Bryce Canyon with the X-H2s, 70-300 fuji and Tamron 17-70
Started 5 months ago | Photos
RobertBetchel
RobertBetchel Regular Member • Posts: 212
33
On the day after Thanksgiving I was lucky enough to make sunrise at Bryce Canyon.  The literal sunrise was just ho-hum, but the images generated shortly after sunrise when the Hoodooos start to receive the early morning light was just amazing.  Bryce is less than two hours from Zion, so well worth a day trip if you are already in the Zion area.
Hoodoo closeup shot with Tamron 17-70 at f/8 1/300th ISO 160
15 image pano shot with Fuji 70-300 at 70 mm, f/10, 1/200
XF70-300 at 181.3mm 1/110 f/7.1 ISO 160
Shot with Tamron 17-70  at 38.8mm 1/320 f/8 ISO 160
Shot with Tamron 17-70 59.6 mm 1/160 f/11 ISO 160
Shot with Tamron 17-70 at 41.8mm, 1/340th f/8 ISO 160
 RobertBetchel's gear list:RobertBetchel's gear list
Fujifilm X-H2S Fujifilm XF 70-300 F4-5.6 R LM OIS WR Fujifilm XF 23mm F1.4 R LM WR Tamron 17–70mm F2.8 Di III-A VC RXD Fujifilm XF 30mm F2.8 R LM WR +1 more
Comment & critique:
Barbarus
Barbarus Regular Member • Posts: 378
Re: Bryce Canyon with the X-H2s, 70-300 fuji and Tamron 17-70
Ooh, Bryce looks great in a sprinkling of snow!  Nice work.
-Bryce
 Barbarus's gear list:Barbarus's gear list
Fujifilm X100F Fujifilm X-Pro3 Fujifilm X-H2 Fujifilm XF 14mm F2.8 R Fujifilm XF 23mm F1.4 R +6 more
Samuraidog Senior Member • Posts: 1,672
Excellent shots. I like the first one best.
 Samuraidog's gear list:Samuraidog's gear list
Fujifilm X-T30 Fujifilm X-H2S Fujifilm XF 35mm F1.4 R Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm XF 27mm F2.8 +13 more
Morris0
Morris0 Forum Pro • Posts: 32,181
Sweet set with the snow adding to the stunning red rock.  You photos bring back wonderful memories
Morris
Fujifilm X-T3 Fujifilm X-H2S Canon EF 200mm f/2.8L II USM Nikon AF-S Teleconverter TC-17E II XF 90mm +11 more
jhorse Veteran Member • Posts: 5,913
Nice set. For those of us the other side of the Pond, what is a/are Hoodoos?
Lovely pano. I would be interested in your technique and whether it was created handle held or on a tripod.
This is a wonderful image
Thanks.
 jhorse's gear list:jhorse's gear list
Fujifilm X-E4 Fujifilm X-T5 Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm XF 55-200mm F3.5-4.8 R LM OIS Fujifilm XF 10-24mm F4 R OIS +6 more
RobertBetchel
OP RobertBetchel Regular Member • Posts: 212
Thanks for the kind comments. Hoodoos are the distinctive rock formations that dominate Bryce Canyon. They are tall skinny shafts of rock that protrude from the bottom of arid basins.
As for my pano technique I have done them both handheld and on a tripod, but in this case a tripod was used, and is always preferable for the best results. I first confirmed the tripod base was level and then mount the camera via L bracket to shoot the series in portrait orientation using a ball head that supports panning. It was an overlapping set of 15 images, each of them exposure bracketed. Each image overlaps the prior image by at least 1/3rd to ensure successful stitching. I used a 70-300 Fuji lens set to 70mm to shoot the pano and then used Lightroom to create the hdr panorama. This produces a DNG file that can then be post processed to taste.
Morris0
Hoodoos are created by the erosion of sandstone.  They sometimes look like the drippings made at the beach on a sand castle.
Morris
Foxjet Contributing Member • Posts: 987
Beautiful series Robert! Bryce with snow is wonderful.
 Foxjet's gear list:Foxjet's gear list
Fujifilm X-T3 Sony a7R V
dmaclau Veteran Member • Posts: 3,053
Very nice, Robert.  Thank's for sharing.  I enjoy Bryce, particularly in winter.  It's more difficult to reach than Zion, usually very very cold and as a result so uncrowded.  Nice with the snow.
absolute power corrupts...absolutely
 dmaclau's gear list:dmaclau's gear list
Fujifilm FinePix X100 Fujifilm X70 Fujifilm X-Pro2 Fujifilm XF 18mm F2 R Fujifilm XF 35mm F1.4 R +4 more
RobertBetchel
Indeed- it was 19 degrees and windy at the rim. Thankfully I dressed appropriatelty.  This late in the season the shuttles were not running and it was easier to explore in your own car.
Rightsaidfred
Rightsaidfred Senior Member • Posts: 2,179
Just -  wow.
Thank you for sharing!
Wonderful.
Martin
 Rightsaidfred's gear list:Rightsaidfred's gear list
Fujifilm X-T20 Fujifilm X-T4 Fujifilm XF 35mm F1.4 R Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm XF 55-200mm F3.5-4.8 R LM OIS +5 more
Ha!  I understand that.
A few years ago I got to Bryce before sunrise, noticed an empty bus in a parking lot.  When I went in to Men's room I there were a half dozen photographers inside. A group had been bussed up there for the morning sunrise lineup and were trying to keep from freezing.  I guess the Ladies room was the same.
Lettermanian
Lettermanian Senior Member • Posts: 2,389
Wonderful set, love the last image 👍🏻
"Be yourself. No one can say you're doing it wrong." -Charles M. Schulz
"I love mankind... it's PEOPLE I can't stand!!" - Linus
 Lettermanian's gear list:Lettermanian's gear list
Fujifilm X-T3 Carl Zeiss Touit 2.8/12 Tamron 17-70 F2.8 Di III-A VC RXD Fujifilm XF 70-300 F4-5.6 R LM OIS WR
Rod McD Veteran Member • Posts: 8,589
Hi Robert,
Wonderful place, great set.  Thanks for posting.
Cheers, Rod
 Rod McD's gear list:Rod McD's gear list
Fujifilm X-T4 Voigtlander 90mm F3.5 APO-Lanthar SL II Fujifilm XF 35mm F1.4 R Fujifilm XF 60mm F2.4 R Macro Fujifilm XF 18-55mm F2.8-4 R LM OIS +13 more
dezinerd
dezinerd Senior Member • Posts: 1,309
Beautiful series. Bryce is a gem to behold. Your Pano caused me to notice all the hoodos  at the far edge are the same height. I did not realize that while I was there. Great work.  I am curious did you use a clear, UV , Haze filter on your lens.  Is the haze more apparent in the photo than you remember seeing it when you were there? During my trips Bryce and Zion were haze free but Canyon Lands was extremely hazy. I suppose sunrise and winter are part of the mix as well. Thanks for sharing.
Dennis
 dezinerd's gear list:dezinerd's gear list
Olympus C-2100 UZ Panasonic LX100 Nikon D70s Nikon D200 Nikon D700 +8 more
