Your thoughts on the M6ii + 28mm f3.5 macro?
Foskito
Foskito Senior Member • Posts: 1,406
Hello guys,
I have an RP with the kit 24-105mm and the 35mm f1.8 IS. I mainly use it to take hundreds of product shots of my wife's online jewelry store. The close focus capabilities of the 35mm allow me to produce great IQ images.
I have been tempted by the M system for years, (never pulled the trigger though) but now that the refurbs are at an incredibly low price I am super interested in getting an M6ii and the 28mm f3.5 macro, I guess the extra 6mp might be handy?
Thanks in advance!
 Foskito's gear list:Foskito's gear list
Canon EOS 5D Leica M8 Panasonic Lumix DMC-G1 Leica M9-P Canon EOS 6D +14 more
User1303423862 Senior Member • Posts: 1,070
Re: Your thoughts on the M6ii + 28mm f3.5 macro?
Foskito wrote:
Hello guys,
Thanks in advance!
Great lens for handheld macro, and normal photography. Be quick though, the refurb cameras are gone when they're gone.
I am not a number. I am a free man.
How the heck did I end up with this username?
 User1303423862's gear list:User1303423862's gear list
Canon EOS R Canon EOS M6 II Canon EF-M 22mm f/2 STM Canon EF-M 28mm F3.5 Macro IS STM Canon 70-300 F4-5.6 IS II +4 more
R2D2 Forum Pro • Posts: 26,530
Foskito wrote:
Hello guys,
Thanks in advance!
The M6ii is an excellent Macro camera.  The biggest difference between this combo and what you’re using now is that the 28mm on the M6ii will fill the frame with an object 18mm wide (4x the magnification than you’re getting now).  At these very high macro ratios, the working distance is quite short though, so you need to have an appropriate way of lighting your subjects.
Happy shopping!
R2
MyM6II Senior Member • Posts: 2,424
R2D2 wrote:
Foskito wrote:
Hello guys,
Thanks in advance!
And then the built-in light helps a lot. 😉
 MyM6II's gear list:MyM6II's gear list
Canon EOS M6 II Canon EOS M6 Canon EOS M200 Canon EOS M50 II +1 more
MyM6II wrote:
R2D2 wrote:
Foskito wrote:
Hello guys,
Thanks in advance!
I just figured the OP already had some kind of lighting setup that highlighted the jewelry nicely (rather than straight-on flat lighting).  That would be my own preference.
R2
jim mij Senior Member • Posts: 1,035
Foskito wrote:
Hello guys,
Thanks in advance!
The m6ii provides great detail for macro, although i use the ef-s 60mm (with an adaptor) rather than the native m28 lens. I have samples in this and the macro forum if you want to browse
The 60mm might also work on your RP (with an adaptor)?
When i asked in this forum about the 28 folks advised me to stay with the 60, but our needs might differ
regards
Jim
 jim mij's gear list:jim mij's gear list
Canon EOS M6 II Canon EF 100-400mm f/4.5-5.6L IS USM Canon EF-S 60mm f/2.8 Macro USM Kenko Teleplus Pro 300 AF 1.4x Canon EF-M 22mm f/2 STM
Sittatunga Veteran Member • Posts: 5,406
jim mij wrote:
Foskito wrote:
Hello guys,
Thanks in advance!
regards
Jim
The 60mm is an EF-S lens, so it will give a maximum 10Mpx cropped image with the RP.  I can't see the point in adapting it if you have both cameras when you get 32Mpx from the M6 II.
It would make a nice portrait lens too on crop; the 28mm is a nice standard lens, with a focal length about the same as the diagonal of the M6 II sensor.  The built-in lighting of the 28mm (and the EF-S 35mm macro) is quite versatile; the choice of left side, right side or both sides lit at two intensities.  That's not quite what you can achieve with tabletop lighting and a bit of working room, but good for something you can put in a jeans pocket.
Sittatunga wrote:
jim mij wrote:
Foskito wrote:
Hello guys,
Thanks in advance!
regards
Jim
+1 Sometimes I’ll toss the M6ii + 28 Macro in my bike bag for shots of opportunity along the way. My strong preference for (lightweight) lighting on-the-go is a piece of translucent plastic with a hole cut in it and stuck on the end of the lens like this…
With this diffuser you can use either the pop-up flash, or a more powerful hotshoe mounted flash.
Note: With the 28 Macro, the diffuser slides nicely right onto the miniscule lens hood. Shown here sandwiched onto a Raynox Close Up Lens.
This setup provides a really nice diffuse light, and stops action/shake with the flash.
You can’t use the Focus Bracketing Mode with flash though. However you can shoot 14 fps with an external flash and “cut slices” right through your subject using the “Lean Technique” for stacking later (note: you need to “tape over” the hotshoe’s communication contacts in order to achieve 14 fps with the flash).
R2
ps. Info here provided for others (I know you know this stuff already ).
Photato
Photato Veteran Member • Posts: 3,152
R2D2 wrote:
Sittatunga wrote:
jim mij wrote:
Foskito wrote:
Hello guys,
Thanks in advance!
regards
Jim
R2
Nice setup R2.
Would you mind sharing what kind of translucent plastic is that ?
It is a DIY or you bought it ?
 Photato's gear list:Photato's gear list
Panasonic LX100 Canon EOS M Canon EOS M6 Canon EOS M6 II Canon EOS R10 +22 more
Foskito
OP Foskito Senior Member • Posts: 1,406
R2D2 wrote:
Sittatunga wrote:
jim mij wrote:
Foskito wrote:
Hello guys,
Thanks in advance!
regards
Jim
R2
Great solution R2, thanks!!
Foskito wrote:
R2D2 wrote:
Sittatunga wrote:
jim mij wrote:
Foskito wrote:
Hello guys,
Thanks in advance!
regards
Jim
R2
Looks really good, but I'd radius that internal corner. The stress concentrations from rectangular windows were what caused the first jet airliners to break up in mid-air. The sharp corners of the hatches did something similar to a lot of the Liberty Ships too.
Photato wrote:
R2D2 wrote:
Sittatunga wrote:
jim mij wrote:
Foskito wrote:
Hello guys,
Thanks in advance!
regards
Jim
R2
Nice setup R2.
It's so nice that you can just stuff the diffuser in a back pocket or a bag. Slip it on as needed.
Looong story here.
First, you need a nice fairly stiff plastic that when held up to the light you can see your fingers through, but not see your fingerprints. Getting the right amount of diffusion is the tricky part (plus you want a nice white plastic that doesn't impart any tint).
I comb the box stores constantly, looking for something with just the right properties. The security staff must think I'm crazy holding all manner of stuff up in the air whenever I find a likely prospect, be it a storage box or a toilet brush holder!
The original plastic sheeting I found was the perfect material. It was the cover of a threee-ring binder that I found at a Staples store years ago (it's since been discontinued). I bought a couple of them at the time, but should have bought a bunch more! Now I'm peering through everything from milk jugs to office supplies looking for the ideal plastic. I think you'll have to do the same!
BTW I found a pic of the diffuser mounted on my 28 Macro...
Crude but effective. I cut the hole just a bit smaller, so that the fit is snug and the diffuser stays put. The plastics I've found are non-marring.
Just an FYI for folks. Diffusion increases with size and (nearer) distance, plus you want to further eliminate hot spots as much as possible (sometimes I add a smaller central layer, or space two sheets a bit apart). Flash power becomes a factor though, as diffusion increases.
Creating a mini softbox out of Foamcore increases light transmission, and can attach right to your flash's head (I use velcro).  It's not as portable as a simple sheet though.
R2
m100
m100 Senior Member • Posts: 2,048
R2D2 wrote:
Photato wrote:
R2D2 wrote:
Sittatunga wrote:
jim mij wrote:
Foskito wrote:
Hello guys,
Thanks in advance!
regards
Jim
R2
Nice setup R2.
Looong story here.
R2
Broken junk flat screen TVs have a big piece the size of the screen in them that was used to diffuse the light from the LEDs.
Dr. says listen to this every morning.
https://www.youtube.com/watch?v=bEeaS6fuUoA
 m100's gear list:m100's gear list
Canon EOS M6 II
Foskito
R2D2 wrote:
Photato wrote:
R2D2 wrote:
Sittatunga wrote:
jim mij wrote:
Foskito wrote:
Hello guys,
Thanks in advance!
regards
Jim
R2
Nice setup R2.
Looong story here.
R2
R2, you should take this to SharkTank 😂
Foskito wrote:
R2D2 wrote:
Sittatunga wrote:
jim mij wrote:
Foskito wrote:
Hello guys,
Thanks in advance!
regards
Jim
R2
I have a diffuser cut out for the 5-diopter Raynox DCR-150 (pictured), and one for the 8-diopter DCR-250. I like the DCR-250 because it is quite powerful and basically acts as a doubler (on whatever lens it's mounted to). Mounting is super-quick and easy, as it just clips onto filter threads from 52mm to 67mm (or a wider range via step-up/down rings).
IQ is very good (it has 3 elements). You do get a little softening though (about the same IQ as two 4-diopter Canon 250D's stacked). An added bonus is that with close-up lenses you don't lose any light (like you do with other methods ie tubes, dedicated macro lenses etc.).
R2
Photato
R2D2 wrote:
Photato wrote:
R2D2 wrote:
Sittatunga wrote:
jim mij wrote:
Foskito wrote:
Hello guys,
Thanks in advance!
regards
Jim
R2
Nice setup R2.
Looong story here.
R2
Good to know, I underestimated the part of finding the material with the right properties, not only in diffusion quality but also weight and rigidity.
I found this one that sells for $12 and can be folded into a small bag, similar to car's windshield shade. I probably go this route.
Thanks for sharing.
R2
HeHe, now you're talking like a true engineer!
I think if I hit something hard enough to tear this 1mm poly sheet though, I'd for sure snap the lens in half first!
Having a nice radiused corner would make it look a little sleeker though!  (esp good when I take it to Shark Tank!)
R2
m100 wrote:
Looong story here.
R2
Whoa, good tip. Now I just have to wait for my 4K LG OLED to die!
R2
Photato wrote:
R2D2 wrote:
Looong story here.
R2
Thanks for sharing.
Yes.  Exactly the same principle!
I have a couple of different Rogue FlashBenders too.  Nice that you can shape them.  You do have to be careful not to bounce any light back onto the surface of the (lens') objective though, in order to maintain as much contrast and color as possible.
R2
m100
R2D2 wrote:
m100 wrote:
Looong story here.
R2
R2
Junk TVs get dumped on the roads all around me.
https://wwemail notification settingsw.youtube.com/watch?v=bEeaS6fuUoA
Canon EOS M6 II
