X-T5 bug causing freeze-up: Can X-T5 owners test/confirm?
Started 5 months ago | Questions
dbull058 New Member • Posts: 11
7
Hi all, I've noticed a bug causing my X-T5 to freeze up occasionally, and just did some testing to narrow in on exactly what sequence of steps causes it. I sent an email to Fuji support, but I'm curious if others with an X-T5 could test as well and confirm if this is a general bug, and not just something with my specific camera.
The bug causes the X-T5 camera to completely lock up and become completely unresponsive. The only solution when this happens is to remove and reinsert the battery. The lock up happens every time when the exact steps are done:
1. Go to an item in the stills "My Menu" and change it. (The bug doesn't happen if no menu item is changed.)
2. Arrow-left on the directional pad to move the cursor out of the list of My Menu items, and onto the left-most list of menu categories.
3. Arrow-up to move to try to move to the Network/USB settings menu. The camera will not move away from the My Menu, but will instead freeze up and become unresponsive. Pressing buttons, waiting, or switching the camera off will have no effect. Only removing and reinserting the battery fixes it.
Anyone willing to check your X-T5 and confirm? If this is indeed a software bug affecting all X-T5 cameras, hopefully a fix will be in the first firmware update! Many thanks in advance.
 dbull058's gear list:dbull058's gear list
Fujifilm X-T5 XF 90mm 7artisans 7.5mm F2.8 Fisheye Fujifilm XF 16-80mm F4 Venus Laowa 65mm F2.8 Macro +6 more
ninjagowoo
ninjagowoo Regular Member • Posts: 251
Re: X-T5 bug causing freeze-up: Can X-T5 owners test/confirm?
I could not reproduce. On step 3 are you still in the context of adding something new to the menu? or does this happen when you just rearrange stuff?
 ninjagowoo's gear list:ninjagowoo's gear list
Fujifilm X-H1 Fujifilm X-T5
woody23 New Member • Posts: 17
Yes, this type of X-T5 freeze -up has happened to me, not every time, but frequently. Exactly as you describe when leaving My Menu. Removing and replacing the battery fixes the problem temporarily. This is definitely a bug and a fairly significant one.
DaveHutch Senior Member • Posts: 2,022
Just tested and no problem here. Changed an item twice and went back tot eh left-hand menu then up, past connection settings. All is fine so far.
I have 7 My Menu items so have done this a few times but will keep my eye open for it.
I can only help one person each day...
...and today is not your day!
(tomorrow doesn't look good either!)
 DaveHutch's gear list:DaveHutch's gear list
Fujifilm X-T3 Fujifilm X-T5 Fujifilm XF 35mm F1.4 R Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm XF 55-200mm F3.5-4.8 R LM OIS +4 more
For me, the freeze up is happening immediately after visiting My Menu to change a setting (not to add, remove, or reposition a My Menu item).
After changing a setting in My Menu, the freeze happens when I press the left arrow to return to the tabs in the left column (where "MY", "IQ", "AF/MF" etc icons are located). The D-pad selector arrows become frozen and the on/off switch is inoperable. Removing the battery is the only fix that I've found. I have 2 pages of My Menu settings.
WCguy Senior Member • Posts: 1,106
Yes, same problem here. While in my menu making changes, then trying to leave, it froze and was unresponsive. It has happened three times so far. I just open the battery cover, quickly pop battery up and down, back in service. A bug that definitly needs a fix.
It's What You Learn After You Know It All That Counts!
 WCguy's gear list:WCguy's gear list
Sony RX1 Nikon 1 V1 Nikon 1 AW1 Fujifilm X-T1 Nikon 1 V3 +37 more
owenb Senior Member • Posts: 1,229
Nope, didn't cause a freeze for me.
I went into My Menu, changed my first item (AUTO ISO) from mode 3 to mode 2, went back to main menu, went up to network settings, no issues.
 owenb's gear list:owenb's gear list
Fujifilm X-T3
I'll tell you what I do think is a serious issue though - not being able to access My Menu with one click of the MENU button. Apparently this is a new feature and entirely by design. I hate it.
Fujifilm X-T3
RalfBorn New Member • Posts: 2
I confirm that happened to my X-T5 as well. Fuji Germany said it's "hardware" error which i did not believe. Anyhow, got my cam swapped and the new one shows exactly same freeze like you described it, by switching between menus around "MY"
https://www.dropbox.com/s/guz6tbjc48e4j5k/Xt5Silber.mp4?dl=0
Rand 47
Rand 47 Senior Member • Posts: 1,721
Agree.  They should make this an option for My Menu.  Either always go to My Menu, OR have it “go to the last place you were.”  Seems to me this could be an easy firmware change.
Rane
RichThomasTacoma Regular Member • Posts: 109
Tried this on my X-T5 and the arrow keys fully operate as would be expected.  Could be a conflicting config setting you've enabled; have you tried restoring the camera to default factory settings?  A pain but it might get you closer to a solution or explanation.
 RichThomasTacoma's gear list:RichThomasTacoma's gear list
Fujifilm X100V Fujifilm X-E3 Fujifilm X-Pro3 Olympus E-M1 III Fujifilm X-T5 +8 more
Cream17
Cream17 Senior Member • Posts: 1,250
Solution and workaround
Ok, I’ve managed to reproduce it and have a work around 🤓
I can only recreate the issue if I have 2 pages of items in “ My Menu” If it’s one page of items then the problem doesn’t occur.
I followed the steps by changing an item and going back to the left menu where it appeared to lock.
pressing buttons didn’t do anything like others have reported, however if I look through the EVF, (I have this activated) then this appears to unlock the menu and I have normal operation again.
Compared to my XT3 which I also tested, the navigation speed does seem more sluggish on the XT5
I seriously doubt that this is a hardware issue as one person was told by Fuji Germany.
For those who have tested above positively or negatively, I’d be interested if you could re-test and advise.
 Cream17's gear list:Cream17's gear list
Fujifilm X-T3 Fujifilm X-H2 Fujifilm XF 35mm F1.4 R Fujifilm XF 14mm F2.8 R Fujifilm XF 27mm F2.8 +9 more
I agree, The whole point of the My Menu is to have your most-used settings available quickly.
While Fuji are at it, maybe they can add the 'double-click to centre' function back for the focus lever
Re: Solution and workaround
Just added an extra item so I have two pages and retested. No fault found. I switched the camera off/on before retesting and changed items on page 1 and page 2 to make sure. All fine.
Cream17
Thanks Dave,
Interesting.....
If I have 3 items its fine, 2 pages its a problem.
What I have noticed now though is it if it locks, I just wait around 60 seconds then the menu is accessible again. So nothing to do with the EVF as I originally thought.
Seems like its processing in the background.
5
There is definitely a sluggishness when you move from My Menu to Connections which doesn't exist on the X-T3 so maybe this is just a code issue that needs an update.
Is there a way to report bugs to Fuji or request features like you can with Apple?
Cream17
Agreed, I think people need to email Fuji Tech Support to get traction on this.
I've contacted them in the UK
fujifilmtec_uk@fujifilm.com
Figured out exactly the same working solution after resetting my 2nd T5 and putting all settings back in manually.
ninjagowoo
Ah I misinterpreted the steps then. I was able to change a lot of settings but eventually could reproduce the bug. I have also noticed that menu navigation is more laggy than I'm used to from my T2 & H1. Hopefully they will have a firmware fix eventually.
ninjagowoo
You can also schedule a techtime: https://fujifilm-x.com/en-us/tech-time/ to speak directly to a rep on a zoom call. Recommend it if they still have openings.
