Darkmatterx76 wrote:
Honestly, that's a fair comment. I guess with the cost of the trip and my current equipment, I was feeling reluctant to spend a lot of money on what would be me trying out a new type of photography.
We understand.
Others have been on your path. I really like diving and photography, so combining the two hobbies was a natural for me. Plus my wife, who got me back into diving after 35 years, was also into photography. She paid for me to get PADI certified, and we went on a Caribbean cruise and dove at several ports.
I started out with one of those disposable ISO 400 film cameras. Here is my first underwater picture:
ISO 400 disposable film camera shot from Coco Cay - 2006
Well, it only took the roll of film from that camera to convince me to get a better camera. At least there were a lot of choices then. I picked a Canon Powershot SD630.
2007 - Canon SD630 in Hawaii
I used that camera on a couple of dive trips, plus out of the water as well along with a D300.
But I had it packed in a duffle type suitcase, and I didn't zip its pocket shut all the way. It fell out during air transport from Hawaii in 2009 and was lost.
On to the next camera - this time Canon SD 870is - first camera with image stabilization. (Which didn't seem to work for portrait orientation, oddly).
2009, Canon SD870is with internal flash and diffuser. Getting my teeth cleaned in Fiji
In 2009 I did a Liveaboard in Fiji, and I experimented with external flash a bit. (Badly though). I had been shooting the internal flash through a diffusing panel that came with the camera, but it had no range at all. I brought an Ikelite AF-35, which was a revelation on the shots that were more-or-less correctly shot, but after a few dives the battery compartment flooded, and I never tried using it again. I couldn't figure out the power controls at the time, so I quit trying to use it. (Still works, still sitting on a garage shelf).
The flash had me thinking though. I definitely wanted more light.
I kept shooting the point-n-shoot, and after the SD630 was lost, I bought a second 870is for my wife, and we both enjoyed shooting them. It was nice to have the same camera in that one wasn't going to be better than the other, but it produced some ripples in post-processing to avoid duplicate file names. (I came up with a naming scheme that differentiated both cameras.)
By 2014 I had taken as many point-n-shoot shots as I could stand and decided I needed to step up a notch from point-n-shoots with no flash. I got an RX100 II with Nauticam housing, dual YS-G1 strobes, a focus light, a wet macro lens and a wet wide dome lens from Bluewater photo. I thought a 20mp, image-stabilized, 1 inch sensor 'modern' camera would do the trick. Cost me $5000. All those Canons with their dedicated housings were under $500 new, each.
2015, RX100 II with dual YS-D1 strobes. Still a point-n-shoot
I did a couple of dive trips with the RX100, and I learned I really wanted to use those strobes. But the AF was typically point-n-shoot slow, and I got a lot of shots of fish tails leaving the frame. At least they were well-lit.
Also in 2014, my wife got Pancreatic cancer and had a Whipple procedure. Living now on borrowed time, I decided to put the camera I wanted to use underwater in a housing an live with the risk. Best decision I could have made. I bought a Nauticam housing for my D810, moved the focus light and strobes to it, and didn't look back. Took the rig on several dives on a Caribbean cruise, and I was hooked.
2015, D810, San Thomas. The last picture I took of my wife underwater.
The D810 completely blew away the point-n-shoots, including the RX100. Focus was fast, was where I wanted it, and was accurate. 36mp allowed for massive cropping. I shot in raw and learned more about post-processing. On the same dive I took the shot of my wife above, she took one of me with the 870is:
Same dive as previous image - 2015, Canon 870is. Note the difference to the D810
The above shots should give a nice contrast between a point-n-shoot w/o flash and a D810 with flash, plus the ability to shoot raw and post-process more.
My wife died in January of 2017, and things stalled out for me, change-wise.
I shot the D810 for 4 years underwater, and the last three of them I shot a D850 above water. Eventually I decided I wanted my best camera underwater, partly because it is the most challenging type of shooting I do, and partly because my housing was due for an expensive maintenance anyway. So I bought a housing for my D850 and used it from 2019 until last summer, when I convinced myself to upgrade to a Z9. But the images from the D850 and Z9 are akin to the D810 images. Mostly in the same class. I can heartily recommend a used D800 or D810 rig as very very capable of getting extremely high quality results.
One of my last D850 shots underwater:
D850, 2022 Bonaire - playing with snooted flash
I did 38 dives in Roatan in September learning the Z9, mostly wide angle. Barely got to video, but here is a nice still.
Z9, 2022 Roatan - playing with snooted flash
IF you get into underwater photography, you'll enjoy your first point-n-shoot immensely, but as a photographer you may feel extremely limited with the type of results you get. If you just want fish and diver portraits, they're decent. The newer ones give better results than the RX100 and have faster AF as well.
You may end up on the path I, and others (with $$), have taken. I'm very happy to have done so, though I've spent enormous amounts of $$ on it, and may still spend $$$ more. (There are some specialty lenses out there I'm very interested in, except for the price tags above $5000.)
I'll have to check to see if I can rent a camera once I'm down there, or maybe for a future trip.
Go to Lensrentals.com here:
https://www.lensrentals.com/rent/cameras/photo/underwater
Finally, Adam Savage (Mythbusters) states a philosophy of his is to buy a cheap tool to see if it deserves a place in his workshop, and if it does he replaces it with a very high quality one. If not, he is only out the cost of the cheap version.
Phoenix Arizona Craig
www.cjcphoto.net
"I miss the days when I was nostalgic."
