color and contrast.
 deanmejos's gear list:deanmejos's gear list
Canon EOS M5 Canon 6D Mark II Canon EF 100mm F2.8L Macro IS USM Canon EF 35mm F2 IS USM Canon EF 50mm F1.8 STM +4 more
