Adjust flash sync speed in Av?
Started 4 months ago | Questions
ihgold2 Regular Member • Posts: 163
Hi,
Is it possible to change the default shutter speed when shooting with and external flash on the m6 ii?  No matter what, it shoots at 1/60s when in Av mode.  I can certainly adjust it by shooting in Manual.  But it would be nice, I think, if the default were, say 1/100s rather than 1/60s.  Is there no way to control this?
 ihgold2's gear list:ihgold2's gear list
Canon EOS M5 Canon EOS M6 II Canon EF 70-200mm F4L IS USM Samyang 12mm F2.0 NCS CS Tamron SP 90mm F2.8 Di VC USD Macro +2 more
Canon EOS M6
geru Senior Member • Posts: 1,409
Re: Adjust flash sync speed in Av?
Setting the minimum shutter speed has no effect if your using flash. Go into the camera menu RED panel 2 go into set ISO SPEED if you set high low SHUTTER Speed press INFO read info all the way to the bottom of info. To go down press the trash icon on the pad.
 geru's gear list:geru's gear list
Canon EF 85mm F1.8 USM Canon EF-S 10-18mm F4.5–5.6 IS STM Canon EOS M50 Canon EOS M6 II Canon EF 40mm f/2.8 STM +5 more
R2D2 Forum Pro • Posts: 26,528
ihgold2 wrote:
Hi,
There may be a menu item (something called Safety Shift or other) that limits your shutter speed.  I think I remember seeing something like that (do a Menu dive).
I shoot flash using Full Manual, which gives a person complete control.  Highly recommend giving that a try.
Best of luck!
R2
R2D2 wrote:
ihgold2 wrote:
Hi,
Best of luck!
R2
There is a limitation with shutter speed when using Av.  I pointed to it in my post it is in the camera menu as well as the cameras manual.
OP ihgold2 Regular Member • Posts: 163
Thank you both.  I can't seem to get any other shutter speed than 1/60s while in Av.  But that's ok.  As R2D2 suggested, I've been doing some trial and error and will give manual a try while using the flash.
1/60 shutter speed in AV is the default speed it can't be changed.
geru wrote:
R2D2 wrote:
ihgold2 wrote:
Hi,
Best of luck!
R2
When I'm in Av Mode I can shoot at whatever shutter speed I like, from waaay slow up to the max sync speed (1/200 sec).  That's with either the built-in or external flash.
R2
