X100V eye-sensor problem
Started 4 months ago | Questions
Natalino Russo
Natalino Russo New Member • Posts: 20
Hi everybody.
My X100V has an annoying problem: the eye-sensor doesn't switch from screen to viewfinder, and vice versa.
The eye-sensor itself seems to work: if I turn on the camera with my finger in front of the eye-sensor, the camera starts properly in viewfinder mode, but when I remove my finger it doesn't go back to the LCD screen. If I turn on the camera with the eye-sensor free, it starts normally with the LCD screen, but then it doesn't switch to viewfinder by bringing my eye close to the eyepiece or a finger to the eye-sensor.
I am not new for this camera: I had the X100T and the F, and I've had the V for a year now.
View mode setting is set on ”eye sensor”, as usual. The eye sensor is clean and free from obstructions. I reset the machine by restoring the factory settings, both for the shooting configuration and for the general configuration. The problem remains.
I also formatted the SD in the car, to avoid Mac compatibility issues or weird invisible files. I have also tried other brands of SD.
The firmware is updated to version 2.13.
The issue persists.
The problem is not constant, but very frequent. It shows up all days, then suddenly disappears and comes back for no reason apparent.
Does something like this happen to anyone else?
Thank you!
Natalino Russo
www.natalinorusso.it
Fujifilm X100F Fujifilm X100T Fujifilm X100V
Morris0
Morris0 Forum Pro • Posts: 32,175
Re: X100V eye-sensor problem
Try cleaning the sensor
Good luck,
Morris
Fujifilm X-T3 Fujifilm X-H2S Canon EF 200mm f/2.8L II USM Nikon AF-S Teleconverter TC-17E II XF 90mm +11 more
Natalino Russo
OP Natalino Russo New Member • Posts: 20
It is perfectly clean, as I’ve written in the post.
Natalino Russo
