R6 mark II review
AtmaWarna Regular Member • Posts: 119
R6 mark II review
12
Duade Paton have posted new R6 mark ii review in his youtube
some remark from his review :
- noticable AF improvement compared to R6
- bigger AF area when using f11 tele prime lens
- best rolling shutter performance for non stacked sensor
- some AF tips at the end of Video
overall its great camera
 AtmaWarna's gear list:AtmaWarna's gear list
Canon EOS Rebel T6i Canon EOS R7 Canon EF 35mm F2 IS USM Canon EF-S 55-250mm f/4-5.6 IS STM Sigma 100-400mm F5-6.3
Canon EOS R6 Canon EOS R6 Mark II
Zeee Forum Pro • Posts: 25,627
Re: R6 mark II review
5
Minute 17
Don't Look Up! The very fabric of captured light is noise.
 Zeee's gear list:Zeee's gear list
Canon EOS R7 Canon EOS R6 Mark II Canon RF 24-105mm F4L IS USM Canon RF 100-500mm F4.5-7.1L IS USM +1 more
drsnoopy Senior Member • Posts: 1,216
Zeee wrote:
Minute 17
OK it’s a little faster. But consider : 1 millisecond is 1/1000 sec. We often photograph birds in flight at 1/2000th sec or 0.5ms to freeze the motion. So the tip of a bird’s wing will move 28 times as far during sensor readout using E-shutter compared to mechanical shutter closure. Of course this affects different parts of the wing depending on how it interacts with the line-by-line readout of the sensor. I think a 14ms readout will still show very significant rolling shutter artefacts and distortion.  The only complete answer is global shutter (whole sensor read out at the same time).
 drsnoopy's gear list:drsnoopy's gear list
Canon EOS RP Canon EOS R5 Canon EOS R10 Canon EF 100mm F2.8L Macro IS USM Canon RF 35mm F1.8 IS STM Macro +10 more
Deorum Contributing Member • Posts: 780
drsnoopy wrote:
Zeee wrote:
Minute 17
its not 100% accurate.
Even if you drop from 1/2000 to 1/1000 this doesn't mean the bird wing will be totally blurred.
in other words birds dont flap their wings 2000 times per second. Fastest birds flap their wings around 100t/sec.
Then the sensor read out is for the whole area of the sensor. How much time it needs to scan from top to bottom (or right to left, idk).
Unless the area we are talking about covers the whole frame, (it doesn't, it doesnt even cover the 1/100 of the frame), then sensor read out for that specific area is gonna be much much faster.
So all in all, its a very welcomed change and i believe e-shutter is usable in most scenarios.
George Spyros,
www.georgespyros.com / www.energyphotos.gr
 Deorum's gear list:Deorum's gear list
Canon EOS-1D Mark III Canon EOS-1Ds Mark III Canon EOS 7D Canon EOS-1D Mark IV Canon EOS-1D X +8 more
Alastair Norcross
Alastair Norcross Veteran Member • Posts: 9,874
6
drsnoopy wrote:
Zeee wrote:
Minute 17
That's not true. Mechanical shutters have rolling shutter too. The mechanical shutter doesn't completely open and close in 1/2000 second. There's a slit that travels across the frame. No part of the frame is exposed for more than 1/2000, but it takes much longer than that for the whole slit to cross the frame. That's why the flash synch speed is usually about 1/200 or 1/250.
“When I die, I want to go peacefully in my sleep like my grandfather. Not screaming in terror, like the passengers in his car.” Jack Handey
Alastair
http://anorcross.smugmug.com
Equipment in profile
 Alastair Norcross's gear list:Alastair Norcross's gear list
Canon G7 X II Canon EOS M6 II Canon EOS R7 Canon EOS R6 Mark II Canon RF 35mm F1.8 IS STM Macro +24 more
CoolHandLu Regular Member • Posts: 451
In the video, he addresses in detail rolling shutter around 16:28.  It's a non-issue save for VERY fast moving wings (he mentioned hummingbirds).  His entire testing of the R6II was done electronically @ 40 FPS, and again, save for very fast moving subjects, it's a non-issue for the most part according to Duade (the reviewer in the linked video).
I don't want to achieve immortality through my work. I want to achieve immortality through not dying. (Woody Allen)
https://www.flickr.com/photos/coolhandlu/
 CoolHandLu's gear list:CoolHandLu's gear list
Fujifilm X-T3 Fujifilm X-T4 Fujifilm XF 16-80mm F4 Fujifilm XF 10-24mm F4 R OIS WR Fujifilm XF 70-300 F4-5.6 R LM OIS WR +12 more
Steve Fink Senior Member • Posts: 1,652
In Camera AF Focal Distance Suggestion
Agreed, great review!  I love his AF suggestion of having an in camera focal distance, similar idea to what many long focal lens have.
Steve
Minds are like parachutes, they only work when they are open - Unknown
JoeSchmoe007 Contributing Member • Posts: 502
TLDW: Digital TC is a gimmick and pre-burst implementation is not great.
N/T
NormSchultze Contributing Member • Posts: 594
What about rolling shutter on aircraft propellers ?  And at Takeoff power ?      Anyone tested that?
Yep - it's in the video.  He shoots drone propeller blades and there's significant rolling shutter.  So if hummingbirds in flight, drone/aircraft spinning propeller blades are your thing, then this isn't your camera.
bytebuster Forum Member • Posts: 77
Some nice updates on the mark ii. Love that you can now fully customize the q menu and can save video custom modes separate from photo
Duckman21 Regular Member • Posts: 273
Rolling shutter warping is one issue but my main concern with the drone shot comparison he used is that there is noticeably more of this jagged/aliasing effect which often appears on the wingtips of fast-flying birds.
I described it on the R6 in this previous thread asking if there was a good way to remove these artifacts: https://www.dpreview.com/forums/thread/4659188#forum-post-66312937
I found that while the RAW file and in-camera JPEG has it, it wasn't always very obvious but DxO PureRAW was making it worse. On the other hand Topaz Denoise has a tendency to smear most of it of when you apply noise reduction.
Instagram @FYLegend21
500px @frankyboy5
 Duckman21's gear list:Duckman21's gear list
Canon EOS Rebel T6s Canon EOS R6 Canon EF-S 18-135mm F3.5-5.6 IS STM Tamron SP 150-600mm F5-6.3 Di VC USD G2 Canon RF 800mm F11 IS STM
Blue-Shift
Blue-Shift Regular Member • Posts: 140
Zeee wrote:
Minute 17
Ah, that's interesting. I would have thought the smaller sensor of the R7 makes much faster readouts possible.
Well I traded my R5 in for the R6II. Charging da battery. We shall see but I think I'll be OK. 45mp as a bit of overkill for I do. 30mp was sweet spot.
Ephemeris
Ephemeris Senior Member • Posts: 1,186
Hope you enjoy it. In keen to learn of the new advances.
I was a little confused about the 30MP comment?
R2D2 Forum Pro • Posts: 26,530
Blue-Shift wrote:
Zeee wrote:
Minute 17
Given all else being equal, but they're not.  The R7 likely has slower processor and bus speeds.
R2
Mebpenguin
Mebpenguin Contributing Member • Posts: 671
R2D2 wrote:
Blue-Shift wrote:
Zeee wrote:
Minute 17
R2
Plus more MP to push.
 Mebpenguin's gear list:Mebpenguin's gear list
Panasonic G85 Panasonic Leica Summilux DG 25mm F1.4 Panasonic 12-60mm F3.5-5.6 OIS Panasonic 100-300mm F4-5.6 II Sony Cyber-shot DSC-HX90V
Sorry about that. I mostly do web applications so 30mp gives me the best IQ with the least amount of work.
But the R6ii is 24MP, not 30.  I'm confused as well.
Brian
Brian
Not sure how to explain this any further but I will try.
I sold my 5D4 and EF 24-70 II and purchased an R and RF 24-105 f4. I really liked both those   30mp sensors for what I do, which is mostly for web applications. Excellent combo for urban photography.
Also for BIF. With my R, EF 100-400II and 2X.
When the R5 was announced I decided to get it and the 100-500. I ordered both at the same time. The lens came fist so I used it on the R for about about a month. I loved it.
Not so much with the R5. Nothing wrong with it but for what I do 45mp is overkill. Lower mp is just easier to work with for web display - for me.
https://gdanmitchell.com/2011/05/01/why-your-21mp-file-looks-softer-than-your-12mp-image-at-100
