Condensation inside lens
allineedislight Senior Member • Posts: 1,309
Re: Condensation inside lens
fronko wrote:
Amadeus21 wrote:
As I already said: Store the lens outside in the coldness. (I think there is enough at the moment in U.S. : (
Cold air is *very* dry. So you may make the lens "breath" in and out but agitating the zoom and focus function every once in a while for some days ( I think not below - 15 deg. C.) during a drying cycle.
No lens is air tight. So I think the owner before has done somerhing inappropriate with the lens. Furthermore and worse, there might be moisture in a *group* of lenses, which are cemented together in the factory. Then you will have to send the whole lens to Sigma definitely. You can have a look at the specs and construction of that objective (how many lenses in how many groups) at the Sigma site. Then you may see whether the frontmost lens is part of a (cemented?) group.
So my opinion.
Best wishes
Johannes
store it outside where? the lens is the 20mm 1.4 art dg hsm.
this one
https://www.sigma-global.com/en/lenses/a015_20_14/
Don't store any electronic or optical equipment outside the house, and also don't store it inside the house in cold conditions. If you do that's really the best way to grow mold on your lens.
Instead, keep it inside the house in a well-heated room. Probably the best place to store a camera is in fact in an office space or a living room. Bed rooms etc are not good because they are colder and there is a lot of moisture. Same for cellars and other nonheated storage rooms.
In the UK the housing stock is quite old and comparatively poorly insulated often with simple single glasing windows etc. So one needs to pick suitable rooms carefully, esp. for storing delicate equipment. For example don't store it in a room where there is window condensation in the morning.
 allineedislight's gear list:allineedislight's gear list
Sigma DP2s Fujifilm X-E1 Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm XF 27mm F2.8 +1 more
Amadeus21 Senior Member • Posts: 1,158
I am of the opinion, you don't know about what you are speaking of and giving wrong examples and wrong advices. E.g. warm air does contain *more* moisture than cold. That's pure physics.
But now I'm off of that topic.
Johannes
 Amadeus21's gear list:Amadeus21's gear list
Fujifilm X100V Sony Alpha DSLR-A900 Sigma SD1 Merrill
It's poor advice to recommend storing camera equipment in cold and potentially damp environments, such as cellars, attics or even outside.
They need to be stored in dry well temperated rooms, such as an office space. Ideally, if you can afford, in a special camera cabinet.
Essentially, store your cameras and lenses in the same conditions as you do important paper documents.
